Mecambioamercedes Publicado 26 de Abril del 2010 Denunciar Publicado 26 de Abril del 2010 Hola a todos, Necesito ayuda para solucionar estos errores, he pasado de 1DIN a 2DIN y he puesto el navegador RNS-E original de audi, me podeid decir porque me salen estos errores?? como los puedo solucionar? se tiene que hacer algo con el VAG-COM? Gracias _____________________________________________________________________________ Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 HW: 8P0 035 192 Component: RNS-E HIGH EU H56 0660 Revision: 08S Serial number: AUZBZ7E0015556 Coding: 0205717 Shop #: WSC 06435 000 00000 5 Faults Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 55 Reset counter: 127 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:05:43 Freeze Frame: Mileage: 99820 km Count: 1602 Clock: 21:06 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 119 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:06:23 00466 - Control Module for Steering Column Electronics (J527) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 119 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:05:38 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 119 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:05:44 01317 - Control Module in Instrument Cluster (J285) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 119 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:05:55 Freeze Frame: Bin. Bits: 10110011 Bin. Bits: 00 ________________________________________________________________________________ ____ Address 56: Radio Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 HW: 8P0 035 192 Component: RNS-E HIGH EU H56 0660 Revision: 08S Serial number: AUZBZ7E0015556 Coding: 0205717 Shop #: WSC 06435 000 00000 5 Faults Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 55 Reset counter: 127 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:05:43 Freeze Frame: Mileage: 99820 km Count: 1602 Clock: 21:06 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 119 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:06:23 00466 - Control Module for Steering Column Electronics (J527) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 119 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:05:38 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 119 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:05:44 01317 - Control Module in Instrument Cluster (J285) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 119 Mileage: 99542 km Time Indication: 0 Date: 2009.02.12 Time: 19:05:55 Freeze Frame: Bin. Bits: 10110011 Bin. Bits: 00 Responder
Mecambioamercedes Publicado 26 de Abril del 2010 Autor Denunciar Publicado 26 de Abril del 2010 Alguien puede ayudarme por favor? Responder
A420TDI Publicado 26 de Abril del 2010 Denunciar Publicado 26 de Abril del 2010 lo tienes mal codificado, segun pones en el post, equivale a un A3, y el tuyo es un A4 no? pues codifica el modulo 37 y el 56, en coding 07 y ya esta. eliminsa errores y a correr. Responder
A420TDI Publicado 26 de Abril del 2010 Denunciar Publicado 26 de Abril del 2010 mirate esto Codificación 0? Xxxxx: Modelo 1 = Lamborghini 2 = Audi A3 (8P) 3 = Audi A4 (8E) 4 = Audi A4 Cabriolet (8H) 5 = Audi A6 (4B) 6 = Audi TT (8J) 7 = Audi R8 (42) 0x? Xxxx: Altavoz de agudos inactivos Vigilancia 0 = Frente agudos de altavoces activos inactivos (no Audi A4 Cabriolet de seguimiento) 1 = frontal del altavoz de agudos de seguimiento inactivos inactivos (SOLO Audi A4 Cabriolet) 0xx? Xxx: Sonido característico 0 = El sonido característico lineal 1 = Audi A4 (8E) 2 = Audi A6 (4B) 3 = Audi A4 Cabriolet (8H) 4 = Audi TT (8J) 5 = Audi A3 (8P) 9 = Sistema de sonido 0xxx? Xx: Teléfono / Telemática 1 = no se instala Teléfono (Remote alimentación del voltaje para los activos de micrófono) 2 = la placa base (Temic - Feed remoto del voltaje para los inactivos micrófono) 3 = la placa base (Cullmann - Feed remoto del voltaje para los inactivos micrófono) 4 = la placa base (Nokia - Feed remoto del voltaje para los inactivos micrófono) 5 = Telemática Europa (Remote alimentación del voltaje para los inactivos micrófono) 6 = Telemática EE.UU. (Remote alimentación del voltaje para los inactivos micrófono) 7 = placa base de diagnóstico capaces con control de confort 0xxxx? X: Equipo I 1 = sintonizador no se instala 2 = la señal digital de radio instalado 3 = Radio por satélite instalado 4 = por satélite y la radio digital instalado 5 = Entrada Analógica (AUX) instalado 7 = por satélite de radio y de entrada analógica (AUX) instalado 0xxxxx?: Equipo II 1 = TV-Tuner/CD-Changer/Multi-Function volante no se instala 2 = Sintonizador de TV instalado 3 = CD-Changer instalado 4 = Sintonizador de TV y cargador de CD-instalado 5 = multi-función de volante instalado 6 = sintonizador de televisión y de múltiples funciones del volante instalado 7 = CD-Changer y multi-función de volante instalado 8 = Sintonizador de TV y cargador de CD y multi-función de volante instalado Responder
