witos Publicado 18 de Julio del 2010 Denunciar Publicado 18 de Julio del 2010 Hoy he pasado por primera vez el VCDS, aprobechando que me ha salido un error de precalentadores y el coche se ha puesto en modo seguridad, el caso, es que a parte de ese error, he sacado otros cuantos, a ver si podeis decirme de que son. ------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-AKE.lbl Part No: 8E0 907 401 AF Component: 2.5l V6 TDI 0000SG 0030 Coding: 02002 Shop #: WSC 06335 Part No: 00008059 Component: 130 106KC318_1.V14754386492 WAUZZZ8E75A460336 AUX6Z0D0452050 1 Fault Found: 01318 - Control Module for Injection Pump (J399) 34-00 - No Elaboration Available Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H10 3230 Revision: 91H10323 Serial number: 0036M001K30C Coding: 0033622 Shop #: WSC 06335 000 00000 1 Fault Found: 01794 - Control Module - Incorrect Chassis (VIN) Number 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 2 Fault Frequency: 5 Reset counter: 99 Time Indication: 0 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BM Component: Komfortgerát T3B 2431 Coding: 06266 Shop #: WSC 06335 Part No: 8E1959801B Component: Tõrsteuer.FS BRM 0205 Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205 Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0205 Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0205 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 195 M Component: symphony II PM6 0410 Coding: 01005 Shop #: WSC 73472 1 Fault Found: 00878 - Connection to Speaker Front Left 36-10 - Open Circuit - Intermittent End --------------------------------------------------------------------- Responder
Tineo Publicado 18 de Julio del 2010 Denunciar Publicado 18 de Julio del 2010 ...01794 - Control Module - Incorrect Chassis (VIN) Number ... ¿se habia sustituido la centralita de airbag por algun motivo?? si has resuelto lo de los calentadores, borra todos los fallos y pasalo mas adelante a ver si se reproducen. Responder
witos Publicado 18 de Julio del 2010 Autor Denunciar Publicado 18 de Julio del 2010 ...01794 - Control Module - Incorrect Chassis (VIN) Number ... ¿se habia sustituido la centralita de airbag por algun motivo?? si has resuelto lo de los calentadores, borra todos los fallos y pasalo mas adelante a ver si se reproducen. No, el coche es de segunda mano y yo jamas he cambiado nada, los errores los borre todos, pero vuelven a aparecer. Me temo que el vehiculo tubo algun tipo de accidente (aunque cuando lo compre me perjuraron que no) porque no me esta dando más que problemas... Responder
Tineo Publicado 18 de Julio del 2010 Denunciar Publicado 18 de Julio del 2010 ...01794 - Control Module - Incorrect Chassis (VIN) Number ... ¿se habia sustituido la centralita de airbag por algun motivo?? si has resuelto lo de los calentadores, borra todos los fallos y pasalo mas adelante a ver si se reproducen. No, el coche es de segunda mano y yo jamas he cambiado nada, los errores los borre todos, pero vuelven a aparecer. Me temo que el vehiculo tubo algun tipo de accidente (aunque cuando lo compre me perjuraron que no) porque no me esta dando más que problemas... ese tema es el mas preocupante. Esa centralita no es la original del coche y no tiene adoptado el VIN (numero de bastidor) del coche. Al menos deberias registrale tu numero de bastidor con el VAGCOM no vaya a estar el sistema de airbag deshabilitado. ¿se apaga el testigo airbag en cuadro???? Responder
witos Publicado 18 de Julio del 2010 Autor Denunciar Publicado 18 de Julio del 2010 ...01794 - Control Module - Incorrect Chassis (VIN) Number ... ¿se habia sustituido la centralita de airbag por algun motivo?? si has resuelto lo de los calentadores, borra todos los fallos y pasalo mas adelante a ver si se reproducen. No, el coche es de segunda mano y yo jamas he cambiado nada, los errores los borre todos, pero vuelven a aparecer. Me temo que el vehiculo tubo algun tipo de accidente (aunque cuando lo compre me perjuraron que no) porque no me esta dando más que problemas... ese tema es el mas preocupante. Esa centralita no es la original del coche y no tiene adoptado el VIN (numero de bastidor) del coche. Al menos deberias registrale tu numero de bastidor con el VAGCOM no vaya a estar el sistema de airbag deshabilitado. ¿se apaga el testigo airbag en cuadro???? Si, y en el check que hace al dar contacto da como OK, de todas formas, como se adopta el VIN del airbag? Y el tema precalentadores, me ha estado fallando todo el dia, aunque el coche arrancaba y no me ha dejado tirado, si entraba en "modo seguridad" y no corria nada, pero lo raro es que lo he cogido hace un rato y el coche volvia a funcionar bien como si nada... ¿? tendre la bomba tocada?? Responder
