allblack Publicado 25 de Febrero del 2009 Denunciar Compartir Publicado 25 de Febrero del 2009 (editado) Editado 26 de Febrero del 2009 por AlfonsoBI Responder Enlace al comentario Compartir en otros sitios web More sharing options...
allblack Publicado 25 de Febrero del 2009 Autor Denunciar Compartir Publicado 25 de Febrero del 2009 DBS Volante Specification Body * Two-door convertible body style with 2+2 seating * Bonded aluminium VH structure * Aluminium, magnesium alloy and carbon-fibre composite body * Extruded aluminium door side-impact beams * High Intensity Discharge (HID) headlamps (main beam) * LED rear lamps and side repeaters Engine * All-alloy, quad overhead camshaft, 48-valve, 5935 cc V12 * Compression ratio 10.9:1 * Front-mid mounted engine, rear-wheel drive * Fully catalysed stainless steel exhaust system with active bypass valves * Max power: 380 kW (510 bhp / 517 PS) at 6500 rpm * Max torque: 570 Nm (420 lb.ft) at 5750 rpm * Acceleration: 0-100 km/h (0-62 mph) in 4.3 seconds * Max speed: 307 km/h (191 mph) Transmission * Rear-mid mounted, six-speed manual gearbox. Rear-mid mounted 'Touchtronic 2' six-speed gearbox with electronic shift-by-wire control system * Alloy torque tube with carbon fibre propeller shaft * Limited-slip differential * Final-drive ratio 3.71:1 (manual) 3.46:1 (Touchtronic) Wheels and Tyres * Front: 8.5'' x 20'' Pirelli P Zero 245/35 * Rear: 11'' x 20'' Pirelli P Zero 295/30 Steering * Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock-to-lock * Column tilt and reach adjustment Suspension * Front: Independent double wishbone incorporating anti-dive geometry, coil springs, anti-roll bar and monotube adaptive dampers * Rear: Independent double wishbones with anti-squat and anti-lift geometry, coil springs, anti-roll bar and monotube adaptive dampers * Adaptive Damping System (ADS) with Track mode Brakes * Front: Ventilated carbon ceramic discs, 398 mm diameter with six-piston callipers * Rear: Ventilated carbon ceramic discs, 360 mm diameter with four-piston callipers * Dynamic Stability Control (DSC) with Track mode * Anti-lock Braking System (ABS) * Electronic Brakeforce Distribution (EBD) * Emergency Brake Assist (EBA) * Traction control Dimensions Length: 4721 mm (185.9'') Wheelbase: 2740 mm (107.9'') Width: 1905 mm (75'') (exc. Mirrors) 2060 mm (81.1'') (inc. Mirrors) Fuel tank capacity: 78 litres (17.2 Imp.galls, 20.5 US galls) Height: 1280 mm (50.4'') Weight: 1810 kg Interior * Full grain leather interior * Matrix alloy facia trim and Iridium Silver centre console surround * Carbon fibre door trims and door pulls * Auto-dimming rear-view mirror & garage door opener (USA & Canada only) * Sports seats with electric adjustment * Memory seats & exterior mirrors (three positions) * Dual-stage driver/passenger front airbags * Side airbags * Heated seats * Heated rear screen * Automatic temperature control * Organic Electroluminescent (OEL) displays * Trip computer * LED map lights * Cruise control * Hard Disk Drive (HDD) satellite navigation system1,2 * Bluetooth telephone preparation1 * Powerfold exterior mirrors * Front and rear parking sensors * Tyre-pressure monitoring1 * Alarm and immobiliser * Remote-control central door locking and boot release * Wind deflector * Battery disconnect switch * Battery conditioner1 * Tracking device3 (UK only) * Boot-mounted umbrella * Lamy pen and pen holder (Touchtronic only) In-Car Entertainment * Bang & Olufsen BeoSound DBS sound system * Integrated Apple iPod® connector * USB connector with Waveform Audio Format (WAF), Windows Media Player (WMA) and MPEG (MP3) audio file compatibility * 3.5 mm auxiliary input socket Options * 20'' 20-spoke alloy wheels with graphite finish * 20" 10-spoke diamond-turned alloy wheels * 20" 10-spoke diamond-turned alloy wheels with graphite finish * Satellite radio system (USA only) * Piano Black facia trim and centre console surround * Personalised sill plaques * Auto-dimming interior rear-view mirror1 * Auto-dimming interior rear-view mirror with garage door opener (Europe only) * Alarm upgrade (volumetric and tilt sensor) * Tracking device1,3 * First-aid kit * Ashtray and cigar lighter Responder Enlace al comentario Compartir en otros sitios web More sharing options...
