Bueno, kantusjack,
Esto es lo que he conseguido despues de quitar los errores y hacer unos km, como deciais, el mas significativo, es el (19-CAN Gateway),
y ha quedado asi
VCDS Version: Beta 812.4
Data version: 20090214
Sunday,01,February,2009,18:58:57:26365
Chassis Type: 4F0
Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 61
62 72 76
VIN: WAUZZZ4F26N145792 Mileage: 154450km/95970miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Not registered 0011
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 HS HW: 028 101 255 7
Component: R4 2,0L EDC G000SG 9673
Revision: --H02--- Serial number:
Coding: 0000072
Shop #: WSC 00045 572 80634
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H05 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02325 785 00200
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10604000342710
Coding: 0000001
Shop #: WSC 00435 572 71847
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350BV067648288
Coding: 0000004
Shop #: WSC 00000 000 00000
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 M
Component: KLIMABETAETIGUNGH05 0170
Revision: 00000030 Serial number: 00000030091822
Coding: 0000020
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0002121
Shop #: WSC 02335 785 00200
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH11 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8047109
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 43 AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0CTT1T
Coding: 0013363
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026060160061
Coding: 0002041
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 931 B
Component: KOMBIINSTR. M73 H17 0660
Revision: 00100000 Serial number: 4PT37RP16
Coding: 2308143
Shop #: WSC 00045 572 75281
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 130080612300AD
Coding: 6CEE73C41B0104
Shop #: WSC 02334 785 00200
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 6
Reset counter: 126
Mileage: 153192 km
Time Indication: 0
Date: 2009.12.27
Time: 09:46:31
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: a0
Coding: 0000522
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 F HW: 4F0 907 289 F
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01010197990000
Coding: 0131205
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H10 0350
Revision: 33S00001 Serial number: 02301060211122
Coding: 0000008
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000116230
Coding: 0001004
Shop #: WSC 02323 785 00200
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: ”b0
Coding: 0000522
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 A HW: 4F0 907 801
Component: EPB CA3C0040 H03 0040
Revision: --H03---
Coding: 0000111
Shop #: WSC 02324 785 00200
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 C
Component: Dynamische LWR H01 0010
Coding: 0000003
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 352BQ067619931
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000005971
Shop #: WSC 00145 572 56436
Part No: 4F0 915 105 C
Component: von VA0 1601131034
Coding: 344630393135313035432056413031363031313331303334
Shop #: WSC 00000 384 00290
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 795 F
Component: TSG HL H21 0050
Coding: 0000002
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 794 F
Component: TSG HR H21 0050
Coding: 0000002
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 11720520803263
Coding: 0201006
Shop #: WSC 00400 176 80736
1 Fault Found
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 10
Reset counter: 156
Mileage: 154116 km
Time Indication: 0
Date: 2010.01.08
Time: 11:40:04
End ---------------------------------------------------------------------
Mañana lo traere a la revision, y le dejare caer algo de las desconexiones de bateria y de mas, seguramente ellos podran codificar ese modulo sin problemas (IMAGINO),
Gracias por vuestras respuestas.
Y tu podrías hacerlo.
Si no estoy equivocado tienes que decirle a la Gateway (19) que tienes el Parking Aid (76). Es el bit 7 del byte 00 que lo tienes sin poner. Por eso te dice que esta mal codificado.
Perdona mi ignorancia,
¿que seria, entrar en 19can gateway y después?
En que línea? Si me puedes especificar un poco mas
perdón por lo pesado que soy,
de esa forma ya estaría resuelto supongo
un saludo
Modulo 19
Coding
Long Coding Helper
En la pantalla del byte 00, el bit 7 lo tienes que marcar (si pone 76 Park Assist)
Cierras y verás una nueva codificación debajo.
DO IT.
Mira si tiene errores y si los tiene bórralos.
Modulo 19
Coding
Long Coding Helper
DO IT.
Gracias, mañana por la mañana lo probare, y ya os cuento,
una vez mas os agradezco mucho lo que hacéis en bien de todos
saludos
Bueno (FAMILIA) parece que ya esta solucionado, hay que ver lo que aprendes por aqui,
Pensaba que en cada concesionario tendria que haber una persona como vosotros, pero pensandolo bien, seria una "RUINA", jajajaja,
si llego al conce, con los fallos que me marcaba el Vag, seguro que hubiera salido muy mal parado, hubieran empezado a cambiar piezas "DEFECTUOSAS", y se hubieran quedado tan panchos,
Una vez mas muchas gracias a todos.
Sunday,01,February,2009,09:08:04:26365
Chassis Type: 4F0
62 72 76
VIN: WAUZZZ4F26N145792 Mileage: 154460km/95976miles
19-CAN Gateway -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Coding: 0000072
Coding: 0020855
Coding: 0000001
Coding: 0000004
Coding: 0000020
Coding: 0002121
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Coding: 0013363
Component: Lenks‰ulenmodul H07 0230
Coding: 0002041
Coding: 2308143
Coding: ECEE73C41B0104
Coding: 0000522
Coding: 0131205
Coding: 0000008
Coding: 0001004
Revision: 00000000 Serial number: îb0
Coding: 0000522
Revision: --H03---
Coding: 0000111
Coding: 0000003
Coding: 0000001
Component: von VA0 1601131033
Coding: 344630393135313035432056413031363031313331303333
Coding: 0000002
Coding: 0000002
Coding: 0201006
