Pulsa los botones AM y ARI-Z a la vez hasta que te aparezca en la pantalla "CODE". Suelta los botones y te aparecerá el número 1000.
Ahora con los botones numericos del 1 al 4 puedes ir modificando las decenas, las centenas, etc.. Cuando tengas tu número metido vuelves a pulsar AM y ARI-Z para meter el codigo.
Asegurate que el codigo que metas sea el correcto, ya que tienes una serie de intentos muy limitados (de 2 a 3) y luego se bloquea "de verdad"..
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving.
Entering anti-theft code
The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
Turn on radio. The radio display shows "SAFE".
Press the AM and ARI-Z buttons simultaneously and hold until "CODE" shows on the display. Release the buttons. After a pause, "1000" is displayed. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
Once the code shown on the display is correct, press the AM and ARI-Z buttons simultaneously and hold until the word "CODE" appears in the display, then release the buttons.
The radio should unlock and be usable shortly afterwards.
If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display.
On the "soft-coded" version of the Delta radio, if an incorrect code is entered again, you can attempt to enter the code two more times. After the third attempt with wrong code, the radio will be locked and not accept even the correct code. You should contact your Audi dealer.
On "hard-coded" versions of the Delta radio, if an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
If you lose your radio code, contact your Audi dealer.
Como puedes ver hay dos modelos de seguridad segun sea Soft o hard code, pero intenta no pasar de tres intentos. Si es hard, despues de una hora puedes intentar de nuevo.
