manuel-a3vigo Publicado 27 de Julio del 2011 Denunciar Publicado 27 de Julio del 2011 Hola tengo un a5 3.0tdi 2008 y me da todos estos fallos. Le doy a borrar pero siguen.Alguien entiende algo? VCDS Version: Release 10.6.3 Data version: 20101206 Wednesday,27,July,2011,00:11:51:36838 Chassis Type: 8T0 Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53 55 56 57 6C 77 VIN: WAUZZZ8T29A000425 Mileage: 47940km/29788miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Sporadic communication error 1000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Sporadic communication error 1000 57-TV Tuner -- Status: Sporadic communication error 1000 6C-Back-up Cam. -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine (J623-CCWA) Labels: None Part No SW: 8K2 907 401 A HW: 8K1 907 401 A Component: 3.0TDI EDC17 H01 0003 Revision: --H01--- Coding: 0114002C180F0128 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM30TDI8K2907401A A01003 ROD: EV_ECM30TDI8K2907401A.rod VCID: 2B5E1B28F383 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD Component: ESP8 quattro H04 0060 Revision: -------- Serial number: -------------- Coding: 1B4500 Shop #: WSC 06325 000 00000 VCID: 7BFEEB684363 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 AD HW: 8K0 907 064 AD Component: BCM2 1.1 H71 0134 Revision: 00002001 Coding: 070000 Shop #: WSC 06325 000 00000 VCID: 72E0C64C1429 Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H35 0039 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb Part No SW: 8T0 035 730 HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 331DM087523761 Coding: 0005004 Shop #: WSC 00264 572 51802 VCID: EED8523C8011 Part No: 8T0 919 609 C Component: E0380 BedienteilH08 0100 2 Faults Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 124 Mileage: 47602 km Time Indication: 0 Date: 2011.07.21 Time: 15:22:16 03157 - Functionality limited due to Communications Disruption 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 139 Mileage: 47949 km Time Indication: 0 Date: 2011.07.26 Time: 21:30:52 Freeze Frame: Bin. Bits: 00000000 10000000 Bin. Bits: 00000000 10000000 Bin. Bits: 00000000 00000000 Bin. Bits: 00000000 00000000 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AB HW: 8T1 820 043 AB Component: KLIMA 3 ZONEN H06 0140 Revision: C0000000 Serial number: 0129.04.080551 Coding: 36020000 Shop #: WSC 06325 000 00000 VCID: 71E2C940112F No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 C HW: 8K0 907 063 C Component: BCM1 1.0 H21 0253 Revision: 04021001 Serial number: 00000000133512 Coding: 260050914034AF211409000000005D5D0F9C038800010141000000 Shop #: WSC 06325 000 00000 VCID: 2F660F38C79B Part No SW: 8T1 955 119 C HW: 8J1 955 119 Component: WWS 140408 H13 0040 Coding: 00FD11 Part No SW: 8K0 955 559 HW: 8K0 955 559 Component: RLS H04 0003 Coding: 02532C Part No SW: 8K0 941 531 G HW: 8K0 941 531 G Component: E1 - LDS H07 0070 2 Faults Found: 03110 - Active Steering Control Module (J792) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 139 Mileage: 47949 km Time Indication: 0 Date: 2011.07.26 Time: 21:39:00 03207 - Charisma Switch Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 139 Mileage: 47906 km Time Indication: 0 Date: 2011.07.26 Time: 16:21:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 8T1 035 110 C HW: 8T1 035 110 C Component: MP3-Changer H41 0390 Revision: 00041001 Serial number: AUZ5ZBH8407997 Shop #: WSC 00000 000 00000 VCID: 2A501E2CFC79 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 C HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0010 Revision: 11001001 Serial number: 75230811715809 Coding: 300003 Shop #: WSC 00264 572 90116 VCID: 3972316009DF