pacoalvarez135 Publicado 11 de Junio del 2010 Denunciar Publicado 11 de Junio del 2010 (editado) POngo los autoscan hecho con cable 908 Release(el que se consigue en la compras conjuntas) con los labels que le metí. Labels Originales del cable VCDS Version: Release 908.0 Data version: 20090911 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 VIN: xxxxxxxxxxxxxxxxx Mileage: xxxxxxxxxx 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 Chassis Type: 8Z - Audi A2 Scan: 01 02 03 08 15 16 17 37 45 46 56 57 75 76 77 Chassis Type: 8T - Audi A5/S5 Scan: Auto-detect Chassis Type: 8T - Audi A5/S5 Scan: Auto-detect Chassis Type: 8T0 Scan: 01 03 05 08 09 10 15 16 17 19 20 42 46 52 53 55 56 5F 62 72 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 NP HW: 03L 906 019 AL Component: R4 2,0L EDC H22 6029 Revision: 25H22--- Coding: 1A194012042403080000 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM20TDI03L906022NP A02004 ROD: EV_ECM20TDI03L906022NP.rod No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT Component: ESP8 front H04 0010 Revision: -------- Serial number: -------------- Coding: 160D0C Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0327 Revision: 00002001 Coding: 032400 Shop #: WSC 06325 000 00000 Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AG HW: 8T1 820 043 AG Component: KLIMA 1 ZONE H08 0171 Revision: A0000000 Serial number: 01091220091711 Coding: 34300000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 N HW: 8K0 907 063 N Component: BCM1 1.0 H25 0380 Revision: 09025001 Serial number: 00000000535036 Coding: 260050914074AF010009000000005D5D0F1C030804010101000000 Shop #: WSC 06325 000 00000 Part No SW: 8T1 955 119 D HW: 8J1 955 119 Component: WWS 101209 H14 0070 Coding: 00FD11 Part No SW: 8K0 955 559 HW: 8K0 955 559 Component: RLS H04 0003 Coding: 02532C Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 J HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0050 Revision: 11001001 Serial number: 39840934403891 Coding: 100207 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H39 0560 Serial number: 003EFD08AC6 Coding: 30343438363030303030554A304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_AU48.rod No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304ILE0001Q Coding: 000016 Shop #: WSC 06325 000 00000 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8T0 920 931 D HW: 8T0 920 931 D Component: KOMBIINSTR. H34 0255 Revision: 00000000 Serial number: CI171VGD9 Coding: 0F0D300003000008050000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L Component: GW-BEM 5CAN-M H10 0105 Revision: FB900055 Serial number: 5500F09B27011B Coding: 00CF07 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: None Part No SW: 8K0 857 511 E HW: 8K0 857 511 A Component: FLA H04 0004 Revision: AA001002 Coding: 02019864747464545425363E Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 8T0 959 793 J HW: 8T0 959 793 D Component: TSG FA H07 1201 Revision: -------- Serial number: -------------- Coding: 011C02625000450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0327 Revision: 00002001 Serial number: 0124837326 Coding: 013A0620203904C00320043680000000 Shop #: WSC 06325 000 00000 Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 8T0 959 792 J HW: 8T0 959 792 D Component: TSG BF H07 1201 Revision: -------- Serial number: -------------- Coding: 011C02225C00450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000392912 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 A Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 06324 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio ® Labels: None Part No SW: 4F0 035 056 B HW: 4F0 035 056 Component: Radio U STD H45 0020 Revision: AB001007 Serial number: 342L5097741699 Coding: 010003020100000001 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: Redir Fail! Part No SW: 8T1 035 666 E HW: 8T1 035 666 E Component: H-BN-EU H47 0047 Revision: -------- Serial number: 483L/097583060 Coding: 010100040106A1ED01000B1E000000030000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 8T0 959 795 J HW: 8T0 959 795 B Component: TSG HL H05 1201 Revision: -------- Serial number: -------------- Coding: 010C02224000450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 8T0 959 795 J HW: 8T0 959 795 B Component: TSG HR H05 1201 Revision: -------- Serial number: -------------- Coding: 010C02224000450005 Shop #: WSC 06325 000 00000 No fault code found. End --------------------------------------------------------------------- Editado 11 de Junio del 2010 por pacoalvarez135 Responder
