dudas de antinieblas
JonyGode
muy buenas, me he comprado en "stagemotion.com" http://www.stagemotion.com/index.php?page=...t&Itemid=27
el cableado de las luces antinieblas y me han mandado este texto para su instalación...
Manual wiring fog lights Audi A3 8P
Please disconnect the battery before starting installation.
Please wire the loom starting from the fog lights to the following connections:
Wire configuration:
Gray - control unit for central electric connector D PIN 2
Gray/ Yellow - control unit for central electric connector A PIN 4
Brown - Ground point - Battery
Single loom - Light switch 10-pole connector – PIN 5 --- to the control unit for central electric 16-pole connector E PIN 6
Connectors are marked directly on the control unit for central electric.
Looms need to be wired through the rubber beak underneath the battery. Therefore the battery needs to be removed as well as the carrier below.
After installation you need to code the control unit for central electric to fog lights.
la parte que no me queda muy clara es esta:
que es un cable blanco.
y por ultimo seria saber que bite tengo que activar con el Vag.
un saludo y muchas gracias por anticipado.
Editado por JuaNiYo_
Enlace al comentario
Compartir en otros sitios web
