jozee1889 Publicado 5 de Noviembre del 2010 Denunciar Publicado 5 de Noviembre del 2010 haber señores tengo un problema al cual no se configurar, y por ello pido vuestra ayuda, ya he sido capaz de quitar algun fallo pero sigo teniendo algunos, os lo pongo aki haber si me podeis ayudar: 19-CAN Gateway -- Status: Malfunction 0010 37-Navigation -- Status: Not registered 0011 56-Radio -- Status: Malfunction 0010 Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 P HW: 1K0 907 951 Component: J533__Gateway H16 0192 Revision: H16 Serial number: 2500K083150F07 Coding: E9807F061006022102 Shop #: WSC 06314 000 00000 VCID: 346C1E8E686179BC 1 Fault Found 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 15 Mileage: 62331 km Time Indication: 0 Date: 2010.11.05 Time: 19:12:06 Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q Component: RNS-E HIGH EU H76 X--- Revision: 07S Serial number: AUZBZ7J0900605 Coding: 0205755 Shop #: WSC 73873 136 83054 VCID: 3D7A3BAA5B2BB8F4 2 Faults Found 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 15 Mileage: 62331 km Time Indication: 0 Date: 2010.11.05 Time: 19:13:09 Freeze Frame: Mileage: 62340 km Count: 511 Clock: 21:03 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01110100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 15 Mileage: 62331 km Time Indication: 0 Date: 2010.11.05 Time: 19:13:59 Address 56: Radio Labels: 8E0-035-192-RNSE.lbl Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q Component: RNS-E HIGH EU H76 X--- Revision: 07S Serial number: AUZBZ7J0900605 Coding: 0205755 Shop #: WSC 73873 136 83054 VCID: 3D7A3BAA5B2BB8F4 2 Faults Found 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 15 Mileage: 62331 km Time Indication: 0 Date: 2010.11.05 Time: 19:13:09 Freeze Frame: Mileage: 62340 km Count: 511 Clock: 21:03 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01110100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 15 Mileage: 62331 km Time Indication: 0 Date: 2010.11.05 Time: 19:13:59 La cuestion es, que el primer fallo del navegdor y de la radio, es por que la antena del gps la tengo quitada, pero la segunda de CD Changer unit, no se de que es, ya que yo no tengo cargador de cd, si se refiere a eso. Y la del CAN Gateway de que puede ser? a que esta relacionada? Saludos y gracias. Responder
