Hola;
Haber quien me puede ayudar,ya que llevo durante unos dias con problemas en mi a3 tdi 130cv.Pues ahora no m ecierra el maletero ni me lo abre el cierre centralizado,aunke suena el motor...y tampoco me cierra la puerta conductor..cuando cojo algun bache o algo,se me abre,osea,sin abrirse de todo,pero ya me da error de puerta abierta.Le he pasado el vag com...si alguien puede indicarme las solucciones...
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 CK
Component: 1,9l R4 EDC G400SG 1243
Coding: 00002
Shop #: WSC 06435
WAUZZZ8LZ1A015720 AUZ7Z0Y1553412
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E
Component: ESP FRONT MK60 0103
Coding: 0019970
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 931 J
Component: AB-KOMBIINSTR. VDO D12
Coding: 03142
Shop #: WSC 03765
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15183
Shop #: WSC 03765
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
3 Faults Found:
01377 - Ultra Sonic Sensor for Alarm System: Left (G170)
27-10 - Implausible Signal - Intermittent
01378 - Ultra Sonic Sensor for Alarm System: Right (G171)
31-00 - Open or Short to Ground
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
End -------------------------------------------------------
Ahora he borrado todos los errores y hace unos dias le he cambiado la bateria.Graciassss
Un saludo a todo el foro,gracias
Hola;
>>> hola, lo que comentas me pasó a mi tb, es problema de un relé que lleva la apertura del maletero, tienes que soltar el paño del portón y pegar unos golpecitos en el relé para que se despegue, no se si será o no tu caso, pero yo lo solucioiné asi, y hasta hoy no me ha vuelto a fallar.
Hola;
Gracias por contestar a los 2.UNNOCANTABRO,cuando te refieres al paño del porton,es sacarle la carcasa que cubre la cerradura del porton del maletero no?? El relé tiene alguna inscripcion? Graciasss
Un slaudo a todo el foro
>>>>> El paño del portón es la carcasa plástica de dentro, (ten especial cuidado al sacarlo, ya que va con grapas y es facil cascarlas) (expr propia), una vez lo tengas quitado, verás una varilla que es la que es accionada para abrir y cerrar la puerta, pues bien, en uno de sus exremos lleva el citado relé, es una cajita negra, no tiene duda posible... espero se te solucione asi.
Pd- Una pregunta, al dar al boton de la llave de abrir el maletero escuchas el ruido de abrir? Lo que te he indicado es si no escuchas ningun ruido, como si no tuviese pila el mando...
Suerte amigo...
Pd2- Necesito ayuda para escoger un kit de xenon, no sé cual escoger,se que de 6000k, pero no se ni que marca ni a quien ni nada... se lee tanto sobre ello que es un lio. Mi A3 es del 2001, el del foco de una pieza, si sabes algo me harias un favor.
Gracias
X UNNOCANTABRO
Gracias amigo,por contestar.Pero de xenon...ni ideaa,...lo sientooo.Pues veras...yo pulso apertura o cierre en el mando..y siempre me cierra y abre las puertas sin problema...solo no cierra el maletero....aunke suena el aparato k esta debajo del foco trasero izquierdo,tanto para apertura...como cierre.revisare el relé,ojala sea la soluccion
