Hola, he conectado el vag-com 704.1 a mi Audi A4b6 2.5 TDI Quattro y le he hecho el autoscan y me han salido estos fallos:
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Part No: 8E0 920 900 EX
Component: KOMBI+WEGFAHRS. RB4 D16
Coding: 01101
Shop #: WSC 00913
WAUZZZ8EZ1A006716 AUZ6Z0Y0012822
1 Fault Found:
01303 - Telephone Transceiver (R36)
49-00 - No Communications
Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H59 0650
Coding: 0301217
Shop #: WSC 51462
5 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 34
Reset counter: 106
Time Indication: 0
Date: 2008.07.15
Time: 13:26:16
Freeze Frame:
Mileage: 655350 km
Count: 1110
Clock: 19:39
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 3
Reset counter: 55
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 54
Time Indication: 0
Date: 2008.07.11
Time: 19:02:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 54
Time Indication: 0
Date: 2008.07.11
Time: 19:02:25
02446 - Disk Drive Mechanical Malfunction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 84
Address 56: Radio Labels: 8E0-035-192-RNSE.LBL
Coding: 0301217
Shop #: WSC 51462
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 106
Time Indication: 0
Date: 2008.07.15
Time: 13:26:16
Freeze Frame:
Mileage: 655350 km
Count: 1110
Clock: 19:39
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 55
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 54
Time Indication: 0
Date: 2008.07.11
Time: 19:02:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 54
Time Indication: 0
Date: 2008.07.11
Time: 19:02:25
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 84
End --------------------------------------------------------------------------------------------------
A ver si me podeis echar una mano para saber a que se deben dichos fallos y ayudarme a corregirlos.
He echo el cambio de concert II a RNS-E, lo que no se si está configurado correctamente, en el fis si que me salen las
instrucciones del navi.
Gracias por adelantado.
¿Nadie me puede facilitar algo sobre el tema?, es que ahora no me salen los pictogramas en el fis, se le va la olla al
coche :cfsd1:.
¿Qué se debe configurar con el vag-com para que se fusionen coche y RNS-E?
Tienes mal codificado el navegador, tu coche no trae cargador de cd, ni telefono y lo tienes activado.
Coding: 0301217 - ESTE CREO QUE DEBE SER 0301111, ACABADO EN 5 SI TIENES VOLANTE MF, PERO MIRALO EN EL ARCHIBO QUE TE ENVÍO
Shop #: WSC 51462
Por este fallo no te preocupes, es culpa del amplificador de antena de la radio concert.
Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 106
Time Indication: 0
Date: 2008.07.15
Time: 13:26:16
vag_com_codigos.pdf
