melkorcete Publicado 12 de Julio del 2011 Denunciar Publicado 12 de Julio del 2011 Hola buenas tengo un problema con mi audi a3 tdi 130cv, el turbo no salta cuando debe y se quedan las luces de averia y esp encendidas. Aqui os pongo un log hecho con vag com, por favor ayudenme que estoy totalmente perdio gracias de antemano!! VAG-COM Version: Release 311.2-N Chassis Type: 8L - Audi A3/S3 Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56 Address 01 ------------------------------------------------------- Controller: 038 906 019 CK Component: 1,9l R4 EDC 0000SG 1477 Coding: 00002 Shop #: WSC 06435 WAUZZZ8L22A048013 AUZ5Z0AN260175 2 Faults Found: 17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus P1256 - 35-10 - - - Intermittent 16955 - Brake Switch (F): Implausible Signal P0571 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 1C0 907 379 E Component: ESP FRONT MK60 0104 Coding: 0019970 Shop #: WSC 06435 2 Faults Found: 00526 - Brake Light Switch-F 008 - Implausible Signal - Intermittent 01435 - Brake Pressure Sensor 1 (G201) 008 - Implausible Signal - Intermittent Address 08 ------------------------------------------------------- Controller: 8L0 820 043 H Component: A Note: Excessive Comm Errors Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8L0 920 900 M Component: KOMBI+WEGFAHRS. M73 D07 Coding: 04140 Shop #: WSC 02231 WAUZZZ8L22A048013 AUZ5Z0AN260175 No fault code found. Address 35 ------------------------------------------------------- Controller: 8L0 862 257 K Component: ZV-Pumpe, Funk D11 Coding: 12864 Shop #: WSC 06435 4 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01389 - Tailgate Open Switch (F124) 29-00 - Short to Ground 00991 - Interior Lights 28-00 - Short to B+ 00958 - Key 4 09-00 - Adaptation Limit Surpassed End ------------------------------------------------------- Responder
melkorcete Publicado 13 de Julio del 2011 Autor Denunciar Publicado 13 de Julio del 2011 Hay alguien que tenga solucion? solo a los fallos del esp por favor GRACIAS! Responder
Lingote Publicado 14 de Julio del 2011 Denunciar Publicado 14 de Julio del 2011 Cambia el sensor del pedal de freno, borra los fallos y comprueba al cabo de unos kms, a ver si vuelve a darte fallos. S2. Responder
Rogerdm Publicado 23 de Agosto del 2011 Denunciar Publicado 23 de Agosto del 2011 me pasa lo mismo. He hecho un auto-scan con el vag-com y me sale el mismo fallo e intermitentemente se me enciende el testigo del ESP. Puede ser el interruptor de la luz de freno? adjunto un documento que nos puede servir http://www.clubseatleon.net/downloads.php?view=detail&df_id=41 Responder
Schummy Publicado 24 de Agosto del 2011 Denunciar Publicado 24 de Agosto del 2011 Puede ser no??!!! ES. Fallan como una escopeta de feria estos interruptores del pedal de freno. Responder
MICHELS3 Publicado 24 de Agosto del 2011 Denunciar Publicado 24 de Agosto del 2011 viendo el scan el interruptor del pedal de freno esta mal vale unos 12 o 15 euros y se cambia en 2 minutos..aparte de eso sale el sensor de temperatura del refrigerante mal tambien,es barato y facil de cambiar igualmente...lo del pedal de freno es lo que causa el que se te encienda la luz de abs y esp al quedarse enganchado y coche detectar como si fueras frenando todo el rato ,ojo mira las luces de freno con el coche en marcha,que suelen pasar 2 cosas cuando va mal,o que pisas y no se encienden,o si falla quedandose enganchado las llevas todo el rato encendidas...saludos Responder
Schummy Publicado 24 de Agosto del 2011 Denunciar Publicado 24 de Agosto del 2011 Yo me he encontrado hasta por llevar una bombilla fundida o por una bombilla cambiada y puesta otra incorrecta que te aparezca este código de avería, más que nada por el consumo de las bombillas. Lo verificaría también antes de ir a por el interruptor. Saludos. Responder
