josett20 Publicado 2 de Enero del 2011 Denunciar Publicado 2 de Enero del 2011 Buenas, el vag me da estos errores: 01221 - Crash Sensor Side Airbag; Driver Side (G179) 65-10 - Unauthorized - Intermittent 01222 - Crash Sensor Side Airbag; Passenger Side (G180) 65-10 - Unauthorized - Intermittent Si apago el airbag del acompañante, el simbolo airbag off se mantiene encendido, creo que asi descarto qe sea de la centralita, podrian ser los conectores de debajo del asiento?? a alguien le a pasado esto?Graciassss Responder
C_B_M Publicado 3 de Enero del 2011 Denunciar Publicado 3 de Enero del 2011 01221 - Crash Sensor Side Airbag; Driver Side (G179) 01221 - Crash Sensor Side Airbag; Driver Side (G179): Faulty 01221 - Crash Sensor Side Airbag; Driver Side (G179): Open Circuit / Short to Plus Possible Symptoms * Airbag Warning Light ON Possible Causes * Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179) faulty * Crash Sensor Side Airbag; Driver Side (G179) faulty * Airbag Control Module (J234) faulty Possible Solutions * Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179) * Replace Crash Sensor Side Airbag; Driver Side (G179) * Replace Airbag Control Module (J234) 01221 - Crash Sensor Side Airbag; Driver Side (G179): No or Incorrect Basic Setting / Adaptation Possible Symptoms * Airbag Warning Light ON Possible Causes * Wrong Crash Sensor Side Airbag; Driver Side (G179) installed Possible Solutions * Install correct Crash Sensor Side Airbag; Driver Side (G179) Special Notes The Crash Sensors can be checked by using the control module identification and the measuring blocks. Address 15: Airbags Controller: 1T0 909 605 Component: 05 AIRBAG VW62 0506 2112 Coding: 0012341 The 0506 in this example stands for the required Crash Sensor ID, the first 2 digits (05) apply for the front crash sensors, while the second 2 digits (06) apply for the rear crash sensors. The ID of the currently installed Crash Sensors can be determined by checking Measuring Value Block (MVB) 009. 01221 - Crash Sensor Side Airbag; Driver Side (G179): Implausible Signal Possible Symptoms * Airbag Warning Light ON Possible Causes * Wrong/Incompatible Crash Sensor Side Airbag; Driver Side (G179) installed * Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179) faulty Possible Solutions * Check Crash Sensor Side Airbag; Driver Side (G179) Part Number o Install correct Crash Sensor Side Airbag; Driver Side (G179) * Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179) Retrieved from "http://wiki.ross-tech.com/wiki/index.php/01221" Category: Fault Codes Responder
C_B_M Publicado 3 de Enero del 2011 Denunciar Publicado 3 de Enero del 2011 01222 - Crash Sensor Side Airbag; Passenger Side (G180) 01221 - Crash Sensor Side Airbag; Passenger Side (G180): Faulty 01221 - Crash Sensor Side Airbag; Passenger Side (G180): Open or Short to Plus Possible Symptoms * Airbag Warning Light ON Possible Causes * Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Passenger Side (G180) faulty * Crash Sensor Side Airbag; Passenger Side (G180) faulty * Airbag Control Module (J234) faulty Possible Solutions * Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Passenger Side (G180) * Replace Crash Sensor Side Airbag; Passenger Side (G180) * Replace Airbag Control Module (J234) 01222 - Crash Sensor Side Airbag; Passenger Side (G180): No or Incorrect Basic Setting / Adaptation Possible Symptoms * Airbag Warning Light ON Possible Causes * Wrong Crash Sensor Side Airbag; Passenger Side (G180) installed Possible Solutions * Install correct Crash Sensor Side Airbag; Passenger Side (G180) Special Notes The Crash Sensors can be checked by using the control module identification and the measuring blocks. Address 15: Airbags Controller: 1T0 909 605 Component: 05 AIRBAG VW62 0506 2112 Coding: 0012341 The 0506 in this example stands for the required Crash Sensor ID, the first 2 digits (05) apply for the front crash sensors, while the second 2 digits (06) apply for the rear crash sensors. The ID of the currently installed Crash Sensors can be determinded by checking Measuring Value Block (MVB) 009. 01222 - Crash Sensor Side Airbag; Passenger Side (G180): Implausible Signal Possible Symptoms * Airbag Warning Light ON Possible Causes * Wrong/Incompatible Crash Sensor Side Airbag; Passenger Side (G180) installed * Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Passenger Side (G180) faulty Possible Solutions * Check Crash Sensor Side Airbag; Passenger Side (G180) Part Number o Install correct Crash Sensor Side Airbag; Passenger Side (G180) * Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Passenger Side (G180) Retrieved from "http://wiki.ross-tech.com/wiki/index.php/01222" Category: Fault Codes Responder