No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H26 0410 Serial number: 0038JD157WUW Coding: 30313433363030303030554A304C38543053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C7C287406ED Driver's Airbag Crash Sensor: Serial number: 6334MSME3A2027704 Passenger Side Airbag Crash Sensor: Serial number: 6344MSME336370084 Driver's Rear Airbag Crash Sensor: Serial number: 6352QSME6649417BP Passenger's Rear Airbag Crash Sensor: Serial number: 6362QSME627412077 Driver's Front Airbag Crash Sensor: Serial number: 63732SME634C48610 Passenger's Front Airbag Crash Sensor: Serial number: 63832SME5F7C0E15G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H12 0013 Revision: -------- Serial number: 90315HE80007M Coding: 000016 Shop #: WSC 06325 000 00000 VCID: 3D7A25701DF7 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8T0 920 931 A HW: 8T0 920 931 A Component: KOMBIINSTR. H28 0221 Revision: 00200000 Serial number: 71X13XE58 Coding: 0F0D010006000008050000 Shop #: WSC 06325 000 00000 VCID: 356A3D5025C7 1 Fault Found: 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 139 Mileage: 47949 km Time Indication: 0 Date: 2011.07.26 Time: 23:47:21 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 K HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0092 Revision: EB302042 Serial number: 4200E08425844B Coding: 000303 Shop #: WSC 06325 000 00000 VCID: 499241A0593F Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H03 0150 6 Faults Found: 02077 - Media Player Position 2 (R119) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 47602 km Time Indication: 0 Date: 2011.07.21 Time: 15:05:42 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 124 Mileage: 47602 km Time Indication: 0 Date: 2011.07.21 Time: 15:16:10 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 47602 km Time Indication: 0 Date: 2011.07.21 Time: 15:25:31 00467 - TV Tuner (R78) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 47602 km Time Indication: 0 Date: 2011.07.21 Time: 15:28:27 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 7 Fault Frequency: 7 Reset counter: 177 Mileage: 47644 km Time Indication: 0 Date: 2011.07.22 Time: 00:51:00 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 6 Reset counter: 175 Mileage: 47644 km Time Indication: 0 Date: 2011.07.22 Time: 03:51:00 ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H15 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 06325 000 00000 VCID: 2B5E1B28F383 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 M Component: MNS ECE H51 1060 Revision: 00000000 Serial number: 333EO087565610 Shop #: WSC 00264 572 51802 VCID: 3B7E2B6803E3 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 HW: 8K0 959 793 Component: TSG FA H09 0149 Revision: Serial number: –r Coding: 011C122250002201 Shop #: WSC 00264 572 51802 VCID: FDFA6570DD77 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 AD HW: 8K0 907 064 AD Component: BCM2 1.1 H71 0134 Revision: 00002001 Serial number: 0110742081 Coding: 01000E80003904C5012000 Shop #: WSC 06325 000 00000 VCID: 72E0C64C1429 Part No SW: 8R0 959 591 HW: 8R0 959 591 Component: J245EE16SKB10 H01 0180 1 Fault Found: 03233 - Controls for Garage Door Opener (E284) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 126 Mileage: 47644 km Time Indication: 0 Date: 2011.07.21 Time: 22:25:13 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-ASM.clb Part No SW: 8T0 035 223 AD HW: 8T0 035 223 G Component: DSP STD H08 0300 Revision: S2600000 Coding: 010101 Shop #: WSC 06325 000 00000 VCID: 70E4CC441A25 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 HW: 8K0 959 792 Component: TSG BF H09 0149 Revision: Serial number: 0‰ Coding: 011C122250002201 