arrebuscando bellotas por la red veo este autoscan:
Chassis Type: 8T0
Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
52 53 55 56 65 6C 77
VIN: WAUDK78T18Axxxxxx Mileage: 1050km/652miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CALA) Labels: TEST-01.lbl
Part No SW: 8T0 907 559 B HW: 8T0 907 559 B
Component: 3.2 SIMOS8.2 H04 0001
Revision: --------
Coding: 01140009180F0121
Shop #: WSC 06342 000 00000
2 Faults Found:
6628 - Unknown Error Code
U1113 00 [032]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 1050 km
Date: 2008.04.17
Time: 18:40:11
6455 - ECM Power Relay Control Circuit (J271): Short to Plus
P0687 00 [032]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 1050 km
Date: 2008.04.17
Time: 19:01:26
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 L HW: 8K0 907 379 L
Component: ESP8 quattro H03 0170
Revision: -------- Serial number: --------------
Coding: 0D0500
3 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:35:20
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x1022
Hex Value: 0x0213
Hex Value: 0x0275
Hex Value: 0x00FF
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:11
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x1022
Hex Value: 0x0221
Hex Value: 0x245F
Hex Value: 0x00FF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x1722
Hex Value: 0x0218
Hex Value: 0x025F
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: Redir Fail!
Part No SW: 8K0 907 289 G HW: 8K0 907 289 G
Component: BCM2.01 H38 0251
Revision: 00002001
Coding: 0F0000
Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
3 Faults Found:
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:37:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:39:36
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 55
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:34
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0042
Revision: AA000000 Serial number: 00001001040585
Coding: 08017025002444111000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:11
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 D HW: 4E0 035 729 A
Component: Interfacebox H43 3010
Revision: 00000000 Serial number: 340JS077504187
Coding: 0005003
Part No: 8T0 919 609 D
Component: E0380 BedienteilH07 0100
No fault code found.
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8T1 820 043 R HW: 8T1 820 043 R
Component: KLIMA 3 ZONEN H05 0112
Revision: C1000000 Serial number: 0126.10.070114
Coding: 46022000
5 Faults Found:
00000 - End of Output
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 81
Mileage: 678 km
Time Indication: 0
Date: 2008.03.30
Time: 14:40:07
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:39:32
Freeze Frame:
Voltage: 8.40 V
Temperature: 23.0°C
RPM: 0 /min
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 82
Mileage: 678 km
Time Indication: 0
Date: 2008.03.30
Time: 15:16:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 19:18:18
01274 - Air Flow Flap Positioning Motor (V71)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 1051 km
Time Indication: 0
Date: 2008.04.18
Time: 08:48:39
Freeze Frame:
Voltage: 13.90 V
Temperature: 18.0°C
Temperature: 14.0°C
Count: 10000
Count: 9982
Bin. Bits: 01000100
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0252
Revision: 05021001 Serial number: 00000000049855
Coding: 26001091061CAF010000080300003D3D0F1C128800010161000000
Shop #: WSC 03743 444 00000
Part No SW: 8T1 955 119 B HW: 8J1 955 119
Component: WWS 021107 H13 0040
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0002
Coding: 02532C
Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
Component: E1 - LDS H07 0070
Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 19:18:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:00
01800 - Light Switch (E1)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 19:17:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 B HW: 8T1 035 110 A
Component: MP3-Changer H41 0380
Revision: 00041002 Serial number: AUZ5ZBG4037672
Shop #: WSC 00000 000 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 19:18:56
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0173117
Coding: 0000100
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 41
Mileage: 678 km
Time Indication: 0
Date: 2008.03.30
Time: 14:37:45
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330729003649
Coding: 200001
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:39:15
Freeze Frame:
Temperature: 23.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:38:25
Freeze Frame:
Temperature: 23.0°C
Address 15: Airbags (J234) Labels: None
Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
Component: AirbagVW-AU10 H23 0409
Serial number: 0039GD110EX4
Coding: 303333333730303030304A55304C38543053
Shop #: WSC 06325 000 00000
2 Faults Found:
13635840 - Supply voltage: Voltage too Low
U1011 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Date: 2008.04.17
Time: 18:35:23
9483264 - Unknown Error Code
B10B4 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Date: 2008.04.17
Time: 18:35:19
Address 16: Steering wheel (J527) Labels: None
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90304GJA00052
