os pongo lo que me sale cuando le doy a auto scan.
Thursday,16,April,2009,21:37:35:26365
VCDS Version: Release 805.0
Data version: 20080730
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
Mileage: 181580km/112828miles
Address 01: Engine Labels: Redir Fail!
Part No: 4D0 907 558 D
Component: 4,2L V8/4V MOTR AT D01
Coding: 05273
Shop #: WSC 00000
6 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-00 - -
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-00 - -
17605 - Oxygen (Lambda) Sensor Heater Circuit: B2 S1: Electrical Malfunction
P1197 - 35-00 - -
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D00
Shop #: BB 24334
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4D0 820 043 K
Component: D2-KLIMAVOLLAUTOMAT D05
Coding: 00080
Shop #: WSC 02324
2 Faults Found:
00801 - A/C Refrigerant High Pressure Switch (F118)
30-10 - Open or Short to Plus - Intermittent
01592 - Air Quality Sensor (G238)
57-10 - Electric Circuit Failure - Intermittent
Address 15: Airbags Labels: Redir Fail!
Part No: 4D0 959 655 H
Component: Airbag 7 Audi 050C
Coding: 00225
Shop #: WSC 02324
No fault code found.
Address 17: Instruments Labels: 4D0-919-033-MYW.lbl
Part No: 4D0 919 033 AC
Component: D2-KOMBIINSTRUMENT D52
Coding: 16083
Shop #: WSC 02324
Address 18: Aux. Heat Labels: None
Part No: 4D0 265 105 E
Component: Standheizung Benzin D48ˆ
Coding: 00001
Shop #: WSC 00000
Address 25: Immobilizer Labels: None
Part No: 4B0 953 234
Component: IMMO AUZ9Z0W2016672 D03
Coding: 00000
Shop #: WSC 64335
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D05
Coding: 13130
Shop #: WSC 02324
4 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 8L0 951 173
Component: Innenraumueberw. D04
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D000
Coding: 00008
Shop #: WSC 02324
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186
Component: Radio 0001
Coding: 00115
Shop #: WSC 02324
1 Fault Found:
00854 - Radio Display Output in dash Panel insert
49-10 - No Communications - Intermittent
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A8 RDW D16
Coding: 01108
Shop #: WSC 02324
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 BH
Component: AG5 01L 4.2l4V RdW 1313
Coding: 00001
Shop #: WSC 02324
1 Fault Found:
17087 - Brake Switch (F): Electrical Malfunction
P0703 - 35-00 - -
End ---------------------------------------------------------------------
La compresión asi tal cual me parece que no, no hay sensores de presión en los cilindros. Podrías detectar fallo en algún cilindro por los sensores de picado, por los sensores de ángulo de giro, ... pero no se me ocurre como averiguar la compresión.
¿Sospechas de algo?
Hola, no se lo que es pero noto una falta de respuesta en el acelerador y al meter acelerador a tope baja de marchas hasta ponerse en 5000rpm sin avance alguno simplemente sonido de motor, hasta que sube una marcha y entonces es cuando avanza, pero me da la sensacion de que no como debiera o mejor dicho no lo suave que debiera. Crees que puede ser por algunos de los fallos que aun borrando salen otra vez. Un saludo
Si el coche aumenta de rpm's no lo hace en velocidad, es que te está patinando el embrague, algo parecido me pasó con un A6 automático, pero fue de repente y en menos de 2Kmts me dejó tirado, me quedé sin caja auomática y 3000€ del ala... ;)
  • 3 años más tarde...
hola buenas tardes companheros soy de portugal e no hay manera de reparar el climatronic, de un momento pra otro el buton de gielo no me fixa yo pense que fuera la consola del climatronic a la vida pero no eh testado en una carrinha igual que la mia e va buena, entonces ligue el vag com e se me aparece el error 0801 - A/C Refrigerant High Pressure Switch (F118)
30-10 - Open or Short to Plus - Intermittent, e no hay manera de saber de donde va, aguien que tuvera el mismo error se me poderia decir el mal de mi carripana, saludos
