Bueno, pues despues de la compra del cable, de instalarlo y todo perfecto, llega la hora del hacer algo. He hecho un autoscan, que de momento es lo único que me da menos miedo, y me ha salido todo esto y no tengo ni idea de que es, si es algo mal, si se pueden resetear o de que hacer.
VCDS Version: Release 805.0
Data version: 20080625
Thursday,15,October,2009,02:43:19:26365
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 77
VIN: WAUZZZ4F05N039212 Mileage: 117620km/73085miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
Component: 3.0L V6TDI 0000AG 0020
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 02334 785 00200
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0080
Revision: --H01--- Serial number: 0046527
Coding: 0000001
Shop #: WSC 02325 785 00200
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004488
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300053810
Coding: 0000003
Shop #: WSC 00347 572 91922
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 730 F HW: 4E0 035 729
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 350H+047529989
Coding: 0000004
Shop #: WSC 00347 572 81629
Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
1 Fault Found:
00658 - Control Head
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 F
Component: KLIMABETAETIGUNGH04 0110
Revision: 00000023 Serial number: 00000000045609
Coding: 0000150
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0012121
Shop #: WSC 02335 785 00200
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0040
Coding: 00141886
Shop #: WSC 02335
1 Fault Found:
01498 - Bulb for Parking Lamps; Right (M3)
011 - Open Circuit
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6003493
Shop #: WSC 00000 000 00000
1 Fault Found:
02446 - Disk Drive Mechanical Malfunction
014 - Defective - Intermittent
Address 15: Airbags Labels: 4F0-910-655.lbl
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 33 AIRBAG AUDI8RH28 0250
Revision: 04H28000 Serial number: 0037LD03E4G
Coding: 0013107
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025042260072
Coding: 0002011
Shop #: WSC 02323 785 00200
Part No: XXXXXXXXXXX
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 S
Component: KOMBIINSTR. M73 H08 0630
Revision: 00200000 Serial number: 4H+30GU74
Coding: 0001143
Shop #: WSC 50741 143 61874
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008047310172
Coding: 6CFE73C41B3104
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 C HW: ÿÿÿÿÿÿÿÿÿÿÿ
Component: MNS ECE ÿÿÿ 0350
Revision: ÿÿÿÿÿÿÿÿ Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Shop #: WSC 131071 1023 2097151
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: 5
Coding: 0000618
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000614690000
Coding: 0139397
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 C HW: 4F0 035 223
Component: Amp.-ASK H09 0320
Revision: 14S00001 Serial number: 02907040025830
Coding: 0000008
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000013358
Coding: 0001003
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: g
Coding: 0000618
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 A
Component: Dynamische LWR H01 0010
Coding: 0000003
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0560
Revision: 00000000 Serial number: 352HR047550646
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000046092
Part No: 4F0 915 105 D
Component: von VA0 1408120143
Coding: 344630393135313035442056413031343038313230313433
Shop #: WSC 00000 640 00290
1 Fault Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0000042
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0000042
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0770
Revision: 00000002 Serial number: T2AUD3060706G0
Coding: 0000004
Shop #: WSC 02313 785 00200
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
End ---------------------------------------------------------------------
Por favor, decidme algo, que no tengo ni idea de todo esto, y no se si es importante o no.
Gracias. :ph34r::unsure:
dale a clear all dtcs ,borrara los errores si le vuelves a escanear y se repiten ves mirando uno a uno en rosstech wiki o en el pdf que hay en el foro con los errores, que es mas completo. un saludo
