Bueno pues e realizado la instlalacion del bluetooth pero no me funciona, pongo una descripcion de mi coche,
Audi a3 8P 3p
RNS-E
Volante Multifincion
Bluetooth (Recien puesto)(no funciona)
El rns-e me dice que no hay telefono configurado.
os pongo los errores que me da el vag com por si sirve de ayuda.
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
Shop #: WSC 06314 000 00000
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0762280C2
Coding: E9801F065002020100
Shop #: WSC 03650 572 64157
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 114
Mileage: 52357 km
Time Indication: 0
Date: 2010.11.19
Time: 16:25:59
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 114
Mileage: 52357 km
Time Indication: 0
Date: 2010.11.19
Time: 16:25:59
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 74
Mileage: 52357 km
Time Indication: 0
Date: 2010.11.19
Time: 18:59:37
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 H HW: 8P0 035 192 H
Component: RNS-E HIGH EU H73 0650
Revision: 02S Serial number: AUZBZ7F0014425
Coding: 0209715
Shop #: WSC 21240 142 52030
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 49141 km
Time Indication: 0
Date: 2010.09.07
Time: 12:26:52
Freeze Frame:
Mileage: 49140 km
Count: 709
Clock: 12:26
02005 - Coding Pin
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 49141 km
Time Indication: 0
Date: 2010.09.07
Time: 12:26:52
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209715
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 49141 km
Time Indication: 0
Date: 2010.09.07
Time: 12:26:52
Freeze Frame:
Mileage: 49140 km
Count: 709
Clock: 12:26
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 212
Mileage: 49141 km
Time Indication: 0
Date: 2010.09.07
Time: 12:26:52
Address 77: Telephone Labels: None
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005233415
Coding: 0011855
Shop #: WSC 00000 000 00000
4 Faults Found:
01042 - Control Module; Not Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 114
02503 - Output Wire to Radio
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 114
01523 - Microphone for Telephone (R38)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 114
Mileage: 52357 km
Time Indication: 0
Date: 2010.11.19
Time: 17:07:46
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 52357 km
Time Indication: 0
Date: 2010.11.19
Time: 19:21:29
