ahi va. espero q tu tengas mas suerte q jc. yo es la llevo y me funciona. ***12 ###8. ya sabes con el telf conectado marcas en la pantalla del mmi primero un codigo y das w llamar. cuando se cuelgue haces lo mismo con el otro.
si encuentro el link de las fotos te lo paso.
y cuéntanos q tal
  • 11 meses más tarde...
Hola, tengo un A6 4f del 2005 con MMI 0500, y el dension 500 va de lujo, pero el modulo bt 1500 a los 10 segundos de cualquier llamada se corta, con la actualizacion del MMI al 5570 se podrá solucionar, estoy desesperado, gracias.
  • 3 meses más tarde...
Esto es lo que dice literalmente la página oficial de Dension.
Microphone and Speaker Volume with BTA1500
Dension released a new BTA1500 firmware (1.5 – available since September 2009) that lets you change the microphone and the speakers volume separately via the car’s head unit. You can set the microphone’s volume value to 1 through 31. The optimal value will be different depending on the car type, cell-phone model and the microphone installation. Please note that the values are not incremental, i.e. 16 is not necessarily louder than 15. Each car will have an optimal setting.
You can easily change the default setting of the microphone if you go to the phone menu and dial *** and then enter the microphone volume’s value (e.g. ***12). The calibration process can take up to 15 seconds. In the case of Mercedes Command Head Unit, put a + in front of the *s or #s. When finished, the system returns to the dial menu.
Please ensure that the GW500 is updated to SW version 2.19.
To change the speakers volume you need to do the same procedure but instead of dialing *’s you need to dial #’s (e.g. ###14). The calibration takes about 5-15 seconds.
After the calibration please dial any number and check the result of your configuration.
If the settings are not correct, please change the values and test the new settings again.
Please note: If your cell-phone starts calling the dialed numbers during the calibration process, you have an older release of BTA1500 where this option is unfortunately not available.
Some recommended settings
...............Mic (***) Audio (###)
iPhone.............12............8
Nokia..............11............7
Sony Ericcson......11............6
Básicamente, que para el micro hacer una llamada con el código ***XX y para el audio ###XX, siendo XX el número . Como ejemplo estos tres teléfonos, para otros "prueba error". El número XX no representa el volumen, es decir 15 no es menos que 16, sino que son configuraciones y por lo tanto se deben de realizar pruebas hasta dar con la óptima.
