Hola a todos, vereis se me enciende desde hace 2 semanas el pilotito naranja fijo con forma de motor, en el manual me pone que es el sistema de control de emisiones de escape, le he pasado el vagcom y creo que es el error que sale en la direccion 01 engine, os pongo la lista que ha sacado:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 5934
Coding: 00003
Shop #: WSC 63251
WAUZZZ8E44A216982 AUZ6Z0D0021826
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04255
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AA
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63251
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 00000
2 Faults Found:
01494 - Bulb for Parking Lamps: Left (M1)
57-00 - Electric Circuit Failure
01498 - Bulb for Parking Lamps: Right (M3)
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01042
Shop #: WSC 63251
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 03101
Shop #: WSC 07721
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1412
Coding: 08058
Shop #: WSC 63251
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63251
End -------------------------------------------------------
El error que creo que es (17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus) he estado investigando por ahi y dicen que es el sensor que controla la temperatura del agua refrigerante. Mis preguntas es sabeis o creeis que sera eso? que otra cosa podria ser? os ha pasado algo parecido?
El coche es un a4 b6 1.9 tdi 130 quattro del 2004.
Gracias por adelantado.
Hace unos meses me paso a mi tambien lo mismo,el error era el mismo que a ti
me cambiaron un sensor de la temeratura del agua,el precio de lo que me costo no te lo se decir porque me entro en garantia
Salu2! :huh:
Pues entonces probare a cambiarselo, he leido por ahi que sale sobre unos 30 euros, Gracias Orenes.
De todas formas si alguien mas le ha pasado algo similar con esta lucecita del cuadro ya sabeis, soy todo oidoss jeje
Gracias otra vez a todos.
La lucecita, no siempre significa fallo de emisión.
De todas formas, no se qué más quieres preguntar cuando ya aportas tú mismo el análisis con el Vag Com y, está claro: el fallo está en el módulo del motor y es el sensor de temperatura del líquido refrigerante que te da lecturas intermitentes
1 Fault Found:
Readiness: N/A
Como bien te dice Orenes, el arreglo es sencillísimo a parte de que, es un error muy común en los motores del Grupo VAG. Creo que el sensor no cuenta ni 12 € y, la junta, son nosecuantos céntimos.
Tienes bricos en la sección de los bricopost (en el subforo de mecánica) que te explican como cambiarlo tú mismo.
SALUDOS
Si el error era el unico que salia, pero como en el manual ponia lo de las emisiones por eso no estaba seguro del todo. Buscare el brico si tengo timepo y sino lo llevare al taller de un amigo que no creo que me cobre mucho, gracias a todos otra vez.
