JUAN-27 Publicado 14 de Agosto del 2010 Denunciar Publicado 14 de Agosto del 2010 Hola, tengo un a4 b7 del año 06, desde hace unos días me parpadean los indicadores del cambio multitronic, se encienden y se apagan, pero solo lo hace a veces, el fallo que me da el vagcom es: Saturday,14,August,2010,12:45:18:26365 VCDS Version: Release 805.0 Address 02: Auto Trans Control Module Part Number: 8E0 910 157 H Component and/or Version: V30 01J 2.0l PD RdW 0050 Software Coding: 0000001 Work Shop Code: WSC 06325 1 Fault Found: 17090 - Can't Decode, CODE File Not Loaded! P0706 - 000 - Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 50 Time Indication: 0 Freeze Frame: RPM: 864 /min RPM: 0 /min (no units): 13.0 Torque: 4.0 Nm Temperature: 66.0°C T.B. Angle: 0.0° Bin. Bits: 0001 0 1 alguna idea??? Responder
JUAN-27 Publicado 14 de Agosto del 2010 Autor Denunciar Publicado 14 de Agosto del 2010 aparte de ese fallo, me da este otro. Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK Component: ESP8 front H06 0120 Revision: 00000000 Serial number: 00000000000000 Coding: 0004402 Shop #: WSC 06325 000 00000 3 Faults Found: 01826 - Can't Decode, CODE File Not Loaded! 000 - Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 25 Time Indication: 0 Freeze Frame: Hex Value: 0x00C0 Hex Value: 0x0202 Hex Value: 0x0024 Hex Value: 0x0198 Hex Value: 0x0000 00493 - Can't Decode, CODE File Not Loaded! 008 - Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 26 Time Indication: 0 Freeze Frame: Hex Value: 0x02C0 Hex Value: 0x4202 Hex Value: 0x001B Hex Value: 0x34AA Hex Value: 0x0000 01119 - Can't Decode, CODE File Not Loaded! 000 - Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 7 Reset counter: 40 Time Indication: 0 Freeze Frame: Hex Value: 0x00C0 Hex Value: 0x0002 Hex Value: 0x0031 Hex Value: 0x0185 Hex Value: 0x0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BJ Component: A4 Klimaautomat 2832 Coding: 00000 Shop #: WSC 00000 No fault code found. Responder
ortizypunto Publicado 30 de Noviembre del 2010 Denunciar Publicado 30 de Noviembre del 2010 hola, espero no estar en lo cierto pero cuando parpadea el display del multitronic es que algo no funciona dentro del cambio, copia esos errores y borralos a ver si salen otra vez, si te salen dirigete a un especialista en cambios automaticos, si no conoces a nadie yo puedo darte los nombres de los mas conocidos y tu hablas con ellos. porcierto, el coche realiza bien los cambios? patina en alguna marcha? cambia sin ton ni son? es posible que se te haya activado modo seguridad y solo tengas un par de marchas. ya nos contaras. Responder
Hotgito Publicado 3 de Diciembre del 2010 Denunciar Publicado 3 de Diciembre del 2010 ¿se te pone solo en modo sport? Responder
