cesardeluxe Publicado 18 de Marzo del 2010 Denunciar Publicado 18 de Marzo del 2010 (editado) pues eso que no se a que viene lo de signal too low y lo de intermitent en varios módulos.. yo creo que todo funciona... kick down ok, cierre ok, motor ok... [code]Monday,19,January,2009,14:28:29:26365VCDS Version: Beta 812.4Data version: 20090214----------------------------------------------------------------------------------------------------------------------------------------------------------------Chassis Type: 8L - Audi A3/S3Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76 Mileage: 122510km/76124miles-------------------------------------------------------------------------------Address 01: Engine Labels: None Part No: 06A 906 018 C Component: 1,8l R4/5V MOTR AT V04 Coding: 04030 Shop #: WSC 00001 3 Faults Found 16486 - Mass Air Flow Sensor (G70): Signal too Low P0102 - 35-10 - - - Intermittent17967 - Throttle Body (J338): Fault in basic settings P1559 - 35-10 - - - Intermittent17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - IntermittentReadiness: 0000 0000-------------------------------------------------------------------------------Address 02: Auto Trans Labels: 01M-927-733.lbl Part No: 01M 927 733 CJ Component: AG4 Getriebe 01M 3391 Coding: 00000 Shop #: WSC 00000 2 Faults Found 00660 - Kickdown Switch or Throttle Position Sensor 27-10 - Implausible Signal - Intermittent00532 - Supply Voltage B+ 35-10 - - - Intermittent-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl Part No: 1J0 907 379 A Component: ABS/EDS ITTAE 20 GI V00 Coding: 03604 Shop #: WSC 03406 No fault code found.-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl Part No: 8L0 820 043 B Component: A3 KLIMAVOLLAUTOMAT_D72 Coding: 03140 Shop #: WSC 06313 No fault code found.-------------------------------------------------------------------------------Address 15: Airbags Labels: Redir Fail! Part No: 8L0 959 655 C Component: Airbag 6 Audi D01 Coding: 00002 Shop #: WSC 03905 1 Fault Found 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent-------------------------------------------------------------------------------Address 17: Instruments Labels: 8L0-919-xxx-17.lbl Part No: 8L0 919 860 A Component: AB-KOMBIINSTR. VDO D07 Coding: 00142 Shop #: WSC 00000 Part No: IMMO Component: IDENTNR: AUZ7Z0V0071563 IMMO-IDENTNR: AUZ7Z0V0071563 1 Fault Found 01176 - Key 07-00 - Signal too Low-------------------------------------------------------------------------------Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8LO 862 257 D Component: ZV-Pumpe,Funk Coding: 08800 Shop #: WSC 65535 2 Faults Found 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01360 - Switch for Anti-Theft Alarm; Open 29-00 - Short to GroundEnd ---------------------------------------------------------------------[/code] Editado 18 de Marzo del 2010 por cesardeluxe Responder
