Buenas a todos...
Alguien me puede pasar el enlace del 2010.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######NYAT9w3Uwndm836+pQkxGbCvIYRPcq
F/R7TVvnFePv2okuKeS3bp4YKNcd1SB4GWIhkOoQrBfIfTxpRIMgmFgu/HRB1eO9Zr6TyuRALkJ7
kar9v57Lx72p5eKGjZGAPfWi2Kf/mE9vrgnmVeGdSqSILrLfDupPwOAv5FlCnkCRREZ7xhkCyxeF
gJBm/PzK9xj5gkUDNd5Ui7w0XARxzJVwn4g9d1iKfRH6peOPP13Bq0MHq7RhnypWOYBLCKBKJblm
UY1+Tf0dS8XMop9GyX24xa1H3RiCX7Kn0OPiNG1iIkgtUE24Gzvx4EbqBgfkHyw9b3zRixkW7nF5
Yqg14GWKqRxX++Vus8WfUMLvgfVPuHzs2PNY7kU95a2L5o6ZZ4Ej/XGzAKC9CR8EurQk+fSvOuOV
6FDxRu6+C2k5xCPOwfXkRzkVQjw7Xx2HIEB757Cr9qMnJTrvg2pDi0n3blTm572Lpjf174F3Hpuc
sEDrYebCL0PExWn9NORfpzlRkBqfc12MhzWKRn2WGXW8NUwVDKprd8aK7/6e4k5jhhq5qsNKT/vw
Yky5zlqvBjDNhTTToVP+7cobVrVeN/Q98OXZgYJCtGRLyNJMBq//r+PFjaURf8kTe8BiS7c7HaB5
EEeGruxBVyTV6p6k3Oaj+Q1le51If7ehta4PfQo0dgCtuH4djRNjl19URnuUZZyeBjqZ1EqsUQ5a
N9NbL0/S9I0o0ySEze1CBa5PCutkvsYumgUPe4RH5eMfJSUuZGqbyRdjVNWzLVUYUDnpmzfj4P2O
z9z9L/XMquI6cTOlli5H7hQymMMoxADf/yZPUjAdZwmm3pHcV5PzesfsDlodakikDfKR7E3/qq0t
5dnBB0QKWnfJHefZppMYQXXhD3Ln0crUexeTVWQi+uEXYm0ZPm3W1QmsPGzPynS8zcbjIDTeWbCV
Jikt9dFJXxyOxD24IMI9DsFA0uHswwckNq9CFQOCAWGN3rTjYDWCOvnLt5f+Hd+LlD9cyebL/T/0
9v8B1NTQjXpNXgVX/dfdwu6rqnD/QrzzUL924L257RKeCLVkn6pccIlqJP3FXPFvoKgKoU3KqglN
oGlPf1ZG9boiNGbi3uHK8LpaxFWLkWwL5X1H6Cg7fCdQMWKru3EOeUYJxpj+vaodQ3zNNY+wpcdV
8AEOy3p6J8bMGAgtumuJb24nY3GdRzMsUsHN2MvgV07eWxNc6llnfJT3xQZ4Wgt6QEAGFvWIBqzO
FNVjQrCi4HjRy+nMfNJpuuwAHjbtUMd+zU65WfY+ZhZfwdmGjloQURyBXG/YEyleloS1IAGZPGr7
OIF5CAZOQPiUedZYncEzbplmL62L5Es/y0Yk118fxgPquvdaG4xyq1HE3ZgELV2z1cbxXcDHBVfc
1rHTaABetXNDfY3ZI1l9hSIBczXr06g7fLOfkSoKeFgrOoiNn0Lmd0rte4bJGgC2V/rHuj+D///c
J9jZtwewxJT+ndS3USK81rsL/2dCMyvIYOPMbhC2VvroafMm+K83lKIzkKO9ko8RNCkAcjsK6ZNJ
/1J6gvF63z1wUOIL6wJH4rgBRlT37BMLhe/lM5aKCLLppIsbe4pVsQbFlFN1kUbav123GjZuDuvp
6pmt8L3z/kQGDcLFlzG+4fjfNLq+8j04nnKyZY/4cE2lcotvS8nucSqlJ+/6LKhnsDQW5V31/GMe
sAwFs0O8Cm4TSidVpA7oUhRB8Ej1jI/mt3disDJ8022AK60G3zkfWLVLoe0ba/4Ok8UHX6B5yHQE
Af0ZRbGvmjUNIDz4ujCPO4C/h+1gb/CJkYYPQJNnhfvHGRBolbM431EQiLeaeAZsW+/LL0hCeA==Q1UyOHRRaGpjdVgxODN6djJPWlg0Yiswd0RYRG13SXpQTERnY2FBOS9GVmxWRXFPWUVld2F
Uk4wY3cxTThWYQ==
Tan solo SELECCIONA TODO el texto raro que aparece antes de esta linea...
dale a COPIAR, crea un archivo "txt" y pegalo dentro y guardalo
despues tan solo debes renombrar el archivo "txt" y darle la extension "dlc"
te quedaria por ejemplo asi:
Atlas2010.dlc
y ya esta... lo abres con el JDownloader... si no lo tienes buscalo por ahi es gratis y va de coña para descargas de servidores tipo Rapidshare, Megaupload, etc...
Lo tuve que renombrar y por eso sale asi... ya que no me dejaba subirlo de otra forma
Te saldran añadidos para descarga 7 archivos "rar"
Unos 490 Mgs comprimido
Como grabarlo lo tienes arriba perfectamente explicado.. sigue esos pasos y te ira a la 1ª
  • Respuestas 386
Posted Images
EDITADO.
Esta es la última vez desde el equipo de moderación te pedimos que leas y cumplas las normas del foro. Como bien te dice el compañero As..Quattro:
Quedan terminantemente prohibidos:
- Los links que faciliten las descargas directas a cualquier material protegido por copyright.
Bueno pues como se me esta llenando el buzon pues aqui os pongo el enlace del Megauloap para que os lo descargeis . Cuando lo grabeis ir comentando si funcionan o no . Gracias
[url="http://www.NoSePuedenPonerEnlacesDeDescargaDirecta.com[/url]
pero esto vale para el navegador del maletero el del fis tengo un a4 2004 me valdria
1º - No se puede, como pone arriba del todo, poner enlaces a descargas directas que esten protegidas por copyrigth.... aunque haya sido otro el del post.
2º - Saca el disco del Navegador y mira que sistema lleva.. si es cd o DVD , etc... sino es imposible ayudarte con garantias
  • 1 mes más tarde...
  • 2 meses más tarde...