pacoalvarez135 Publicado 11 de Junio del 2010 Denunciar Publicado 11 de Junio del 2010 CON LABELS V. 10.3 VCDS Version: Release 908.0 Data version: 20100324 Scan: Auto-detect Chassis Type: 8T - Audi A5/S5 Scan: Auto-detect Chassis Type: 8T - Audi A5/S5 VIN: XXXXXXXXXXXXXXX Mileage: XXXXXXXXXXX Scan: Auto-detect Chassis Type: 8T - Audi A5/S5 Scan: Auto-detect Chassis Type: 8T0 Scan: 01 03 05 08 09 10 15 16 17 19 20 42 46 52 53 55 56 5F 62 72 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 NP HW: 03L 906 019 AL Component: R4 2,0L EDC H22 6029 Revision: 25H22--- Coding: 1A194012042403080000 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM20TDI03L906022NP A02004 ROD: N/A No ASAM data for: "EV_ECM20TDI03L906022NP" () No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT Component: ESP8 front H04 0010 Revision: -------- Serial number: -------------- Coding: 160D0C Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0327 Revision: 00002001 Coding: 032400 Shop #: WSC 06325 000 00000 Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AG HW: 8T1 820 043 AG Component: KLIMA 1 ZONE H08 0171 Revision: A0000000 Serial number: 01091220091711 Coding: 34300000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 N HW: 8K0 907 063 N Component: BCM1 1.0 H25 0380 Revision: 09025001 Serial number: 00000000535036 Coding: 260050914074AF010009000000005D5D0F1C030804010101000000 Shop #: WSC 06325 000 00000 Part No SW: 8T1 955 119 D HW: 8J1 955 119 Component: WWS 101209 H14 0070 Coding: 00FD11 Part No SW: 8K0 955 559 HW: 8K0 955 559 Component: RLS H04 0003 Coding: 02532C Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 J HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0050 Revision: 11001001 Serial number: 39840934403891 Coding: 100207 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H39 0560 Serial number: 003EFD08AC6 Coding: 30343438363030303030554A304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: N/A No ASAM data for: "EV_AirbaECUVWAUDI010" () No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304ILE0001Q Coding: 000016 Shop #: WSC 06325 000 00000 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8T0 920 931 D HW: 8T0 920 931 D Component: KOMBIINSTR. H34 0255 Revision: 00000000 Serial number: CI171VGD9 Coding: 0F0D300003000008050000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L Component: GW-BEM 5CAN-M H10 0105 Revision: FB900055 Serial number: 5500F09B27011B Coding: 00CF07 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: None Part No SW: 8K0 857 511 E HW: 8K0 857 511 A Component: FLA H04 0004 Revision: AA001002 Coding: 02019864747464545425363E Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 8T0 959 793 J HW: 8T0 959 793 D Component: TSG FA H07 1201 Revision: -------- Serial number: -------------- Coding: 011C02625000450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0327 Revision: 00002001 Serial number: 0124837326 Coding: 013A0620203904C00320043680000000 Shop #: WSC 06325 000 00000 Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 8T0 959 792 J HW: 8T0 959 792 D Component: TSG BF H07 1201 Revision: -------- Serial number: -------------- Coding: 011C02225C00450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000392912 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 A Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 06324 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio ® Labels: None Part No SW: 4F0 035 056 B HW: 4F0 035 056 Component: Radio U STD H45 0020 Revision: AB001007 Serial number: 342L5097741699 Coding: 010003020100000001 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: Redir Fail! Part No SW: 8T1 035 666 E HW: 8T1 035 666 E Component: H-BN-EU H47 0047 Revision: -------- Serial number: 483L/097583060 Coding: 010100040106A1ED01000B1E000000030000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 8T0 959 795 J HW: 8T0 959 795 B Component: TSG HL H05 1201 Revision: -------- Serial number: -------------- Coding: 010C02224000450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 8T0 959 795 J HW: 8T0 959 795 B Component: TSG HR H05 1201 Revision: -------- Serial number: -------------- Coding: 010C02224000450005 Shop #: WSC 06325 000 00000 No fault code found. End ------------------------------------------------------ Responder
pacoalvarez135 Publicado 11 de Junio del 2010 Denunciar Publicado 11 de Junio del 2010 VERSIÓN 908.1 EN ESPAÑOL VCDS Version: Release 908.0 Data version: 20091028 Chassis Type: 8T0 Scan: 01 03 05 08 09 10 15 16 17 19 20 42 46 52 53 55 56 5F 62 72 VIN: XXXXXXXXXXXXXXX Mileage: XXXXXXXXXXX 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 NP HW: 03L 906 019 AL Component: R4 2,0L EDC H22 6029 Revision: 25H22--- Coding: 1A194012042403080000 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM20TDI03L906022NP A02004 ROD: EV_ECM20TDI03L906022NP.rod No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT Component: ESP8 front H04 0010 Revision: -------- Serial number: -------------- Coding: 160D0C Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0327 Revision: 00002001 Coding: 032400 Shop #: WSC 06325 000 00000 Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AG HW: 8T1 820 043 AG Component: KLIMA 1 ZONE H08 0171 Revision: A0000000 Serial number: 01091220091711 Coding: 34300000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 N HW: 8K0 907 063 N Component: BCM1 1.0 H25 0380 Revision: 09025001 Serial number: 00000000535036 Coding: 260050914074AF010009000000005D5D0F1C030804010101000000 Shop #: WSC 06325 000 00000 Part No SW: 8T1 955 119 D HW: 8J1 955 119 Component: WWS 101209 H14 0070 Coding: 00FD11 Part No SW: 8K0 955 559 HW: 8K0 955 559 Component: RLS H04 0003 Coding: 02532C Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 J HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0050 Revision: 11001001 Serial number: 39840934403891 Coding: 