Hola compis.he intentado buscar los errores en el listado que hay puesto en destacados pero no soy capaz.es que le he hecho un autoscan y me salen un monton de fallos.a ver si podeis echarme una manita.muchas gracias!!
Thursday,01,January,2009,15:34:56:26365
VCDS Version: Beta 812.4
Data version: 20090214
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EX3A326627 Mileage: 103360km/64224miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JQ
Component: 1,9l R4 EDC 0000SG 1570
Coding: 00002
Shop #: WSC 63351
WAUZZZ8EX3A326627 AUZ6Z0B0462652
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 06435
1 Fault Found
65535 - Internal Control Module Memory Error
00-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
2 Faults Found
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
30-10 - Open or Short to Plus - Intermittent
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00100
Shop #: WSC 11111
1 Fault Found
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1211
Coding: 06730
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0003
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0003
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0003
11 Faults Found
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01366 - Opened Due to Crash Signal
36-00 - Open Circuit
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J398)
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 00000
Shop #: WSC 00000
1 Fault Found
01042 - Control Module; Not Coded
35-00 - -
End ---------------------------------------------------------------------
allos,os paso la informacion:
Editado por liyo_a4
dale a clear dtcs borras los fallos y te quedaran los fijos el mas estraño es el del modulo de abs. Tienes dos del climatizador que si no se borraran quizas con un ajuste basico de este se solucione , los de la alarma yo no me preocuparia y el de la radio seguramente es porque no tienes la original. saludos
si le he dado a all clear dtcs y no se borran jeje.lo del modulo de abs creo que es por el kit de xenon.puede ser?lo de la radio es una concert 2 pero no la traia mi coche y los del clima y la alarma ni idea.tendre algo estropeado?
muchas gracias amigo.un saludo
