JUAN-27 Publicado 31 de Julio del 2010 Denunciar Compartir Publicado 31 de Julio del 2010 hola, hoy le hice un autoscan al a4 b7 con el vag com, me da dos errores en lo que creo que son los intermitentes, alguien me lo puede confirmar??? gracias. Saturday,31,July,2010,17:10:47:26365 VCDS Version: Release 805.0 Data version: 20080625 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E26A259722 Mileage: 116330km/72284miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BLB.lbl Part No SW: 03G 906 016 LR HW: 028 101 272 6 Component: R4 2,0L EDC G000CG 0972 Revision: --H02--- Serial number: Coding: 0000076 Shop #: WSC 09042 300 86580 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 8E0 910 157 H HW: 01J 927 156 HT Component: V30 01J 2.0l PD RdW 0050 Revision: 00000008 Serial number: 00000000967049 Coding: 0000001 Shop #: WSC 06325 000 00000 1 Fault Found: 17090 - Can't Decode, CODE File Not Loaded! P0706 - 000 - Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 21 Time Indication: 0 Freeze Frame: RPM: 96 /min RPM: 0 /min (no units): 1.0 Torque: -26.0 Nm Temperature: 63.0°C T.B. Angle: 0.0° Bin. Bits: 0001 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK Component: ESP8 front H06 0120 Revision: 00000000 Serial number: 00000000000000 Coding: 0004402 Shop #: WSC 06325 000 00000 1 Fault Found: 01119 - Can't Decode, CODE File Not Loaded! 000 - Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 18 Reset counter: 38 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0022 Hex Value: 0x0031 Hex Value: 0x0199 Hex Value: 0x0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BJ Component: A4 Klimaautomat 2832 Coding: 00000 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 N Component: int. Lastmodul ECE 0907 Coding: 10001 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H12 3730 Revision: 91H12373 Serial number: 0036M00BM15R Coding: 0033622 Shop #: WSC 06325 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 01042 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 D HW: 8E0 920 901 D Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0006141 Shop #: WSC 09042 300 69305 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CH Component: Komfortgerát T3B 4035 Coding: 07018 Shop #: WSC 06325 Part No: 8E1959801H Component: Tõrsteuer.FS BRM 0606 Part No: 8E1959802H Component: Tõrsteuer.BF BRM 0606 Part No: 8E0959801E Component: Tõrsteuer.HL BRM 0606 Part No: 8E0959802E Component: Tõrsteuer.HR BRM 0606 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 D Component: concert II GRO 0004 Coding: 01001 Shop #: WSC 06325 No fault code found. End --------------------------------------------------------------------- Responder Enlace al comentario Compartir en otros sitios web More sharing options...