Shop #: WSC 00264 572 90116 VCID: FCFC6874C66D No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb Part No SW: 8K0 907 801 D HW: 8K0 907 801 D Component: EPB Audi B8 H04 0050 Revision: 00000003 Serial number: 00000000117399 Shop #: WSC 00000 000 00000 VCID: 30640C44DAA5 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8K0-907-357.clb Part No: 8K0 907 357 B Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 06324 000 00000 VCID: 346C00542EBD No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 L Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 336EX087558335 Coding: 0000001 Shop #: WSC 06325 000 00000 VCID: 31620940D1AF No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 E HW: 4E0 919 148 Component: R78 TVHybridDVB 0470 Revision: R0H06000 Serial number: 76300801493601 Coding: 0000201 Shop #: WSC 06325 000 00000 VCID: 254AED109567 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl Part No SW: 8T0 907 441 B HW: 4L0 907 441 A Component: J772__Rearview 0070 Revision: --H12--- Serial number: 525PA8-J81908N Coding: 1020008 Shop #: WSC 00264 572 51802 VCID: 377637583FCB No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached Responder
pacoalvarez135 Publicado 29 de Julio del 2011 Denunciar Publicado 29 de Julio del 2011 Tu tienes sintonizador de televisión en el coche?? Que cosas le has activado al coche? El ADS por lo que veo seguro. Responder
manuel-a3vigo Publicado 29 de Julio del 2011 Autor Denunciar Publicado 29 de Julio del 2011 (editado) Si señor tengo tv, El otro dia actualice el MMI(para ver los mapas en 3d y demas) y tambien active varias cosillas on el vag com como ADS.El problema es que ahora no me funciona el bloetooth ni los botones correspondiantes del volante.Gracias. Editado 29 de Julio del 2011 por manuel-a3vigo Responder
manuel-a3vigo Publicado 30 de Julio del 2011 Autor Denunciar Publicado 30 de Julio del 2011 Ademas quiero entrar en el modulo del telefono y no me deja.Tengo el cable 10.6 y el vag com 10.6.3, gracias Responder
manuel-a3vigo Publicado 30 de Julio del 2011 Autor Denunciar Publicado 30 de Julio del 2011 (editado) El archivo codinglog es en el que salen las modificaciones que he realizado?Como hago para ponerlo como estaba? Los datos que me salen son: Address 17:8T0 920 931 A recoded (Long Coding) from 0F05010002000008050000 to 0F0D010002000008050000 (06325/000/00000) Thursday,21,July,2011,21:41:45:36838 Address 46:8K0 907 064 AD recoded (Long Coding) from 01000E80003904C5012000 to 01000E80003944C5012000 (06325/000/00000) Thursday,21,July,2011,22:25:14:36838 Address 09:8K0 907 063 C recoded (Long Coding) from 260050914034AF010009000000005D5D0F1C038800010141000000 to 260050914034AF210409000000005D5D0F1C038800010141000000 (06325/000/00000) Tuesday,26,July,2011,16:21:04:36838 Address 09:8K0 907 063 C recoded (Long Coding) from 260050914034AF210409000000005D5D0F1C038800010141000000 to 260050914034AF310409000000005D5D0F9C038800010141000000 (06325/000/00000) Tuesday,26,July,2011,21:39:01:36838 Address 09:8K0 907 063 C recoded (Long Coding) from 260050914034AF310409000000005D5D0F9C038800010141000000 to 260050914034AF210409000000005D5D0F9C038800010141000000 (06325/000/00000) Tuesday,26,July,2011,21:43:56:36838 Address 09:8K0 907 063 C recoded (Long Coding) from 260050914034AF210409000000005D5D0F9C038800010141000000 to 260050914034AF010409000000005D5D0F9C038800010141000000 (06325/000/00000) Tuesday,26,July,2011,21:46:31:36838 Address 09:8K0 907 063 C recoded (Long Coding) from 260050914034AF010409000000005D5D0F9C038800010141000000 to 260050914034AF011409000000005D5D0F9C038800010141000000 (06325/000/00000) Tuesday,26,July,2011,21:48:47:36838 Address 09:8K0 907 063 