KuA Publicado 29 de Octubre del 2010 Denunciar Compartir Publicado 29 de Octubre del 2010 Hoy he conectado el Vag-com porque tengo el testigo de la presión de los neumaticos que me da error. Al conectarlo, no solo me ha salido ese error, sino unos cuantos más. Quisierá saber si teneis la solución para alguno de ellos. Gracias. ddress 01: Engine Labels: 079-910-560-BNS1.lbl Part No SW: 8E1 910 560 HW: 8E1 907 560 Component: 4.2L V8/4V FSI ª0080 Revision: --H03--- Serial number: XXXXXXXXXXXXXX Coding: 01040003180F0160 Shop #: WSC 63401 134 52318 VCID: E3CE2DD21D0F2E04 1 Fault Found 005493 - Right Engine Mount Solenoid Valve (N145): Short to Plus P1575 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 51 Mileage: 102657 km Time Indication: 0 Freeze Frame: RPM: 800 /min Load: 24.7 % Speed: 0.0 km/h Temperature: 96.0°C Temperature: 42.0°C Absolute Pres.: 940.0 mbar Voltage: 13.589 V Address 11: Engine II Labels: 079-910-560-BNS2.lbl Part No SW: 8E1 910 560 HW: 8E1 907 560 Component: 4.2L V8/4V FSI ª0080 Revision: --H03--- Serial number: Coding: 01040003180F0160 Shop #: WSC 63401 134 52318 VCID: E3CE2DD21D0F2E04 1 Fault Found 000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit: Short to Ground P0051 - 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 107243 km Time Indication: 0 Freeze Frame: RPM: 134 /min Load: 74.1 % Speed: 0.0 km/h Temperature: 96.0°C Temperature: 59.0°C Absolute Pres.: 1000.0 mbar Voltage: 10.795 V Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl Part No SW: 8E0 035 192 D HW: 8E0 035 192 D Component: RNS-E HIGH EU H71 0650 Revision: 02S Serial number: AUZBZ7E1125691 Coding: 0309717 Shop #: WSC 06335 000 00000 VCID: 254AF3CAD3BB1034 4 Faults Found 02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 172 Time Indication: 0 Date: 2010.10.11 Time: 18:58:43 Freeze Frame: Mileage: 655350 km Count: 2810 Clock: 23:12 00857 - CD Changer Unit (R41) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 172 Time Indication: 0 Date: 2010.08.06 Time: 19:02:27 16352 - Control Module - Electrical Error 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 171 Time Indication: 0 Date: 2006.05.20 Time: 14:40:27 02444 - Disk Drive Load / Eject Malfunction 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 172 Time Indication: 0 Date: 2010.10.12 Time: 18:29:04 Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CA Component: Komfortgerát T3B 3332 Coding: 06778 Shop #: WSC 06335 VCID: 72E0D89652F5378C Part No: 8E1959801G Component: Tõrsteuer.FS BRM 0506 Part No: 8E1959802G Component: Tõrsteuer.BF BRM 1406 Part No: 8E0959801E Component: Tõrsteuer.HL BRM 0606 Part No: 8E0959802E Component: Tõrsteuer.HR BRM 0606 4 Faults Found 01616 - Signal Wire to Interior Monitor 49-00 - No Communications 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - Address 65: Tire Pressure Labels: 8E0-907-273.lbl Part No SW: 8E0 907 273 HW: 8E0 907 273 Component: Reifendruck 3 H03 0110 Coding: 0022523 Shop #: WSC 02195 785 00200 VCID: E9D23FFAFF237454 1 Fault Found 01521 - Sensor for Tire Pressure 002 - Lower Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100010 Fault Priority: 3 Fault Frequency: 10 Reset counter: 40 Time Indication: 0 Freeze Frame: (no units): 38.0 Voltage: 13.40 V (no units): 19.0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