Coding: 000016
Component: E221 - MFL H02 0003
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:59
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.lbl
Part No SW: 8T0 920 980 L HW: 8T0 920 980 L
Component: KOMBIINSTR. H28 0214
Revision: 00000000 Serial number: 71W10DLA7
Coding: 830501000B00D705020000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:39:10
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E07A0380BE
Coding: 000003
Shop #: WSC 06412 444 53365
Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0120
3 Faults Found:
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 17:28:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:34
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 19:15:41
Address 1E: Media Player 2 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
Coding:
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H09 0042
Revision: AA000000 Serial number: 00001001040997
Coding: 08197B25002444111000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:08
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H50 0990
Revision: 00000000 Serial number: 341JR077504149
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 19:18:19
Freeze Frame:
Hex Value: 0x4807
Hex Value: 0xA27B
Hex Value: 0x0050
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0146
Revision: Serial number: ˆe
Coding: 011C13225E002201
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:39:35
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:29
Address 46: Central Conv. (J393) Labels: 8K0-907-289-46.clb
Revision: 00002001 Serial number: 0106803018
Coding: 01060798004A44C500B000
Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB09 H01 0170
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:34
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 8T0 035 223 P HW: 8T0 035 223 A
Component: DSP STD H07 0250
Revision: S2400000
Coding: 010101
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0146
Revision: Serial number: @Ie
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:39:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:30
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000023345
Coding:
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:41:24
Freeze Frame:
Voltage: 7.00 V
Count: 46
Hex Value: 0x0277
Hex Value: 0x0081
Hex Value: 0x1010
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 55
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:32
Freeze Frame:
Voltage: 7.60 V
Count: 44
Hex Value: 0x0273
Hex Value: 0x0081
Hex Value: 0x1010
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:35:20
Freeze Frame:
Voltage: 9.50 V
Count: 80
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Xenon Range Labels: 8T0-907-357.clb
Part No SW: 8T0 907 357 HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000017
Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Component: AFS-Modul rechtsH06 0002
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:37:58
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:24
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336JV077522752
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 19:18:35
Address 65: Tire Pressure (J502) Labels: 8K0-907-273-A.lbl
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 12822707050213
Coding: 0CD155
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:40:28
Freeze Frame:
Not Recogn.
Bin. Bits: 00000000 00100101
Voltage: 7.60 V
Text: 23,5°C;n.
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 19:17:15
Freeze Frame:
Text: erkannt;
Text: n.erkan
Text: nt
Text: 23,0°C;n.
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 8T0 907 441 HW: 4L0 907 441 A
Component: J772__Rearview 0040
Revision: --H12--- Serial number: 525PA8-J7850DN
Coding: 1000008
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:38:50
Freeze Frame:
Text: Ç:G
Text: @
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 1050 km
Time Indication: 0
Date: 2008.04.17
Time: 18:39:48
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005011617
Coding: 0010900
End ---------------------------------------------------------------------
con 1050 km , esto parece una broma!!
bueno oye.....
que le funciona el telefono !! , almenos podra llamar a la grua :thumbsup: B)
Y digo yó ¿ésto que leñes es?, sé que es algo de vag-com ¿nooo?
A ver cuéntame algo más y dime que es esto, te juro de verdad no he entendido ni papa. ja,ja,ja
Un saludo. :thumbsup:
Editado por mezquita_649
bueno oye.....
que le funciona el telefono !! , almenos podra llamar a la grua :drool: :clap1:
si , es del vag com y de 28 modulos que lee en ese coche solo 5 no tiene ningun fallo .... pero esq solo tiene 1050km!!!
Es muy sencillo... a tu coche no le han hecho el procedimiento de entrega correcto, que incluye un borrado de averías, además de la limpieza, revisión de niveles, estado de chapa y tal... Tu coche (como muchos) debió quedarse sin batería en la campa o bien durante el transporte y lo arrancaron en algún momento con un arrancador o con pinzas... Me he mirado las averías por encima y todas están relacionadas con el voltaje demasiado bajo (es decir, batería descargada)
bueno oye.....