C recoded (Long Coding) from 260050914034AF011409000000005D5D0F9C038800010141000000 to 260050914034AF111409000000005D5D0F9C038800010141000000 (06325/000/00000) Tuesday,26,July,2011,21:54:00:36838 Address 09:8K0 907 063 C recoded (Long Coding) from 260050914034AF111409000000005D5D0F9C038800010141000000 to 260050914034AF211409000000005D5D0F9C038800010141000000 (06325/000/00000) Tuesday,26,July,2011,21:55:27:36838 Address 56:4E0 910 541 T recoded (Short coding) from 0000001 to 0000011 (06325/000/00000) Tuesday,26,July,2011,22:00:04:36838 Address 46:8K0 907 064 AD recoded (Long Coding) from 01000E80003944C5012000 to 01040E80003944C5012000 (06325/000/00000) Tuesday,26,July,2011,22:05:30:36838 Address 17:8T0 920 931 A recoded (Long Coding) from 0F0D010002000008050000 to 0F0D010003000008050000 (06325/000/00000) Tuesday,26,July,2011,22:09:53:36838 Address 17:8T0 920 931 A recoded (Long Coding) from 0F0D010003000008050000 to 0F0D010002000008050000 (06325/000/00000) Tuesday,26,July,2011,22:10:31:36838 Address 46:8K0 907 064 AD recoded (Long Coding) from 01040E80003944C5012000 to 01000E80003944C5012000 (06325/000/00000) Tuesday,26,July,2011,23:44:49:36838 Address 17:8T0 920 931 A recoded (Long Coding) from 0F0D010002000008050000 to 0F0D010006000008050000 (06325/000/00000) Tuesday,26,July,2011,23:47:22:36838 Address 17:8T0 920 931 A recoded (Long Coding) from 0F0D010006000008050000 to 0F0D010007000008050000 (06325/000/00000) Tuesday,26,July,2011,23:49:59:36838 Address 52:8K0 959 792 recoded (Long Coding) from 011C122250002201 to 011E122250002201 (00264/572/90116) Tuesday,26,July,2011,23:53:12:36838 Address 52:8K0 959 792 recoded (Long Coding) from 011E122250002201 to 011C122250002201 (00264/572/90116) Tuesday,26,July,2011,23:55:46:36838 Address 46:8K0 907 064 AD recoded (Long Coding) from 01000E80003944C5012000 to 01000E80003904C5012000 (06325/000/00000) Tuesday,26,July,2011,23:59:25:36838 Address 17:8T0 920 931 A recoded (Long Coding) from 0F0D010007000008050000 to 0F0D010006000008050000 (06325/000/00000) Wednesday,27,July,2011,00:00:26:36838 Address 17:8T0 920 931 A recoded (Long Coding) from 0F0D010006000008050000 to 0F0D010002000008050000 (06325/000/00000) Wednesday,27,July,2011,09:47:27:36838 Address 56:4E0 910 541 T recoded (Short coding) from 0000001 to 0000011 (06325/000/00000) Wednesday,27,July,2011,16:46:48:36838 -Despues me sale otro adp log: Address 09:8K0 907 063 C channel 64 adapted from 2 to 4 Tuesday,26,July,2011,16:23:37:36838 Address 09:8K0 907 063 C channel 64 adapted from 4 to 4 Tuesday,26,July,2011,16:24:39:36838 Address 09:8K0 907 063 C channel 63 adapted from 2 to 4 Tuesday,26,July,2011,16:25:05:36838 Address 09:8K0 907 063 C channel 65 adapted from 2 to 4 Tuesday,26,July,2011,16:25:44:36838 Address 09:8K0 907 063 C channel 66 adapted from 2 to 4 Tuesday,26,July,2011,16:26:04:36838 Address 07:8T0 035 730 channel 8 adapted from 0 to 1 Tuesday,26,July,2011,21:23:18:36838 Address 46:8K0 907 064 AD channel 63 adapted from 40 to 44 Tuesday,26,July,2011,22:07:42:36838 Editado 30 de Julio del 2011 por manuel-a3vigo Responder
manuel-a3vigo Publicado 12 de Agosto del 2011 Autor Denunciar Publicado 12 de Agosto del 2011 Problema del bluetooth arreglado,simplemente era la actualizacion del mmi.Resulta que lo actualice el otro dia y me dejo de funcionar el bluetooth.Le meti el cd 2 que corresponde al tlfn y listo.Gracias a todos. Responder
labombadiesel Publicado 14 de Agosto del 2011 Denunciar Publicado 14 de Agosto del 2011 Me parece que has activado con el vagcom más cosas de las que tienes, o que no has terminado de actualizar el mmi con los cds y tienes que pasar alguno todavía alguna vez más... Responder
