Avanterado Publicado 27 de Diciembre del 2010 Denunciar Publicado 27 de Diciembre del 2010 Buenas, alguien me puede ayudar a descifrar lo que me ha salido con el vag-com: Monday,27,December,2010,11:27:06:13314 VCDS Version: Release 908.0 Data version: 20090911 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8D - Audi A4 B5 Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 Mileage: 200170km/124379miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 038 906 012 AH Component: 1,9l R4 EDC 0000SG 2827 Coding: 00002 Shop #: WSC 06325 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl Part No: 8E0 614 111 AB Component: ABS 5.3 FRONT D00 Shop #: BB 24548 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl Part No: 8D0 820 043 M Component: A4 KLIMAAUTOMAT D56 Coding: 00043 Shop #: WSC 06325 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.lbl Part No: 8D0 959 655 J Component: Airbag Front+Seite 1001 Coding: 00106 Shop #: WSC 06325 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-920-xxx-17.lbl Part No: 8D0 920 930 M Component: KOMBI+WEGFAHRS. M73 D10 Coding: 00140 Shop #: WSC 00000 Part No: Ident Component: Nr. Wegfahrs.:AUZ5Z0X9185041 Ident.-Nr. Wegfahrs.:AUZ5Z0X9185041 2 Faults Found: 00667 - Ambient Temperature Signal 29-10 - Short to Ground - Intermittent 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8D0 862 257 B Component: ZV-Pumpe, Funk D12 Coding: 12865 Shop #: WSC 06325 1 Fault Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - End --------------------------------------------------------------------- Responder
Avanterado Publicado 28 de Diciembre del 2010 Autor Denunciar Publicado 28 de Diciembre del 2010 Buenas, alguien que me ayude a descifrar los errores que me da el vag-com por favor? Gracias Responder
Avanterado Publicado 29 de Diciembre del 2010 Autor Denunciar Publicado 29 de Diciembre del 2010 Una ayudita por favor, algún consumo eléctrico tiene que cuando está una semana parado no arranca. Le pasé el vag-com y me salieron esos erores pero no los se interpretar. Alguien qe me ayude? Garcis. Responder
mariscal Publicado 30 de Diciembre del 2010 Denunciar Publicado 30 de Diciembre del 2010 (editado) airbag: 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent Instrumentos: 2 Faults Found: 00667 - Ambient Temperature Signal 29-10 - Short to Ground - Intermittent 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent Cierre centralizado: 1 Fault Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) Para saber que es cada cosa, entra en herramientas del idioma de google y traducelos para asi saber en español la traduccion. TE sera muy util. Asi sabras de que puede ser A mi me paso que me marcaba fallo del airbag. Con desconectar la bateria, soltar la ficha del airbag que falla y volver a enchufar airbag y bateria, pasar vag-com se soluciono. un saludo Editado 30 de Diciembre del 2010 por mariscal Responder
Athabasco Publicado 30 de Diciembre del 2010 Denunciar Publicado 30 de Diciembre del 2010 Tendrias que borrarlos y volver a pasar el vag-com. Salen como "intermitentes" y puede que alguno no lo tengas ya. Si te fijas casi todos son por causas electricas y pueden estar ocasionados por esa falta de bateria al cabo del tiempo. Mira de hacerlo con la bateria cargada, los borras y lo vuelves a pasar a ver. S2 Responder