Ok amigo "demon" ahora me ha quedao claro, es que con tantas y letras y números me había quedao :lol2:
Lo veis, si es que soy un inculto. je,je,je
Muchas gracias por vuestra aclaración.
bueno oye.....
que le funciona el telefono !! , almenos podra llamar a la grua :lol2: :clap1:
Ok amigo "demon" ahora me ha quedao claro, es que con tantas y letras y números me había quedao :conf:
h
Son todos fallos intermitentes es decir o es que le an quitado la bateria o no le an hecho las activaciones de ls pre-entrega
No hay nada como ser un ignorante y no tener vag com :drooling::thumbsup::ph34r:
Se sufre menos.... si todo funciona.... qué mas da el lector del vag com ¿¿¿¿ :p:laugh::laugh:
La ignorancia en estos casos es la felicidad, :laugh:
Pues yó aún tengo más delito porque tengo Vag-com (sin estrenar metido en su paquete), y sigo siendo un ignorante, pero claro por los motivos que algunos sabeis no he podido estrenarlo todavía. ó por lo menos eso creo... :lol2::lol2: ja,ja,ja
Os aviso que el amigo DEMON es una maquina, creo que ya no le hace falta ni el cable, el mismo lee los fallos con el coche que se ponga por delante...
El otro dia se metia en algunos sitios al chequear mi coche que yo decia, "mamaita, de mi vida", pero al final lo dejo niquelado y sin despeinarse...
Por cierto, ya me pillare el cable famoso ese, que el programa ya lo tengo, tambien cortesia de demon... :lol2:
No hay nada como ser un ignorante y no tener vag com :lol2:;):thumbsup:
Se sufre menos.... si todo funciona.... qué mas da el lector del vag com ¿¿¿¿ :laugh::laugh::lol2:
La ignorancia en estos casos es la felicidad, :(
Pues yó aún tengo más delito porque tengo Vag-com (sin estrenar metido en su paquete), y sigo siendo un ignorante, pero claro por los motivos que algunos sabeis no he podido estrenarlo todavía. ó por lo menos eso creo... :(:( ja,ja,ja
+ 1
Por cierto, ya me pillare el cable famoso ese, que el programa ya lo tengo, tambien cortesia de demon... :thumbsup:
:thumbsup: ya sabeis que lo que necesiteis....
  • 2 meses más tarde...
Demon.... me puedes ayudar?
acabo de pasar el vagcom a mi coche y me da los siguientes errores... soy un poco patoso con este tema, es la primera vez que uso el programa y el coche es de segundamano recien comprado... me puedes decir como los soluciono? son graves? Muchas gracais por tu ayuda!! La verdad es que estoy muy asustado!!!
