JuanK_A64F Publicado 24 de Marzo del 2010 Denunciar Compartir Publicado 24 de Marzo del 2010 (editado) Lo que está en rojo como se puede solucionar??? Que es lo de DTC?? Tiene que ver algo de que se comunique el motor con el cuadro a traves del INMO? esta configurado como INMO III, yo creo que este B5 del 99/00 es INMO II, No? de todas formas anda perfect.... Thursday,25,March,2010,19:53:38:59303 VAG-COM Version: Release 704.1 Data version: 20071016 Chassis Type: 8D - Audi A4 B5 Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 Mileage: 137960km/85724miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-012.LBL Part No: 038 906 012 AH Component: 1,9l R4 EDC G000SG 2705 Coding: 00002 Shop #: WSC 06325 1 Fault Found: 18062 - Please check DTC Memory of Instrument Cluster P1654 - 35-00 - - Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL Part No: 8E0 614 111 AB Component: ABS 5.3 FRONT D00 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No: 8D0 820 043 N Component: A4 KLIMAAUTOMAT D54 Coding: 00043 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.LBL Part No: 8D0 959 655 J Component: Airbag Front+Seite 0001 Coding: 00104 Shop #: WSC 06325 1 Fault Found: 00654 - Seat Belt Tensioner Igniter; Driver Side (N153) 32-00 - Resistance too High ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-920-xxx-17.LBL Part No: 8D0 920 930 Component: B5-KOMBIINSTR. VDO D05 Coding: 02040 Shop #: WSC 00050 Component: AUZ7Z0X1130626 ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1130626 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: None Part No: Bitte Adress Component: e 17 eingeben No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.LBL Part No: 8D0 862 257 C Component: ZV-Pumpe D12 Coding: 00033 Shop #: WSC 06325 No fault code found. End -------------------------------------------------------------------------------------------------- Otra cosa, sabe alguien como se cambia el idioma al cuadro en español?? se que es el codigo 5 (ESPAÑOL) he probado con 00005 y nada de nada.... Editado 24 de Marzo del 2010 por Carlos A4 B5 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
clio69 Publicado 25 de Marzo del 2010 Denunciar Compartir Publicado 25 de Marzo del 2010 pues no se lo que es pero en el mio tambien sale y mira que lo he borradop veces y he estado mirando por hay pero no saco nada claro un saludo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
JuanK_A64F Publicado 25 de Marzo del 2010 Autor Denunciar Compartir Publicado 25 de Marzo del 2010 pues no se lo que es pero en el mio tambien sale y mira que lo he borradop veces y he estado mirando por hay pero no saco nada claro un saludo Tu as modificado algo del cuadro o llaves....? Responder Enlace al comentario Compartir en otros sitios web More sharing options...
clio69 Publicado 25 de Marzo del 2010 Denunciar Compartir Publicado 25 de Marzo del 2010 yo no pero el coche lo compre de segundamano por cierto hoy le vuelto a pasar el vagcom y hoy no lo tengo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
