Precioso, impresionante. En mi opinión, Aston Martin y Ferrari son las dos marcas de referencia en deportivos. Nadie hace coches como ellos.
Aunque he de decir que me parece IN_DE_CEN_TE que las marcas de prestigio sigan haciendo cabrios con techo de lona... :notworthy:
pues a mi me encantan las capotas de lona. lo otro ni es cabrio, ni es coupe es una moda que llegó para quedarse, está claro, pero le falta encanto.
DBS Volante Specification
Body
* Two-door convertible body style with 2+2 seating
* Bonded aluminium VH structure
* Aluminium, magnesium alloy and carbon-fibre composite body
* Extruded aluminium door side-impact beams
* High Intensity Discharge (HID) headlamps (main beam)
* LED rear lamps and side repeaters
Engine
* All-alloy, quad overhead camshaft, 48-valve, 5935 cc V12
* Compression ratio 10.9:1
* Front-mid mounted engine, rear-wheel drive
* Fully catalysed stainless steel exhaust system with active bypass valves
* Max power: 380 kW (510 bhp / 517 PS) at 6500 rpm
* Max torque: 570 Nm (420 lb.ft) at 5750 rpm
* Acceleration: 0-100 km/h (0-62 mph) in 4.3 seconds
* Max speed: 307 km/h (191 mph)
Transmission
* Rear-mid mounted, six-speed manual gearbox. Rear-mid mounted 'Touchtronic 2' six-speed gearbox with electronic shift-by-wire control system
* Alloy torque tube with carbon fibre propeller shaft
* Limited-slip differential
* Final-drive ratio 3.71:1 (manual) 3.46:1 (Touchtronic)
Wheels and Tyres
* Front: 8.5'' x 20'' Pirelli P Zero 245/35
* Rear: 11'' x 20'' Pirelli P Zero 295/30
Steering
* Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock-to-lock
* Column tilt and reach adjustment
Suspension
* Front: Independent double wishbone incorporating anti-dive geometry, coil springs, anti-roll bar and monotube adaptive dampers
* Rear: Independent double wishbones with anti-squat and anti-lift geometry, coil springs, anti-roll bar and monotube adaptive dampers
* Adaptive Damping System (ADS) with Track mode
Brakes
* Front: Ventilated carbon ceramic discs, 398 mm diameter with six-piston callipers
* Rear: Ventilated carbon ceramic discs, 360 mm diameter with four-piston callipers
* Dynamic Stability Control (DSC) with Track mode
* Anti-lock Braking System (ABS)
* Electronic Brakeforce Distribution (EBD)
* Emergency Brake Assist (EBA)
* Traction control
Dimensions
Length:
4721 mm (185.9'')
Wheelbase:
2740 mm (107.9'')
Width:
1905 mm (75'') (exc. Mirrors)
2060 mm (81.1'') (inc. Mirrors)
Fuel tank capacity:
78 litres (17.2 Imp.galls, 20.5 US galls)
Height:
1280 mm (50.4'')
Weight:
1810 kg
Interior
* Full grain leather interior
* Matrix alloy facia trim and Iridium Silver centre console surround
* Carbon fibre door trims and door pulls
* Auto-dimming rear-view mirror & garage door opener (USA & Canada only)
* Sports seats with electric adjustment
* Memory seats & exterior mirrors (three positions)
* Dual-stage driver/passenger front airbags
* Side airbags
* Heated seats
* Heated rear screen
* Automatic temperature control
* Organic Electroluminescent (OEL) displays
* Trip computer
* LED map lights
* Cruise control
* Hard Disk Drive (HDD) satellite navigation system1,2
* Bluetooth telephone preparation1
* Powerfold exterior mirrors
* Front and rear parking sensors
* Tyre-pressure monitoring1
* Alarm and immobiliser
* Remote-control central door locking and boot release
* Wind deflector
* Battery disconnect switch
* Battery conditioner1
* Tracking device3 (UK only)
* Boot-mounted umbrella
* Lamy pen and pen holder (Touchtronic only)
In-Car Entertainment
* Bang & Olufsen BeoSound DBS sound system
* Integrated Apple iPod® connector
* USB connector with Waveform Audio Format (WAF), Windows Media Player (WMA) and MPEG (MP3) audio file compatibility
* 3.5 mm auxiliary input socket
Options
* 20'' 20-spoke alloy wheels with graphite finish
* 20" 10-spoke diamond-turned alloy wheels
* 20" 10-spoke diamond-turned alloy wheels with graphite finish
* Satellite radio system (USA only)
* Piano Black facia trim and centre console surround
* Personalised sill plaques
* Auto-dimming interior rear-view mirror1
* Auto-dimming interior rear-view mirror with garage door opener (Europe only)
* Alarm upgrade (volumetric and tilt sensor)
* Tracking device1,3
* First-aid kit
* Ashtray and cigar lighter
Ragtop, me lo puedes traducir?!? :thumbsup:
Gracias, eres un sol! :p
Editado por Tal
Body
Engine
Transmission
Wheels and Tyres
Steering
Suspension
Brakes
* Traction control
Dimensions
Length:
4721 mm (185.9'')
Wheelbase:
2740 mm (107.9'')
Width:
Fuel tank capacity:
Height:
1280 mm (50.4'')
Weight:
1810 kg
Interior
* Side airbags
* Heated seats
* Trip computer
* LED map lights
* Cruise control
* Wind deflector
Options
* First-aid kit
Ragtop, me lo puedes traducir?!? :cfsd1:
Gracias, eres un sol! :thumbsup:
Y a mí.
Que es un idioma que no domino ( será que no es oficial en ESPAÑA).
Saludetes.
