  • Respuestas 132
Posted Images
hi, what is the problem?
romulo haz de traductor tu que sabes
*6350EE047515601*
Ref: 4E0 035 729
SW: 4F0 910 729 Q 050
TYP: HU Basis
Model No: BE 6350
Serial No: 47515601
EC: 103
12 Volt
074 JTB
I need this...but i cant find it...:(
what country are you?
should know that after changing the part, has to go to Audi workshop for this work in your car
I am from Bosnia and Herzegovina...there is no this parts in my country...i will go to workshop but i really need music in my car..:D
good morning
this piece carries a protection, which here only on AUDI removed,
you can buy a piece of these on ebay and then you'll have to go to AUDI to remove the protection of components
If your language is Russian I think you'll have to do a software bootloader with Russian,
if it is worth to English change language only if it is in German or any other European
Poles who say there are vendors selling the removed components protection, so it is just put, encode and ready
look at this with the same software as yours
http://www.ebay.pl/itm/AUDI-INTERFACE-BOX-MMI-2G-HIGH-HU-BASIC-4E0035729-SW-4F0910729-A6-S6-/231032932708?pt=LH_DefaultDomain_212&hash=item35caa2c964&_uhb=1
by chance or were not wearing tv reversing camera in the car, because if you take time to look for a unit with entry FVAS
http://www.ebay.pl/itm/AUDI-MMI-HIGH-2G-FBAS-VIDEO-MODULE-INTERFACE-4E0035729A-/231047758671?pt=UK_In_Car_Technology&hash=item35cb85034f&_uhb=1
Editado por ximo@6
I'm sorry, I do not know what language is spoken
if your MMI is in English any of these you better, just need to know if you have FVAS input, normally carry only cars with reversing camera or tv
also have to configure it with your car
  • 3 meses más tarde...
Hola chicos,
tengo el mismo problema, alguien sabe a ciencia cierta donde puedo encontrar el modulo bluetooth de mi coche (Audi A6 3.0 TDI C6 del 2006)???
según el VagCom tengo cortada la fibra en este modulo por fallo electico. Imagino que habrá petado el modulo.
gracias!!!
Ivan
  • 7 meses más tarde...
lo primero si vais a cambiar la unithead, es que conecteis el vag com, vayais al 07 controlhead, en donde pone coding copies en un papel el numero que tienes, ejem 00004 para que en la nueva lo pongais igual y os ahorreis quebraderos de cabeza.
2º control head 07 - adaptacion canal 1 copias numero
canal 2 copias numero
canal 11 copias numero
canal 12 copias numero
3º poneis la nueva centralita unit head. poneis el vagcom otravez.
vais a 07 controlhead y en coding poneis el numero que teniais (seguramente tengais una centralita de un q7 o un a6 avant o berlina y por lo tanto no os coincidiria con el vuestro)
4º control head 07 adaptacion canal 1 pones numero que tenias
canal 2 pones numeero que tenias
canal 11 pones numero que tenias
canal 12 pones numero que tenias
canal 111 ponei 1 y el mmi se resetea se apaga y se enciende.
5º vais a 19 cangateway y pulsais en new loft coding.
salen unos cuadraditos negros con numeros y letras, le pinchas encima y te salen unos listados con las cosas que llevais montadas comprobarlas y marcai o desmarcais segun configuraciones de cada vehiculo, le das ala x de cerrar ventana, y le das a save newcoding.
os tendara que salir en el menu car todas las cosas que os salian antes, si no lo haceis asi os saldra la configuracion del coche donde estaba montada la centralita
espero os sirva de ayuda, y asi no tendreis problemas-
retomo este hilo pues me pasa lo mismo, se enciende el logotipo de audi y se apaga y no funciona nada, ni teléfono, ni navegación, ni radio, ni música, ni camara trasera y no se puede acceder a la pantalla.
probé lo de la bateria,comprobé todas las conexiones y fusibles y sigue sin funcionar.
intente con el vag hacer lo que pone este enlace y no reconoce nada, sale todo en blanco, al pasar el vag da errores en todo lo anterior pero no deja entrar a reparar ninguno.
al no poder entrar no puedo copiar las referencias que tengo?
la referencia que tiene mi modulo es 4E0 035 729A SW 4E0 910 731 K y lo tenia actualizado a la version 5570.
en internet encuentro con referencia 4E0 035 729A pero la del SW las referencias son distintas y los precios andan por los 280 eu.
alguien sabe como solucionar esto?
Tienes que puentear la fibra de cada modulo empezando por el cargador después telefono luego radio despues nav y dsp. Sacas el conector de cada módulo pones el puente y pruebas y el que esta mal ya sabras cual es el que sigue funcionando despues de puentear.
y sabes si asiste alguna conexión preparada para puentear los?
otro problema es que no me funciona ninguno por lo que creo según leí en otro post que es el modulo que esta debajo de la guantera (4E0 035 729 A)
pero eso de puentear no lo hice, haber si alguien conoce alguna conexión prefabricada para hacerlo.
el navegador y la tv creo que están en el maletero pero el telefono, la camara trasera y no se si falta alguna cosa no se donde estan
