Pues mirando más detenidamente he observado que en el primer autoscan que hice, todos los errores que me salen es con fecha y hora del día que hice la repro, alguien me puede decir si está todo correcto?
Pongo el autoscan entero:
VCDS Version: Release 908.1
Data version: 20091018
Saturday,17,July,2010,19:33:52:46862
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 77
VIN: WAUZZZ8T19A043296 Mileage: 18840km/11706miles
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 MH HW: 03L 906 022 B
Component: R4 2,0L EDC H01 4382
Revision: 11H01---
Coding: 0104002C180F2020
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TDI03L906022MH A01005
ROD: EV_ECM20TDI03L906022MH.rod
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AH HW: 8K0 907 379 AH
Component: ESP8 quattro H04 0230
Revision: -------- Serial number: --------------
Coding: 184500
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0025
Hex Value: 0x9399
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:16
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x22A2
Hex Value: 0x0031
Hex Value: 0x0298
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H80 0145
Revision: 00002001
Coding: 030000
Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
2 Faults Found:
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 210
Mileage: 16915 km
Time Indication: 0
Date: 2010.05.24
Time: 13:31:45
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:17
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AB HW: 8T1 820 043 AB
Component: KLIMA 3 ZONEN H06 0150
Revision: C0000000 Serial number: 01030220090200
Coding: 34020000
2 Faults Found:
00712 - Right Footwell Flap Positioning Motor (V109)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 7
Reset counter: 197
Mileage: 16174 km
Time Indication: 0
Date: 2010.04.15
Time: 19:25:05
Freeze Frame:
Voltage: 13.60 V
Temperature: 21.0°C
Temperature: 18.0°C
Count: 15811
Count: 16782
Bin. Bits: 01000000
Bin. Bits: 10001001
Time: 8.00 s
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:16
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000204339
Coding: 260050914034AF010009000000005D5D0F1C038800010141000000
Part No SW: 8T1 955 119 C HW: 8J1 955 119
Component: WWS 040209 H13 0040
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 02532C
Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 F HW: 8K0 919 475
Component: PARKHILFE 4K H06 0040
Revision: 11001001 Serial number: 40140903506223
Coding: 000001
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1DZSXO
Coding: 30313433363030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H15 0013
Revision: -------- Serial number: 90304IB10000T
Coding: 000012
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 A HW: 8T0 920 931 A
Component: KOMBIINSTR. H32 0224
Revision: 00200000 Serial number: 9D571P429
Coding: 0F05010002000008050000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:17
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G0912482AC
Coding: 000303
Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:17
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008399871
Coding: 011C02225000120102
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0116655894
Coding: 01000680003904C4012000
Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
2 Faults Found:
00218 - Humidity Sensor (G355)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 197
Mileage: 17334 km
Time Indication: 0
Date: 2010.06.11
Time: 08:13:09
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:17
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008420296
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 F HW: 8K0 907 801 F
Component: EPB Audi B8 H06 0070
Revision: 00000003 Serial number: 00000000301722
Shop #: WSC 00000 000 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:16
Freeze Frame:
Voltage: 12.20 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
Shop #: WSC 06324 000 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:16
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H01 0300
Revision: 00000003 Serial number: AUZ5Z6I1173248
Coding: 0500048204048500035B070000
Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 17625 km
Time Indication: 0
Date: 2010.06.16
Time: 13:30:21
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 C HW: 8T0 862 335 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005057453
Coding: 0010350
End ---------------------------------------------------------------------
  • Respuestas 724
Acrapovic, la mayoría de los errores que pones son del día de la repro, es decir, borralos bien(porque es evidente que no los has borrado ya que si así fuera te aparecerían con la fecha actual y no con la fecha de hace un mes y pico y vuelve a hacerle un autoscan.
Es decir, entra en la pestaña de autoscan, selecciona el tipo de chasis y luego dale directamente a borrar fallos (Clear DTCs), te pedirá confirmación, le dices que sí e inmediatamente después de hacerlo el coche borra los fallos y comienza solo un nuevo autoscan para ver que fallos salen ahora.
Deja que termine y ya está. Así verás que fallos reales tienes ahora.
Por si acaso te comento que hay que utlizar el Vagcom con el contacto del coche puesto pero el motor apagado, para que pueda acceder a todos los módulos necesarios y no de errores extraños.
Cuando hayas hecho esto vuelve a colgar el autoscan completo y le echamos un vistazo.
