pep3 Publicado 17 de Febrero del 2009 Denunciar Publicado 17 de Febrero del 2009 Espero aportar algo más de información, he encontrado lo siguiente, http://en.wikipedia.org/wiki/Secure_Digita...tibility_issues SD and SDHC compatibility issues During early 2007, the simultaneous availability of 4 GB SD cards compliant with later revisions of version 1.x of the SD specification but incompatible with readers based on earlier revisions of the specification, and of 4 GB SDHC cards, and incompatibilities between SD and SDHC caused confusion among consumers buying memory devices. Several Manufacturers such as Sandisk, Alcotek, Toshiba and Hynix have developed SDHC cards that are now fully compatible with the SDHC SD2.0 specification. SD and SDHC cards and devices have these compatibility issues : Devices that do not specifically support SDHC do not recognize SDHC memory cards. Nonetheless, some devices require only a firmware upgrade.[20] SDHC devices are backward compatible with SD memory cards.[20] Some manufacturers have produced 4 GB SD cards that conform to neither the SD2.0/SDHC spec nor existing SD devices.[21] File System: SD cards are typically formatted with the FAT16 file system, while SDHC cards are typically formatted as FAT32.[18] However, both types of cards can support other general-purpose file systems, such as UFS2/ext2 or the proprietary exFAT for example. Un saludo Responder
Ange Publicado 17 de Febrero del 2009 Denunciar Publicado 17 de Febrero del 2009 Espero aportar algo más de información, he encontrado lo siguiente, http://en.wikipedia.org/wiki/Secure_Digita...tibility_issues SD and SDHC compatibility issues During early 2007, the simultaneous availability of 4 GB SD cards compliant with later revisions of version 1.x of the SD specification but incompatible with readers based on earlier revisions of the specification, and of 4 GB SDHC cards, and incompatibilities between SD and SDHC caused confusion among consumers buying memory devices. Several Manufacturers such as Sandisk, Alcotek, Toshiba and Hynix have developed SDHC cards that are now fully compatible with the SDHC SD2.0 specification. SD and SDHC cards and devices have these compatibility issues : Devices that do not specifically support SDHC do not recognize SDHC memory cards. Nonetheless, some devices require only a firmware upgrade.[20] SDHC devices are backward compatible with SD memory cards.[20] Some manufacturers have produced 4 GB SD cards that conform to neither the SD2.0/SDHC spec nor existing SD devices.[21] File System: SD cards are typically formatted with the FAT16 file system, while SDHC cards are typically formatted as FAT32.[18] However, both types of cards can support other general-purpose file systems, such as UFS2/ext2 or the proprietary exFAT for example. Un saludo Ufff, pues "maltraduciendo" parece que tenemos razon ambos "bandos". Un saludote, Angel Responder
A4-TFSI Publicado 17 de Febrero del 2009 Denunciar Publicado 17 de Febrero del 2009 Se precisa de una actualización de tipo Software para que sea compatible con tarjetas de memoria de tipo SDHC, esto es así de claro. Esperamos entonces noticias de los últimos A4 (a partir de 2009) para determinar si vienen o no con la versión de software actualizada y así comprar la tarjeta adecuada. Responder
Luzitan Publicado 17 de Febrero del 2009 Denunciar Publicado 17 de Febrero del 2009 Sip pero ai tambien pone que tambien existen lectores de SD que a pesar de cualquier actualizacion no leerian SDHC asi que hasta que no lo pruebe alguien..... Responder
Ange Publicado 17 de Febrero del 2009 Denunciar Publicado 17 de Febrero del 2009 Sip pero ai tambien pone que tambien existen lectores de SD que a pesar de cualquier actualizacion no leerian SDHC asi que hasta que no lo pruebe alguien..... Siempre al quite amigo Luzitan, efectivamente a eso tambien me referia con mi respuesta. Un saludote y corta espera (espero), Angel Responder
jmdes1 Publicado 18 de Febrero del 2009 Autor Denunciar Publicado 18 de Febrero del 2009 Hola de nuevo Ninguno de los nuevos ha tenido oprtunidad de probarlo?? salu2 Responder
fjnavar Publicado 18 de Febrero del 2009 Denunciar Publicado 18 de Febrero del 2009 Esta tarde me dan el coche, lo prueba y os digo algo mañana Responder
fjnavar Publicado 19 de Febrero del 2009 Denunciar Publicado 19 de Febrero del 2009 Perdonar chicos pero hasta mañana no os podre decir nada de los de la sh hc Responder