Tineo Publicado 18 de Julio del 2010 Denunciar Publicado 18 de Julio del 2010 ...de todas formas, como se adopta el VIN del airbag? mirate esto: http://wiki.ross-tech.com/wiki/index.php/A..._8.4#Adaptation modulo Airbag, Adaptation, Canal 81 y meter ese codigo para que lo adopte. lo del error en modulo motor... te lo pueden mirar tambien en un Bosch Car Service; es posible que este tocada la electronica de la bomba inyectora Responder
witos Publicado 18 de Julio del 2010 Autor Denunciar Publicado 18 de Julio del 2010 ...de todas formas, como se adopta el VIN del airbag? mirate esto: http://wiki.ross-tech.com/wiki/index.php/A..._8.4#Adaptation modulo Airbag, Adaptation, Canal 81 y meter ese codigo para que lo adopte. lo del error en modulo motor... te lo pueden mirar tambien en un Bosch Car Service; es posible que este tocada la electronica de la bomba inyectora Gracias, mañana pruebo lo de los airbags y lo posteo. Referente al error de los calentadores, como tengo la garantía de 1 año, iré a comentarlo, pero empiezo a estar cansado que en 5 meses me haya petado el catalizador, el sensor de presión de aceite, la bomba de dirección, los cojinetes de las ruedas y ahora esto... y eso que "teoricamente" el coche tiene 74.000 km's... Responder
chirrito Publicado 18 de Julio del 2010 Denunciar Publicado 18 de Julio del 2010 Con ese kilometraje a mi también se me habían roto ya el catalizador, la caja de la dirección, silentblocks, tirantes de la barra estabilizadora, elevalunas del conductor............... No te "asustes" tanto SALUDOS Responder
witos Publicado 20 de Julio del 2010 Autor Denunciar Publicado 20 de Julio del 2010 Con ese kilometraje a mi también se me habían roto ya el catalizador, la caja de la dirección, silentblocks, tirantes de la barra estabilizadora, elevalunas del conductor............... No te "asustes" tanto SALUDOS No me asusto, pero es que cabrea Mis dos anteriores coches, con muchos más km, no he tenido ni 1/4 de averías, además que en este caso, las averías son tirando a gordas Catalizador = €€€€ Bomba dirección = €€€€ Bomba inyección = €€€€ Y sólo tiene 80.000 KM!!!! (teóricamente), porque no creo que sean averías para tan pocos km..., en el primer coche, que aún tengo, y pasa los 200.000 km con un motor 1.0 de 50 cv y también del grupo VAG, aún tengo estas 3 piezas de origen... Responder
Tineo Publicado 20 de Julio del 2010 Denunciar Publicado 20 de Julio del 2010 ... los cojinetes de las ruedas .... :crying_anim: los cojinetes del cubo rueda suelen irse con muchos mas kms. A mi me ha fallado uno con 300.000 y fue después de un golpe con una piedra en carretera. Responder
witos Publicado 21 de Julio del 2010 Autor Denunciar Publicado 21 de Julio del 2010 Añadimos 4 calentadores a las demas averias... A ver que sera lo siguiente... Responder
HallRoad Publicado 26 de Octubre del 2010 Denunciar Publicado 26 de Octubre del 2010 Hola, El error del numero VIN suele darse en coches traidos de fuera, con el afeitado de km. Teoricamente mi coche vino con 90000, y a los 3 meses me enteré que el anterior dueño habia pasado la revision oficial de los 19000 medio año antes de vender el coche.... En mi caso ese error mas otro referente al airbag se dio con un cambio de bateria. Debido a un bug en el software del cuadro y por la perdida de corriente, el cuadro pierde el VIN y cuando lo intenta recuperar por can-bus tras sustituir la bateria solo recuepera parte del numero (le faltan las 5 ultimos numeros). En mi caso el problema es mas gordo, ya que la centralita del airbag no reconoce el cuadro (por discrepancia entre el VIN de la centralita y el erroneo del cuadro) y al cabo de unos minutos se me enciende la luz del airbag. Este problema sólo se da en modelos A4 hast septiembre de 2003 equipados con FIS. La solucion de audi es cambiar el cuadro e instalar el nuevo software, si no funciona, hay que cambiar la unidad de control del airbag y las llaves.... Saludos y animos HR Responder
o pendello Publicado 16 de Octubre del 2014 Denunciar Publicado 16 de Octubre del 2014 (editado) Hola hoy tras quedarme sin bateria me ha pasado lo la perdida del vin en varios modulos.....he conseguido que reconociee el numero de bastidor en todos excepto el cuadro(canal 17) que siguen faltando los 5 ulrimos digitos.... En la web de rosstech no encuentro como he de hacer ni el codigo como hice en los otros modulos...... Editado 16 de Octubre del 2014 por o pendello Responder
o pendello Publicado 16 de Octubre del 2014 Denunciar Publicado 16 de Octubre del 2014 Aqui os muestro lo que me sale en el numero de bastidor... Decir que sin embargo en el apartado de fallos no da ningun error.... con lo cual no tiene importancia....pero bueno... Responder