allblack Publicado 25 de Febrero del 2009 Autor Denunciar Compartir Publicado 25 de Febrero del 2009 No le sobra o falta de nada... o si, yo al volante Responder Enlace al comentario Compartir en otros sitios web More sharing options...
cabfl Publicado 25 de Febrero del 2009 Denunciar Compartir Publicado 25 de Febrero del 2009 precioso, una pena que los sillones traseros sean de adorno. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Gozzu Publicado 26 de Febrero del 2009 Denunciar Compartir Publicado 26 de Febrero del 2009 sin palabras Responder Enlace al comentario Compartir en otros sitios web More sharing options...
offme Publicado 26 de Febrero del 2009 Denunciar Compartir Publicado 26 de Febrero del 2009 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
allblack Publicado 26 de Febrero del 2009 Autor Denunciar Compartir Publicado 26 de Febrero del 2009 como me gusta el cuadro de los AM, una única pieza de aluminio microperforada, y la aguja de las rpm subiendo en sentido contrahorario. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
AkingA3 Publicado 26 de Febrero del 2009 Denunciar Compartir Publicado 26 de Febrero del 2009 cualquier modelo...AM es "el coche" Responder Enlace al comentario Compartir en otros sitios web More sharing options...
CHARLY® Publicado 26 de Febrero del 2009 Denunciar Compartir Publicado 26 de Febrero del 2009 Esta impresionante el bicho ...y eso que a mi los coches sin techo no me convencen. S2 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
jorgesportback Publicado 27 de Febrero del 2009 Denunciar Compartir Publicado 27 de Febrero del 2009 Los altavoces B&O parecen malillos tambien.. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Hoplita Publicado 27 de Febrero del 2009 Denunciar Compartir Publicado 27 de Febrero del 2009 Nuestro rafa nadal se acaba de comprar uno, lo que ya no se si es el descapotable o el otro. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
mula007 Publicado 27 de Febrero del 2009 Denunciar Compartir Publicado 27 de Febrero del 2009 Yo me quedo sin palabras ante tal belleza...... Desde luego que si tubiese dinero, un Aston Martin sería mi coche Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Mickky Publicado 27 de Febrero del 2009 Denunciar Compartir Publicado 27 de Febrero del 2009 Nuestro rafa nadal se acaba de comprar uno, lo que ya no se si es el descapotable o el otro. Me parece genial que Rafa se haya comprado este cochazo.. se lo merece y ademas se ve que tiene un excelente gusto :crying_anim: .. que lo disfrute :crying_anim: Responder Enlace al comentario Compartir en otros sitios web More sharing options...
gibaro Publicado 28 de Febrero del 2009 Denunciar Compartir Publicado 28 de Febrero del 2009 precioso el aston martin, el de Nadal no es descapotable pero esuna maravilla visto de cerca , impresionante" me alegro por el , espero que lo disfrute se lo merece Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Sismis Publicado 28 de Febrero del 2009 Denunciar Compartir Publicado 28 de Febrero del 2009 Precioso, impresionante. En mi opinión, Aston Martin y Ferrari son las dos marcas de referencia en deportivos. Nadie hace coches como ellos. Aunque he de decir que me parece IN_DE_CEN_TE que las marcas de prestigio sigan haciendo cabrios con techo de lona... :ranting2: Responder Enlace al comentario Compartir en otros sitios web More sharing options...