Monday,29,March,2010,20:11:57:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 4F0
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61
62 72 76
VIN: WAUZZZ4F86Nxxxxxx Mileage: 142650km/88638miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 HS HW: 028 101 255 7
Component: R4 2,0L EDC G000SG 8251
Revision: --H01--- Serial number:
Coding: 0000072
Shop #: WSC 66565 257 00032
1 Fault Found:
006215 - Please check DTC Memory of ABS Controller
P1847 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 142176 km
Time Indication: 0
Date: 2010.03.08
Time: 17:55:12
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00101000
Torque: 0.0 Nm
Bin. Bits: 00000100
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020855
Shop #: WSC 02327 785 00200
4 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 16
Mileage: 142168 km
Time Indication: 0
Date: 2010.03.08
Time: 16:24:14
Freeze Frame:
Hex Value: 0x5308
Hex Value: 0x4AB2
Hex Value: 0x0008
Hex Value: 0x37AB
Hex Value: 0x00FF
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 16
Mileage: 142168 km
Time Indication: 0
Date: 2010.03.08
Time: 16:24:14
Freeze Frame:
Hex Value: 0x5308
Hex Value: 0x4AB2
Hex Value: 0x0009
Hex Value: 0x37AB
Hex Value: 0x00FF
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 16
Mileage: 142176 km
Time Indication: 0
Date: 2010.03.08
Time: 17:49:29
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0382
Hex Value: 0x0013
Hex Value: 0x8594
Hex Value: 0x00FF
02083 - Message for Delay Request
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 142176 km
Time Indication: 0
Date: 2010.03.08
Time: 17:49:29
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0382
Hex Value: 0x002B
Hex Value: 0x0594
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10600600249782
Coding: 0000001
Shop #: WSC 08038 572 54849
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 730 F HW: 4E0 035 729
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 350I1057598993
Coding: 0000004
Shop #: WSC 02335 785 00200
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 R
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000030051047
Coding: 0000020
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 17
Mileage: 142171 km
Time Indication: 0
Date: 2010.03.08
Time: 17:28:04
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 E HW: 4F0 907 279 B
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00141886
Shop #: WSC 02335
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7233504
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 43 AIRBAG AUDI8RH29 0280
Revision: 07H29000 Serial number: 0037LD09UD3D
Coding: 0013363
Shop #: WSC 08038 572 91207
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025052440184
Coding: 0002041
Shop #: WSC 08038 572 61192
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 931 B
Component: KOMBIINSTR. M73 H16 0630
Revision: 00100000 Serial number: 4PT32EE95
Coding: 2308143
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 16
Mileage: 142171 km
Time Indication: 0
Date: 2010.03.08
Time: 17:28:01
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008059058268
Coding: ECEE53C41B2104
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 16
Mileage: 142171 km
Time Indication: 0
Date: 2010.03.08
Time: 17:28:00
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C
Component: MNS ECE H45 0850
Revision: 00000000 Serial number: 305IU057633773
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 F HW: 4F0 959 793 F
Component: TSG FA H21 0050
Coding: 0000522
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01007006520000
Coding: 0262277
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 16
Mileage: 142171 km
Time Indication: 0
Date: 2010.03.08
Time: 17:28:00
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 C HW: 4F0 035 223
Component: Amp.-ASK H09 0320
Revision: 20S00001 Serial number: 00509050145640
Coding: 0000008
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000130203
Coding: 0001014
Shop #: WSC 02323 785 00200
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 17
Mileage: 142168 km
Time Indication: 0
Date: 2010.03.08
Time: 17:28:00
Freeze Frame:
Voltage: 11.500 V
Temperature: 33.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 F HW: 4F0 959 792 F
Component: TSG BF H21 0050
Coding: 0000522
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000111
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 16
Mileage: 142168 km
Time Indication: 0
Date: 2010.03.08
Time: 17:27:59
Freeze Frame:
Voltage: 10.56 V
Count: 241
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 16
Mileage: 142168 km
Time Indication: 0
Date: 2010.03.08
Time: 16:24:14
Freeze Frame:
Voltage: 12.84 V
Count: 231
Part No SW: 4E0 910 541 L HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0560
Revision: 00000000 Serial number: 394IM057612040
Coding: 0000001
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 5
Reset counter: 252
Mileage: 141550 km
Time Indication: 0
Date: 2009.12.04
Time: 12:14:01
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000014069
Part No: 4F0 915 105 C
Component: von VA0 161Z16Z616
Coding: 34463039313531303543205641303136315A31365A363136
5 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 141063 km
Time Indication: 0
Date: 2009.11.21
Time: 12:29:37
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 141063 km
Time Indication: 0
Date: 2009.11.21
Time: 12:29:47
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Mileage: 141063 km
Time Indication: 0
Date: 2009.11.21
Time: 12:29:57
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Mileage: 141063 km
Time Indication: 0
Date: 2009.11.21
Time: 12:30:07
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 17
Mileage: 142171 km
Time Indication: 0
Date: 2010.03.08
Time: 17:28:00
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 795 F
Component: TSG HL H21 0050
Coding: 0000002
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 794 F
Component: TSG HR H21 0050
Coding: 0000002
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 C HW: 4F0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 11820523805188
Coding: 0200006
