golfinho Publicado 7 de Octubre del 2010 Denunciar Publicado 7 de Octubre del 2010 TYPE: 4B2 0RC A6 LIM TDI 2.5 110 KW M6S MOTORKB / GETR. KB ENG. CODE / TRANS. CODE AFB ---- DQS LACKNR. / INNENAUSST. PAINT NO. / INTERIOR LZ9W / LZ9W N4G / BN E0A = No special edition 4UE = Air bag for driver and front seat passenger 6XD = Exterior mirrors: electrically adjustable/heated 1KD = Disc brakes, rear J1G = Battery 450 A (92 Ah) 1LT = Disc brakes, front 1AJ = Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL) 1BE = Sports suspension/shock absorption 3FA = Without roof insert (standard roof) 5MB = Decorative inserts 7X0 = Without park distance control F0A = No special purpose vehicle, standard equipment 0L2 = Electric throttle actuation (acelerador electrónico) 8GL = Alternator 120 A 0G1 = Gearshift lever 0YC = Weight range 3 installation control only, no requirement forecast 0JJ = Weight category front axle weight range 9 T6T = 6-cylinder diesel engine 2.5 L unit 059.A 3ND = Rear seat bench/backrest, unfolding 8JH = Ellipsoidal headlight for driving on the right U1C = Instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.) X3B = National sales program Spain (FBU) 1N1 = Power steering 1MR = Leather steering wheel 3HA = Without leather parts scope 8Q1 = Headlight-range adjustment 9Q2 = Multi-function display/on-board computerwith check control 8Z6 = Hot country M5V = 6-cyl. turbo diesel engine 2.5 L/110 kW catalytic converter and EGR, MVEG 2 base engine is T6T 7Q0 = Without navigation device C6P = Alloy wheels 7J x 16 9-spoke style, offset 45 7K0 = Without tire pressure warning light 4X1 = Side air bag front 2K1 = Reinforced bumpers 6R2 = Leather gearshift boot 3PF = Electric height adjustment for both front seats 4KC = Side and rear windows in heat-insulatingglass 3Y0 = Without roll-up sun screen 4K4 = Radio remote controlled central locking 5D1 = Carrier frequency 433.92 MHz-434.42 Mhz 1SA = Without additional engine guard Q1A = Standard front seats 4GH = Windshield in heat-insulating glass with sunshield Responder
a34323 Publicado 8 de Octubre del 2010 Denunciar Publicado 8 de Octubre del 2010 Golfi, y todo esto de donde lo has sacado y cómo? Responder
jafv Publicado 8 de Octubre del 2010 Denunciar Publicado 8 de Octubre del 2010 Todos los letrajos están en la etiqueta que está pegada en el hueco de la rueda de repuesto en el maletero. Luego, con los códigos de tres letras te vas a una web por ahí y te saca lo que significan mas o menos (más bien menos). He visto por ahí que los códigos metidos en un fichero de tipo txt se lo pasas al ETKA y a partir de ahí te saca solo los repuestos específicos de tu coche. Yo tenía el ETKA para que se conectara a internet y poniendo tu bastidor te diera solo la información de tu coche, pero eso dejó de funcionar. Por ahora lo que funciona es entrar en "http://www.etka-online.net/", utilizar un traductor del ruso, meter el número de bastidor, descargarte el fichero txt con los datos de tu coche y meterselo al ETKA para que te diga las piezas del tuyo. Para el que no tenga un taller es totalmente suficiente. Responder
a34323 Publicado 9 de Octubre del 2010 Denunciar Publicado 9 de Octubre del 2010 Joer javf...muchas gracias. Mi coche es que vino sin pegatina cuando lo compré. Así que me quedo en blanco...jo... Responder
jafv Publicado 9 de Octubre del 2010 Denunciar Publicado 9 de Octubre del 2010 Joer javf...muchas gracias.Mi coche es que vino sin pegatina cuando lo compré. Así que me quedo en blanco...jo... No, no te quedas en blanco, entra en la web que te he puesto, introduce la marca del coche (AUDI), el nº de chasis, y te descargarás un fichero de texto que contiene todos los letrajos que debería llevar tu pegatina. Prueba y nos cuentas. Responder
Urbiés Publicado 10 de Octubre del 2010 Denunciar Publicado 10 de Octubre del 2010 ¿Es normal que tarde 11 horas en descargar? Responder
jafv Publicado 11 de Octubre del 2010 Denunciar Publicado 11 de Octubre del 2010 No, no es normal, pero yo lo conseguí el tercer día que lo intenté. Me pasaba lo que a tí, que no descargaba, ASI que a intentarlo de vez en cuando. Responder
Urbiés Publicado 11 de Octubre del 2010 Denunciar Publicado 11 de Octubre del 2010 No, no es normal, pero yo lo conseguí el tercer día que lo intenté. Me pasaba lo que a tí, que no descargaba, ASI que a intentarlo de vez en cuando. Gracias Responder
a34323 Publicado 12 de Octubre del 2010 Denunciar Publicado 12 de Octubre del 2010 Pues mi coche tiene estos extras y no entiendo nada de nada.... 4B20R9; B2B2BR; AKN; 000000; DQT; 000 ;30092000; 000 ;2001; 1E03B06U02WA4UE9V71C1QH09M9T6TJ1G5C0K8B1LT1KD1AT4L22K17QA7A05D14W08KA6E33C73V0B0 6FB8T0FC0VY04N02A44K42T11X10GE8Z61SAMR2A8S6XD2B11T30TD8WB6W51Z60F36R26Q2C158GL6P FA0VX08JH8K08X08Q17E69AK1EX2G05MC1VHU1C0W17CA3HA5SL4E01PC6SS5A57P14ZB9Q27Q20VD5K 7X03CA8AY0N13GA8TC3Q63NZ6V1VC05RQ3Y03FA3S00LT7M13PF9P0N5A4A0A001BE4X44KC5E23X01G 9VDE0A0SU1N12C5L0L2ZQ9NX9B09ZF0L26M17K0H6U1D01WD1YCG0L0G1B992Z10DSF0A0JK0YPC6P4G 8N4P21PK6PNDQA0Q1AQV0V0AWM4YNT Entiendo que el coche es de septiembre del 2000, que es un motor akn y poco más. Responder
golfinho Publicado 14 de Octubre del 2010 Autor Denunciar Publicado 14 de Octubre del 2010 Buenas Emilio, perdona por no responder antes, mis códigos los he sacado del libro de mantenimiento, como bien te han dicho por ahi es una pegatina. Despues para interpretar los códigos yo lo hice en una web pero no recuerdo el nombre, a ver si la localizamos. Para interpretar los códigos tienes que separarlos en grupos de 3 caracteres, empezando por: E03: xxxxxxxxxxxxxxxxxxxxxxxxx B06: xxxxxx Responder
jafv Publicado 15 de Octubre del 2010 Denunciar Publicado 15 de Octubre del 2010 (editado) La web es esta: http://igorweb.org/equidec/Default.aspx Puedes meter todos los códigos separados por una coma y te devuelve más o menos lo que son. Pero realmente lo que está bien es meterle al ETKA el fichero texto, ahí es donde sale realmente lo que tienes, además de que luego te selecciona lo que es específico de tu coche. Aqui tienes un ejemplo de una hoja de lo que te sale con el ETKA. Editado 15 de Octubre del 2010 por jafv Responder
