VCDS Version: Beta 812.4
Data version: 20090214
Tuesday,28,April,2009,19:14:31:26365-----FECHA TRUCADA POR LO TODOS YA CONOCIDOS
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 BB
Component: 1,9l R4 EDC 0000SG 2809
Coding: 00002
Shop #: WSC 06435
1 Fault Found
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 M
Component: A3 KLIMAVOLLAUTOMAT_D77
Coding: 03143
Shop #: WSC 06435
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 G
Component: Airbag Front+Seite 2008
Coding: 00104
Shop #: WSC 06435
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 900
Component: KOMBI+WEGFAHRS. M73 D16
Coding: 00040
Shop #: WSC 46701
Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0Y8073141
Ident.-Nr. Wegfahrs.:AUZ5Z0Y8073141
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 L
Component: ZV-Pumpe D14
Coding: 00000
Shop #: WSC 06435
2 Faults Found
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 152 B
Component: Radio 0001
Coding: 00201
Shop #: WSC 06435
End -----------------------------------------------------
Coding: 00002
Shop #: WSC 06435
1 Fault Found
Readiness: N/A
Coding: 13304
Shop #: WSC 06435
Coding: 03143
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
Coding: 00040
Shop #: WSC 46701
Part No: Ident
No Faults Found
Coding: 00000
Shop #: WSC 06435
2 Faults Found
35-00 - -
Coding: 00201
Shop #: WSC 06435
17965/P1557/005463
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 17965/P1557/005463 - Charge Pressure Control: Positive Deviation
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