Guest Publicado 19 de Febrero del 2009 Denunciar Publicado 19 de Febrero del 2009 Dinos tambien, por favor, el modelo de radio que llevas, y luego en el menu del coche/radio la version del soft y hardware. Gracias =D Responder
vigarcivi Publicado 19 de Febrero del 2009 Denunciar Publicado 19 de Febrero del 2009 De momento no hay actualizacion alguna, puesto que mi A4 tiene sobre 7 meses y solo se le ha hecho una actualizacion de software (respecto a la entrega de potencia), y llame la semana pasada para saber si habia alguna otra pendiente y me contestaron que no, que mi modelo era el ultimo el K no se que más y que no habia mas campañas de momento para este... (no se han detectado fallos de software de momento). Con respecto a lo de las tarjetas...haber si lo actualizan para que nos lea al menos 8 o 16 Gb...porque si mal no recuerdo no podemos pasar de 4 Gb no??? Responder
fjnavar Publicado 19 de Febrero del 2009 Denunciar Publicado 19 de Febrero del 2009 En e manual que tengo yo, me dieron el coche el 18/02/2009, es decir e pasado miercoles, pone SD 4 gb, yo he probado con una SDHC de 4gb SD2 y funciona correctamente, es decir, que yo creo que han actualizado algo de los lectores por parte de AUDI. Tengo una Radio Concert, no se deciros la versión de Software, si me decir como se mira o si se tiene que preguntar...... En otro Hilo de este foro a una persona que le funciona una SDHC de 32GB SD4 Este es el hilo: http://www.audisport-iberica.com/foro/inde...howtopic=181915 Un saludo. Responder
Luzitan Publicado 20 de Febrero del 2009 Denunciar Publicado 20 de Febrero del 2009 (editado) En e manual que tengo yo, me dieron el coche el 18/02/2009, es decir e pasado miercoles, pone SD 4 gb, yo he probado con una SDHC de 4gb SD2 y funciona correctamente, es decir, que yo creo que han actualizado algo de los lectores por parte de AUDI. Tengo una Radio Concert, no se deciros la versión de Software, si me decir como se mira o si se tiene que preguntar...... En otro Hilo de este foro a una persona que le funciona una SDHC de 32GB SD4 Este es el hilo: http://www.audisport-iberica.com/foro/inde...howtopic=181915 Un saludo. Eso es una noticia cojonuda!!! Por cierto, me parece que el que decia lo de la de 32 gb estaba bromeando :ranting2: Editado 20 de Febrero del 2009 por Luzitan Responder
jmdes1 Publicado 22 de Febrero del 2009 Autor Denunciar Publicado 22 de Febrero del 2009 En e manual que tengo yo, me dieron el coche el 18/02/2009, es decir e pasado miercoles, pone SD 4 gb, yo he probado con una SDHC de 4gb SD2 y funciona correctamente, es decir, que yo creo que han actualizado algo de los lectores por parte de AUDI. Tengo una Radio Concert, no se deciros la versión de Software, si me decir como se mira o si se tiene que preguntar...... En otro Hilo de este foro a una persona que le funciona una SDHC de 32GB SD4 Este es el hilo: http://www.audisport-iberica.com/foro/inde...howtopic=181915 Un saludo. Hola Yo probe este viernes en el concesionario una SDHC que me dejaron de un telefono y no la reconocia.....me puedes decir las caracteristicas de tu tarjeta (marca, referencia....), asi probare con mas calma una vez tenga el coche en casa. salu2 Responder
AL3 Publicado 22 de Febrero del 2009 Denunciar Publicado 22 de Febrero del 2009 Lo probaré en el coche nuevo de un amigo hoy por la mañana y es cuento. Voy a probar con una Kingston 4Gb SDHC. Responder
fjnavar Publicado 22 de Febrero del 2009 Denunciar Publicado 22 de Febrero del 2009 En e manual que tengo yo, me dieron el coche el 18/02/2009, es decir e pasado miercoles, pone SD 4 gb, yo he probado con una SDHC de 4gb SD2 y funciona correctamente, es decir, que yo creo que han actualizado algo de los lectores por parte de AUDI. Tengo una Radio Concert, no se deciros la versión de Software, si me decir como se mira o si se tiene que preguntar...... En otro Hilo de este foro a una persona que le funciona una SDHC de 32GB SD4 Este es el hilo: http://www.audisport-iberica.com/foro/inde...howtopic=181915 Un saludo. Hola Yo probe este viernes en el concesionario una SDHC que me dejaron de un telefono y no la reconocia.....me puedes decir las caracteristicas de tu tarjeta (marca, referencia....), asi probare con mas calma una vez tenga el coche en casa. salu2 Kingston 4Gb SDHC clase 2 (mira ver porque lo mismo si sube de clase es decir de velocidad a lo mejor no funciona porque le lector de la radio no esta preparado) Un saludo. Responder
