Hola
Pues despues de pasar hoy el vag me encuentro con todo esto. Como lo soluciono???? :thumbsup::innocent:
A ver si me podeis ayudar
Gracias
Friday,12,November,2010,19:21:13:26365
VCDS Version: Release 805.0
Data version: 20080625
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: Mileage: 82400km/51200miles
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 7420
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00844 572 55250
1 Fault Found:
16567 - Fuel Temp. Sensor A (G81): Open or Short to Plus
P0183 - 000 - -
Freeze Frame:
RPM: 1890 /min
Torque: 124.0 Nm
Speed: 27.0 km/h
Load: 36.9 %
Voltage: 14.52 V
Temperature: 14.4°C
Temperature: 18.0°C
Temperature: -31.5°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06435 572 55250
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4002
Hex Value: 0x00FF
Hex Value: 0xFF93
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AJ
Component: A4 Klimaautomat 2831
Coding: 00000
Shop #: WSC 00000
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul ECE 0503
Coding: 00001
Shop #: WSC 06314
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M00AYMNY
Coding: 0033622
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 R
Component: Lenksáulenmodul 0701
Coding: 00041
Shop #: WSC 00000
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 900 R HW: 8E0 920 900 R
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0022141
Shop #: WSC 00000 785 00200
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BM
Component: Komfortgerát T3B 2431
Coding: 03707
Shop #: WSC 06314
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 1215
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
1 Fault Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01001
Shop #: WSC 06314
End ---------------------------------------------------------------------
