pakorro1 Publicado 7 de Octubre del 2009 Denunciar Publicado 7 de Octubre del 2009 esto es lo q me ha salido alguin me lo puede descifrar gracias Chassis Type: 4B - Audi A6 C5 Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56 Address 01 ------------------------------------------------------- Controller: 038 906 019 CF Component: 1,9l R4 EDC 0000SG 1414 Coding: 00002 Shop #: WSC 02325 WAUZZZ4B72N073964 AUZ7Z0A1975458 3 Faults Found: 19464 - Camshaft Position Sensor (G40): Signal Out of Range P3008 - 00-00 - - 17965 - Charge Pressure Control: Positive Deviation P1557 - 35-10 - - - Intermittent 17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus P1256 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 4B0 614 517 G Component: ABS/ESP front 1728 Coding: 06255 Shop #: WSC 02325 No fault code found. Address 08 ------------------------------------------------------- Controller: 4B0 820 043 AA Component: A6-Klimavol Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 4B0 920 933 M Component: KOMBI+WEGFAHRS. VDO D09 Coding: 00140 Shop #: WSC 00012 WAUZZZ4B72N073964 AUZ7Z0A1975458 No fault code found. Address 35 ------------------------------------------------------- Controller: 4B0 962 258 K Component: Zentralverrieg.,DWA D35 Coding: 04686 Shop #: WSC 08017 7 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00956 - Key 2 09-10 - Adaptation Limit Surpassed - Intermittent 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01562 - Right Rear Door 61-10 - Won't De-Safe - Intermittent Address 45 ------------------------------------------------------- Controller: 4B0 951 178 A Component: Innenraumueberw. D04 Coding: 00101 Shop #: WSC 02325 No fault code found. Address 56 ------------------------------------------------------- Controller: 4B0 035 152 C Component: chorus II GRO 0007 Coding: 00002 Shop #: WSC 02325 No fault code found. End ------------------------------------------------------- Responder
ferchir Publicado 9 de Octubre del 2009 Denunciar Publicado 9 de Octubre del 2009 http://www.audisport-iberica.com/foro/inde...st&id=29166 aqui puedes comprobar los codigos de errores. un saludo Responder
Manu Lorenzo Publicado 10 de Octubre del 2009 Denunciar Publicado 10 de Octubre del 2009 Chungo ehhhhhhhh, muy chungo todo na, no hay nada grave tranki mirate sobretodo los 3 errores de engine, los sensores G40 y G62 Borra los errores, anda un par de días con él y vuelve a pasar el test, quizas no vuelvan a aparecer y ha sido por algo puntual Salu2 Responder