Mecambioamercedes Publicado 27 de Abril del 2010 Autor Denunciar Publicado 27 de Abril del 2010 Hola GRACIAS por contestar. Yo tengo un Audi A3 8P no un A4, los codigos que me mandas "sinceramente" me suenan a chino... no tengo ni idea de nada ni de como hacerlo, hoy me dan mi cable Vag-Com y programa la version 908 por 70eu Responder
A420TDI Publicado 28 de Abril del 2010 Denunciar Publicado 28 de Abril del 2010 0205717 0: 0 2: A3 0: frente agudos... 5: A3 8p 7: placa base de diagnostico con control de confort 1: no sintonizador de tv 7: cargador de cd y volante multifuncion pregunta: tienes telefono instalado? revisa el modulo 16 direccion J527, y elimina fallos. lo mismo en el modulo 17 cuadro de instrumentos J285, elimina fallos. y tienes cargador de cd? bueno ya me diras algo jesus, un saludo Responder
Mecambioamercedes Publicado 28 de Abril del 2010 Autor Denunciar Publicado 28 de Abril del 2010 Telefono no tengo y Cargador de CD´S tampoco tengo,, borro los fallos pero encuanto le doy al contacto vuelven... Responder
A420TDI Publicado 28 de Abril del 2010 Denunciar Publicado 28 de Abril del 2010 prueba con este codigo 0205115 y me dices haber ok elimina todos los fallos Responder
Mecambioamercedes Publicado 29 de Abril del 2010 Autor Denunciar Publicado 29 de Abril del 2010 Perdona que te moleste de nuevo pero... en que apartado o donde meto ese codigo? Ese codigo exactamente que hace? deja todo por defecto? me borrar los errores pero lo configura a la vez? porque yo realizo el auto-scan me salen los errores, los borro y encuento das el contacto vuelven Responder
A420TDI Publicado 29 de Abril del 2010 Denunciar Publicado 29 de Abril del 2010 Perdona que te moleste de nuevo pero... en que apartado o donde meto ese codigo? Ese codigo exactamente que hace? deja todo por defecto? me borrar los errores pero lo configura a la vez? porque yo realizo el auto-scan me salen los errores, los borro y encuento das el contacto vuelven HOLA JESUS, pues lo metes dentro del modulo 56 radio. en coding 07, metes el codigo que te digo y le das a do it, te sale y eliminas fallos de ese modulo y del modulo 16, direccion, ok pd. el modulo 56 y el 37 son el mismo. prueba y me dices, y que no molestas a ver si lo conseguimos. Responder
Mecambioamercedes Publicado 30 de Abril del 2010 Autor Denunciar Publicado 30 de Abril del 2010 OK, mañana por la mañana lo probare <_<, pero me sale una duda, ese codigo me ajusta toda la configuración, o simplemente me borrar esos errores pero siguen estando? nose si me entiendes? Responder
Jhimy Publicado 30 de Abril del 2010 Denunciar Publicado 30 de Abril del 2010 OK, mañana por la mañana lo probare , pero me sale una duda, ese codigo me ajusta toda la configuración, o simplemente me borrar esos errores pero siguen estando? nose si me entiendes? Con ese codigo lo que le estas diciendo a la centralita es que tienes un A3, sin telefono y sin cargador. con el codigo que tienes actualmente le estas diciendo que tienes telefono y cargador por eso te indica el fallo. Responder
ferchir Publicado 1 de Mayo del 2010 Denunciar Publicado 1 de Mayo del 2010 Antes de cambiar nada apunta el codigo que llevas por si acaso. Es una norma a seguír cuando se trabaja con vag-com. Te puede ahorrar quebraderos de cabeza.te dejo una pagina de por si te ayuda . saludos http://wiki.ross-tech.com/wiki/index.php/A..._Cabriolet_(8P) Responder
Mecambioamercedes Publicado 2 de Mayo del 2010 Autor Denunciar Publicado 2 de Mayo del 2010 Hola, he pusto el codigo que me indicais de la siguiente manera: Modulo 56 --> Coding 07 --> poner el codigo --> Do it --> pasar el auto scan y borrar errores Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 HW: 8P0 035 192 Component: RNS-E HIGH EU H56 0660 Revision: 08S Serial number: AUZBZ7E0015556 Coding: 0205115 Shop #: WSC 06435 000 00000 5 Faults Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 13 Reset counter: 141 Mileage: 100215 km Time Indication: 0 Date: 2009.02.19 Time: 20:03:53 Freeze Frame: Mileage: 100300 km Count: 2202 Clock: 05:08 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 136 Mileage: 100215 km Time Indication: 0 Date: 2009.02.19 Time: 20:04:33 00466 - Control Module for Steering Column Electronics (J527) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 136 Mileage: 100215 km Time Indication: 0 Date: 2009.02.19 Time: 20:03:48 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 136 Mileage: 100215 km Time Indication: 0 Date: 2009.02.19 Time: 20:03:53 01317 - Control Module in Instrument Cluster (J285) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 136 Mileage: 100215 km Time Indication: 0 Date: 2009.02.19 Time: 20:04:04 Freeze Frame: Bin. Bits: 10110011 Bin. Bits: 00 Responder
Jhimy Publicado 2 de Mayo del 2010 Denunciar Publicado 2 de Mayo del 2010 (editado) Una Pregunta, volante multifunción Tienes? Editado 2 de Mayo del 2010 por Jhimy Responder