100207 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 G HW: 8K0 959 655 G Component: AirbagVW-AU10 H39 0560 Serial number: 003EFD08AC6 Coding: 30343438363030303030554A304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_AU48.rod No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304ILE0001Q Coding: 000016 Shop #: WSC 06325 000 00000 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8T0 920 931 D HW: 8T0 920 931 D Component: KOMBIINSTR. H34 0255 Revision: 00000000 Serial number: CI171VGD9 Coding: 0F0D300003000008050000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L Component: GW-BEM 5CAN-M H10 0105 Revision: FB900055 Serial number: 5500F09B27011B Coding: 00CF07 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb Part No SW: 8K0 857 511 E HW: 8K0 857 511 A Component: FLA H04 0004 Revision: AA001002 Coding: 02019864747464545425363E Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 8T0 959 793 J HW: 8T0 959 793 D Component: TSG FA H07 1201 Revision: -------- Serial number: -------------- Coding: 011C02625000450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP Component: BCM2 1.1 H02 0327 Revision: 00002001 Serial number: 0124837326 Coding: 013A0620203904C00320043680000000 Shop #: WSC 06325 000 00000 Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 8T0 959 792 J HW: 8T0 959 792 D Component: TSG BF H07 1201 Revision: -------- Serial number: -------------- Coding: 011C02225C00450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000392912 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 A Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 06324 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio ® Labels: None Part No SW: 4F0 035 056 B HW: 4F0 035 056 Component: Radio U STD H45 0020 Revision: AB001007 Serial number: 342L5097741699 Coding: 010003020100000001 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb Part No SW: 8T1 035 666 E HW: 8T1 035 666 E Component: H-BN-EU H47 0047 Revision: -------- Serial number: 483L/097583060 Coding: 010100040106A1ED01000B1E000000030000 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 8T0 959 795 J HW: 8T0 959 795 B Component: TSG HL H05 1201 Revision: -------- Serial number: -------------- Coding: 010C02224000450005 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 8T0 959 795 J HW: 8T0 959 795 B Component: TSG HR H05 1201 Revision: -------- Serial number: -------------- Coding: 010C02224000450005 Shop #: WSC 06325 000 00000 No fault code found. End --------------------------------------------------------------------- Como veis con estos Labels un módulo que tengo muchas ganas de entrar para activar el Menu Oculto MMI3G, es el 5F Information Elect, y con estos labels funcionaría pero tengo el problema que como son en español cuando le doy a Long Conding Helper me sale este error, hablandolo con VWGOLF, puede que sea por que estos labels 908.1 son en español y me hacen falta en ingles, sabeis donde puedo conseguir los labels 908.1 o 908.2(si existe) en Ingles?? Muchas gracias espero haberme explicado un poco más. Error Long Conding Helper Responder
jabicho Publicado 12 de Junio del 2010 Denunciar Publicado 12 de Junio del 2010 A ver si te puedo ayudar, esto lo encontré por ahí en un foro y se supone que es la versión 908 v150 pero de 64 bits, sólo tendrías que instalarla en otro ordenador (para no cargarte la que tienes) y copiar tú mismo la carpeta "labels".No lo he probado, pero la descargé y sé que no tiene virus ni cosas raras.Por cierto, ¿cómo actualizas los labels'? Yo si sobreescribo la carpeta labels sólamente me va bien, pero si sobreescribo la usv ya me da fallos, ¿te pasa lo mismo? Ahí va el enlace: VCDS 908 V150 64 BITS Responder
pacoalvarez135 Publicado 12 de Junio del 2010 Denunciar Publicado 12 de Junio del 2010 A ver si te puedo ayudar, esto lo encontré por ahí en un foro y se supone que es la versión 908 v150 pero de 64 bits, sólo tendrías que instalarla en otro ordenador (para no cargarte la que tienes) y copiar tú mismo la carpeta "labels".No lo he probado, pero la descargé y sé que no tiene virus ni cosas raras.Por cierto, ¿cómo actualizas los labels'? Yo si sobreescribo la carpeta labels sólamente me va bien, pero si sobreescribo la usv ya me da fallos, ¿te pasa lo mismo? Ahí va el enlace: VCDS 908 V150 64 BITS Muchas gracias, pero cuando se me termina de descargar el antivurus Nod32 me dice que tiene un virus, así que prefiero no arriesgar, conoces algun sitio más donde poder buscarlo?? Responder
jabicho Publicado 12 de Junio del 2010 Denunciar Publicado 12 de Junio del 2010 qué raro, a mí el Avast 5 no me dice que tenga virus, como se te da bien el inglés prueba aquí:automotive software Responder
pacoalvarez135 Publicado 12 de Junio del 2010 Denunciar Publicado 12 de Junio del 2010 qué raro, a mí el Avast 5 no me dice que tenga virus, como se te da bien el inglés prueba aquí:automotive software Gracias, lo voy a mirar. Responder
ximo@6 Publicado 13 de Junio del 2010 Denunciar Publicado 13 de Junio del 2010 (editado) el programa se lo podeis bajar de ross tech, hay seguro que no tiene virus, es original, lo instalais, copiais la carpeta labels y ya esta Editado 13 de Junio del 2010 por ximo@6 Responder
