Pues despues de varios intentos, cables y drivers he conseguido pasarle el vag-com al coche con el 908.
Uno de los errores que me sale es:
Intake Manifold Pressure 08-00 Control Limit Surpassed.
Según he visto por internet o es algo del turbo o cauda, que opinais???
Bueno de mto he borrado todos los errores, y dentro de un par de dias lo pasaré de nuevo a ver que sale.
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 4B0 907 401 S
Component: 2.5l/4VTEDC G000SG D66
Coding: 01002
Shop #: WSC 02324
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
00575 - Intake Manifold Pressure
08-00 - Control Limit Surpassed
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 8E0 614 111 AH
Component: ABS/ASR 5.3 FRONT D10
Coding: 00012
Shop #: WSC 02325
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 G
Component: A6-Klimavollautomat D61
Coding: 00063
Shop #: WSC 02325
3 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
00792 - A/C Pressure Switch (F129)
31-10 - Open or Short to Ground - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 G
Component: Airbag Front+Seite 1001
Coding: 00106
Shop #: WSC 02324
1 Fault Found:
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 931 B
Component: C5-KOMBIINSTR. VDO D09
Coding: 00160
Shop #: WSC 00000
Component: AUZ7Z0X1238128
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1238128
1 Fault Found:
01176 - Key
07-10 - Signal too Low - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 E
Component: Zentralverrieg.,DWA D33
Coding: 04683
Shop #: WSC 02324
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02324
End ---------------------------------------------------------------------
Golphi creo que eso es de los manguitos de depresión del turbo, a mi padre le salió algo, si mal no recuerdo, similar, la avería en caso de que tengas que hacerle algo es cosa de poco..
Ya nos cuentas,,, saludos
Eso es un fallo de sobrepresion de turbo.
Yo tengo ese mismo error, pero en m icaso es porque unos cafres me han tocado la regulacion del turbo y ahora sopla demasiado.
De todas formas borra los errores y vuelve a pasar el vagcom, puede haber sido un error que te a dado en algun momento untual y hasta que no lo borras se queda guardado.
Pero seguramente el error no esta en el turbo asi que tranquilo, puede ser un sensor, algun manguito que pierde presion...
Si el coche anda normal no te preocupes!!
Gracias chicos, hoy a la mañana le pasaré el vag de nuevo a ver que me cuenta.
Por cierto, sabeis por que motivo cuando le enchufo el vag me dice que la comunicación la establece por kkl y no por can?? es que por ejemplo, no me deja acceder al módulo de navegación, y no sé si es por que no tengo cableado el can h y l del cuadro al navi
Bueno pues ya está, he borrado todas las averias y de mto no me ha salido nada con el vag-com, lo probaré de nuevo a la tarde.
Por cierto, por fin he conseguido entrar en el canal del navi, al final era necesario tener el coche y el navi encendido para poder acceder.
Otra cosilla que he hecho es activar la luz del cinturón de seguridad en el cuadro.
Ya os iré contando más cosillas.
