ASTHAROT Publicado 3 de Marzo del 2010 Denunciar Publicado 3 de Marzo del 2010 QUE TAL SOCIOS: Desde hace dias me da algun tipo de problemas el cuadro con testigos encendidos, concretamente el de ABS y ESP Despues de meterle la maquina de diagnosis da los siguientes errores: MOTOR: P 1649 ABS : P 1848 01203 Sabriais decirme de que se trata????? muchas gracias. Responder
a34323 Publicado 3 de Marzo del 2010 Denunciar Publicado 3 de Marzo del 2010 Buenas! A ver: Error 01203: http://wiki.ross-tech.com/index.php/01203 01203 - Electrical Connection between ABS and Instrument Cluster 01203 - Electrical Connection between ABS and Instrument Cluster: Open or Short to Ground Possible Symptoms * ABS Malfunctions Possible Causes * Wiring between ABS and Instrument Cluster defective * Instrument Cluster defective (rare) Possible Solutions * Check Wiring between ABS and Instrument Cluster for Short to Ground/Open Circuit * Check Instrument Cluster 01203 - Electrical Connection between ABS and Instrument Cluster: No Signal Possible Symptoms * ABS Malfunctions Possible Causes * Wiring between ABS and Instrument Cluster defective * ABS incorrectly coded * Instrument Cluster defective (rare) Possible Solutions * Check Wiring between ABS and Instrument Cluster for Short to Plus * Check ABS Coding * Check Instrument Cluster Responder
ASTHAROT Publicado 3 de Marzo del 2010 Autor Denunciar Publicado 3 de Marzo del 2010 Buenas! A ver: Error 01203: http://wiki.ross-tech.com/index.php/01203 01203 - Electrical Connection between ABS and Instrument Cluster 01203 - Electrical Connection between ABS and Instrument Cluster: Open or Short to Ground Possible Symptoms * ABS Malfunctions Possible Causes * Wiring between ABS and Instrument Cluster defective * Instrument Cluster defective (rare) Possible Solutions * Check Wiring between ABS and Instrument Cluster for Short to Ground/Open Circuit * Check Instrument Cluster 01203 - Electrical Connection between ABS and Instrument Cluster: No Signal Possible Symptoms * ABS Malfunctions Possible Causes * Wiring between ABS and Instrument Cluster defective * ABS incorrectly coded * Instrument Cluster defective (rare) Possible Solutions * Check Wiring between ABS and Instrument Cluster for Short to Plus * Check ABS Coding * Check Instrument Cluster gracias Emilio....pero.....como que no me entero de nada...el ingles no ye lo mio.......ya habia visto otro post donde lo has puesto pero ya te digo na de na...a ver si en español y con las posibles soluciones.... otra cosa el P1649 y P1848 son fallos de algo???? Responder
Tolo Publicado 3 de Marzo del 2010 Denunciar Publicado 3 de Marzo del 2010 ¿De que año es el coche? Conozco un chaval con un A6 que "sufria" el mismo error, le aparece y le desaparece según los dias. Me imagino que es un mal contacto, humedad o algo parecido. Responder
ASTHAROT Publicado 4 de Marzo del 2010 Autor Denunciar Publicado 4 de Marzo del 2010 ¿De que año es el coche? Conozco un chaval con un A6 que "sufria" el mismo error, le aparece y le desaparece según los dias. Me imagino que es un mal contacto, humedad o algo parecido. año 2.000 Tolo. Responder
