macut0 Publicado 9 de Abril del 2011 Denunciar Compartir Publicado 9 de Abril del 2011 (editado) Hola! Hoy ha sido un dia de coche...y hace un rato, para finalizar y tras meses parado, he usado el VAG-COM. Al principio lo he tenido que volver a instalar y activar y cuando ya tenía esto listo, le he dado a escanear el coche y me ha salido lo siguiente: VAG-COM Version: Release 311.2-N Chassis Type: 8L - Audi A3/S3 Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Skipping Address 15-Airbags Address 35 ------------------------------------------------------- Controller: 8LO 862 257 Component: ZV-Pumpe, DWA, Funk D03 Coding: 13162 Shop #: WSC 65535 24 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - 01366 - Opened Due to Crash Signal 35-00 - - 01361 - Switch for Anti-Theft Alarm: Close 29-00 - Short to Ground 01360 - Switch for Anti-Theft Alarm: Open 29-00 - Short to Ground 01362 - Close Switch for Tailgate/Trunk (F124) 29-00 - Short to Ground 01363 - Switch for Central Locking: Driver's Door (F59) 27-00 - Implausible Signal 01364 - Switch for Central Locking: Passenger Door (F114) 27-00 - Implausible Signal 01365 - Lock/Unlock Switch: Interior 29-00 - Short to Ground 01365 - Lock/Unlock Switch: Interior 28-00 - Short to B+ 01389 - Tailgate Open Switch (F124) 29-00 - Short to Ground 22307 - Unknown Error Code Unknown - 70-10 - Cylinder 3 - Intermittent 23331 - Unknown Error Code Unknown - 02-00 - Signal Shorted to Ground 23587 - Unknown Error Code Unknown - 103-10 - Unknown Error Elaboration - Intermittent 24099 - Unknown Error Code Unknown - 39-00 - Output won't Switch or Short to Ground 23075 - Unknown Error Code Unknown - 01-00 - Signal Shorted to B+ 22819 - Unknown Error Code Unknown - 01-10 - Signal Shorted to B+ - Intermittent 22563 - Unknown Error Code Unknown - 38-10 - Output won't Switch or Short to B+ - Intermittent Address 45 ------------------------------------------------------- Controller: 8L0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 06313 1 Fault Found: 01380 - Alarm triggered by Anti-Theft Sensor: Rear Left 35-00 - - End ------------------------------------------------------- Me podría decir alguien si está bien pasado el vag com? y de ser así, qué es todo lo que me aparece ahi? es que no tengo ni papa!! jajaja. Sinceramente, tan sólo lo había usado para activar funciones pero jamás lo había escaneado, y la antigua propietaria dudo mucho que lo hubiese hecho...así que ya veis todo lo que aparece ahi!! B) Un saludo y gracias! Editado 9 de Abril del 2011 por macut0 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
MICHELS3 Publicado 9 de Abril del 2011 Denunciar Compartir Publicado 9 de Abril del 2011 Hola! Hoy ha sido un dia de coche...y hace un rato, para finalizar y tras meses parado, he usado el VAG-COM. Al principio lo he tenido que volver a instalar y activar y cuando ya tenía esto listo, le he dado a escanear el coche y me ha salido lo siguiente: VAG-COM Version: Release 311.2-N Chassis Type: 8L - Audi A3/S3 Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Skipping Address 15-Airbags Address 35 ------------------------------------------------------- Controller: 8LO 862 257 Component: ZV-Pumpe, DWA, Funk D03 Coding: 13162 Shop #: WSC 65535 24 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - 01366 - Opened Due to Crash Signal 35-00 - - 01361 - Switch for Anti-Theft Alarm: Close 29-00 - Short to Ground 01360 - Switch for Anti-Theft Alarm: Open 29-00 - Short to Ground 01362 - Close Switch for Tailgate/Trunk (F124) 29-00 - Short to Ground 01363 - Switch for Central Locking: Driver's Door (F59) 27-00 - Implausible Signal 01364 - Switch for Central Locking: Passenger Door (F114) 27-00 - Implausible Signal 01365 - Lock/Unlock Switch: Interior 29-00 - Short to Ground 01365 - Lock/Unlock Switch: Interior 28-00 - Short to B+ 01389 - Tailgate Open Switch (F124) 29-00 - Short to Ground 22307 - Unknown Error Code Unknown - 70-10 - Cylinder 3 - Intermittent 23331 - Unknown Error Code Unknown - 02-00 - Signal Shorted to Ground 23587 - Unknown Error Code Unknown - 103-10 - Unknown Error Elaboration - Intermittent 24099 - Unknown Error Code Unknown - 39-00 - Output won't Switch or Short to Ground 23075 - Unknown Error Code Unknown - 01-00 - Signal Shorted to B+ 22819 - Unknown Error Code Unknown - 01-10 - Signal Shorted to B+ - Intermittent 22563 - Unknown Error Code Unknown - 38-10 - Output won't Switch or Short to B+ - Intermittent Address 45 ------------------------------------------------------- Controller: 8L0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 06313 1 Fault Found: 01380 - Alarm triggered by Anti-Theft Sensor: Rear Left 35-00 - - End ------------------------------------------------------- Me podría decir alguien si está bien pasado el vag com? y de ser así, qué es todo lo que me aparece ahi? es que no tengo ni papa!! jajaja. Sinceramente, tan sólo lo había usado para activar funciones pero jamás lo había escaneado, y la antigua propietaria dudo mucho que lo hubiese hecho...así que ya veis todo lo que aparece ahi!! B) Un saludo y gracias! borra los errores y escanea otra vez,por que si no an escaneado en años se quedan ahi acumulados y casi todo lo que veo es de la alarma del coche que a saltado por diferentes motivos...y lo que te sale de Unknown - 01-10 - Signal Shorted to B+ - Intermittent 22563 - Unknown Error Code Unknown - 38-10 - Output won't Switch or Short to B+ - Intermittent a mi hermano en el a3 que tenia tambien le sali pero no tenia nada mal,,solo que llevaba otra alarma aparte de la de serie y al abrir el coche y cerrar marca como cieere a positivo o negativo,pero eso lo marca como averia intermitente y no influye en el funcionamiento del coche,, Responder Enlace al comentario Compartir en otros sitios web More sharing options...
C_B_M Publicado 9 de Abril del 2011 Denunciar Compartir Publicado 9 de Abril del 2011 Te veo muchos errores por ahí ¿no? ¿le has metido mano al coche por todos los lados? Never mind!!!!. Bueno aquí te pongo un enlace, a ver si sacas algo en claro. S2 http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes Responder Enlace al comentario Compartir en otros sitios web More sharing options...
macut0 Publicado 9 de Abril del 2011 Autor Denunciar Compartir Publicado 9 de Abril del 2011 Buenas. Que va, no le he metido mano alguna, se lo compré a una chica de Vigo y desde que lo tengo (casi un año) tan sólo he retocado estéticamente, en breves le tocará motor pero ná de ná, lo único con vag-com activar el cierre confort y el pitido de la alarma al cerrar y abrir el coche. Otra cosa que hice fue cambiar el tapizado completo del techo por un restyling (incluidos los pilares laterales con los volumétricos de la alarma), será de eso que da tantos fallos de la alarma? por no poner los volumétricos que tenía antes y meter unos nuevos? Un saludo. Te veo muchos errores por ahí ¿no? ¿le has metido mano al coche por todos los lados? Never mind!!!!. Bueno aquí te pongo un enlace, a ver si sacas algo en claro. S2 http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes Responder Enlace al comentario Compartir en otros sitios web More sharing options...