Si labomba, eso es exactamente lo que hizo, el autoscan que he colgado arriba es el primero que hizo, despues borré los fallos y me hizo otro autoscan con estos fallos:
Saturday,17,July,2010,19:39:32:46862
Chassis Type: 8T0
Revision: 11H01---
Readiness: 0 0 0 0 1
Coding: 184500
Revision: 00002001
Coding: 030000
Coding: 34020000
Coding: 00FD11
Coding: 02532C
Coding: 000001
Coding: 000012
Coding: 000303
Coding: 0000002
Component: Display
Coding: 0010350
Tambien decirte que lo hago con el contacto puesto y motor apagado, ves algo raro???
wenas !!...una preguntilla destrangis...merece la pena pillarse el cable sin tener mmi ni navegador ¿?
xk veo q para cambiar todo ay que estar con el cablecito parriba y pabajo...
saludos y gracias d antemano !
hombre para mi si,piensa que podrás cambiar muchas cosas:
Activar el nivel de la batería,la iluminación ambiental,la inclinación del espejo al meter marcha atrás,el cronómetro y temperatura del aceite en el Fis,los logos "s","s5" o "rs" en el MMI,activar el modo dynamic del motor,el aviso de presión de neumáticos si tu centralita es 1AT etc etc y lo que nos deparen los nuevos descubrimientos
nadie me puede decir si esos errores son normales?
Gracias ;-)
fijate bien porque al borrarlos ya no te dió errores en ningún módulo (al final de cada módulo te pone en inglés que no se han encontrado errores) el resumen que pònes al principio debe ser del scan anterior
yo de ti mañana volveria, a hacer otro scan y ya verás como no te da todos esos errores, en el resumen que hace antes de ir módulo a módulo
saludos
El resumen que has puesto no tiene nada que ver con el scan de los modulos. para mi que te has echo la picha un lio.... de todos modos cuando vuelvas a hacer un autoscan, si direcatamente en el resumen no te sale nada en rojo, esta todo OK
s2
Editado por JoZeLiToX
bueno, pues acabo de subir del garaje de hacerle un nuevo auto-scan, parece que ahora ha salido todo ok, pongo el resumen:
Wednesday,21,July,2010,12:58:22:46862
Chassis Type: 8T0
VIN: WAUZZZ8T19A043296 Mileage: 18850km/11712miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Revision: 11H01---
Coding: 184500
Revision: 00002001
Coding: 030000
Coding: 34020000
Coding: 00FD11
Coding: 02532C
Coding: 000001
Coding: 000012
Coding: 000303
Coding: 0000002
Coding: 0500048204048500035B070001
Component: Display
Coding: 0010350
¡Exacto!, es que antes parecía como si se te hubieran quedado "grabados" los datos del resumen inicial del primer autoscan ya que no coincidian con los resultados de los módulos que todos daban correctos.
Ahora ya siguen saliendo todos los módulos sin fallos y además el resumen inicial sale de acuerdo a los resultados de los módulos de abajo.
Por cierto, ¿No llevas activada ni la ventilación estacionaria ni el Audi Drive Select?
Es que si los llevaras te tendrían que salir dos fallos, uno en el Auto HVAC por no tener la calefacción estacionaria y haber activado la ventilación y otro el del Audi Drive select al no detectar el módulo de botones del salpicadero.
Bueno, he activado dos cosas más, la funcion cornering que funciona a la perfección y el Audi Drive Select.
Sobre el Audi Drive Select decir que el tema de la respuesta del acelerador, tampoco he notado gran diferencia, y en la dirección si que se endurece mucho, demasiado para mi gusto, me gustaba incluso más antes para ciudad, pero para carretera imagino que irá mejor así de dura. Despues de probar el coche he hecho un Auto-Scan y me han salido dos fallos, según comenta labomba es normal, pero no sé cual de los dos es el "normal" por no tener la botonera del Audi Drive Select. Os cito los fallos:
Thursday,22,July,2010,21:35:52:46862
Chassis Type: 8T0
VIN: WAUZZZ8T19A043296 Mileage: 18860km/11719miles
Coding: 260050914134AF210709000000005D5D0F9C038800010141000000
Coding: 00FD11
Coding: 02532C
1 Fault Found:
03207 - Charisma Switch Module
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 18852 km
Time Indication: 0
Date: 2010.07.22
Time: 21:03:00
Component: Display
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 18852 km
Time Indication: 0
Date: 2010.07.22
Time: 20:28:49
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000001
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Depués he borrado los fallos y ha hecho un nuevo auto-scan, y el de la radio ha desaparecido, pero el 09-Cent. Elect. sigue saliendo.
He hecho algo mal?
Editado por Acrapovic
