crodri123 Publicado 10 de Julio del 2010 Autor Denunciar Publicado 10 de Julio del 2010 Los de stagemotion dicen que solo es compatible el AMI. Sin embargo los de xcarlink aparte de decir que no hay limite, dicen que es totalmente compatible con el MMI. Hi, Thanks for your enquiry. Firstly I can confirm that the interface is fully compatible with your car. Lo de 850 ma se refieren a discos de 2,5 pulgadas, los de los portatiles. Yes you can indeed use an external USB hard drive with our interface connected to the USB port. There is no limit terms of capacity. The power output of the USB port on our device is 850ma so this would be sufficient to power most drives available on the market. However if your external drive requires more power it will still work but it may require a separate power source. Please let me know if you have any further queries and I would be pleased to assist you. Kind Regards Jan Xcarlink Responder
