Hola!
Hoy ha sido un dia de coche...y hace un rato, para finalizar y tras meses parado, he usado el VAG-COM. Al principio lo he tenido que volver a instalar y activar y cuando ya tenía esto listo, le he dado a escanear el coche y me ha salido lo siguiente:
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Skipping Address 15-Airbags
Address 35 -------------------------------------------------------
Controller: 8LO 862 257
Component: ZV-Pumpe, DWA, Funk D03
Coding: 13162
Shop #: WSC 65535
24 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm: Open
01362 - Close Switch for Tailgate/Trunk (F124)
01363 - Switch for Central Locking: Driver's Door (F59)
27-00 - Implausible Signal
01364 - Switch for Central Locking: Passenger Door (F114)
01365 - Lock/Unlock Switch: Interior
28-00 - Short to B+
01389 - Tailgate Open Switch (F124)
22307 - Unknown Error Code
Unknown - 70-10 - Cylinder 3 - Intermittent
23331 - Unknown Error Code
Unknown - 02-00 - Signal Shorted to Ground
23587 - Unknown Error Code
Unknown - 103-10 - Unknown Error Elaboration - Intermittent
24099 - Unknown Error Code
Unknown - 39-00 - Output won't Switch or Short to Ground
23075 - Unknown Error Code
Unknown - 01-00 - Signal Shorted to B+
22819 - Unknown Error Code
Unknown - 01-10 - Signal Shorted to B+ - Intermittent
22563 - Unknown Error Code
Unknown - 38-10 - Output won't Switch or Short to B+ - Intermittent
Address 45 -------------------------------------------------------
Controller: 8L0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 06313
1 Fault Found:
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
End -------------------------------------------------------
Me podría decir alguien si está bien pasado el vag com? y de ser así, qué es todo lo que me aparece ahi? es que no tengo ni papa!! jajaja.
Sinceramente, tan sólo lo había usado para activar funciones pero jamás lo había escaneado, y la antigua propietaria dudo mucho que lo hubiese hecho...así que ya veis todo lo que aparece ahi!! B)
Un saludo y gracias!
Editado por macut0
Hola!
Coding: 13162
Shop #: WSC 65535
24 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
28-00 - Short to B+
Coding: 00001
Shop #: WSC 06313
1 Fault Found:
35-00 - -
borra los errores y escanea otra vez,por que si no an escaneado en años se quedan ahi acumulados y casi todo lo que veo es de la alarma del coche que a saltado por diferentes motivos...y lo que te sale de
a mi hermano en el a3 que tenia tambien le sali pero no tenia nada mal,,solo que llevaba otra alarma aparte de la de serie y al abrir el coche y cerrar marca como cieere a positivo o negativo,pero eso lo marca como averia intermitente y no influye en el funcionamiento del coche,,
Buenas.
Que va, no le he metido mano alguna, se lo compré a una chica de Vigo y desde que lo tengo (casi un año) tan sólo he retocado estéticamente, en breves le tocará motor pero ná de ná, lo único con vag-com activar el cierre confort y el pitido de la alarma al cerrar y abrir el coche.
Otra cosa que hice fue cambiar el tapizado completo del techo por un restyling (incluidos los pilares laterales con los volumétricos de la alarma), será de eso que da tantos fallos de la alarma? por no poner los volumétricos que tenía antes y meter unos nuevos?
Te veo muchos errores por ahí ¿no? ¿le has metido mano al coche por todos los lados? Never mind!!!!. Bueno aquí te pongo un enlace, a ver si sacas algo en claro. S2
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
