Quimicefa Publicado 31 de Julio del 2011 Denunciar Publicado 31 de Julio del 2011 Hola, a ver si alguien con servotronic me puede aclarar una duda. Yo no tengo MMI y he cambiado en el byte 8 los bits 1 y 2, y ahora la dirección se endurece bastanta incluso yendo despacio; pero el bit 2 es para los que tengan dirección dinámica ¿habría que poner el bit 4 en vez del 2? [code][09 - Cent Elect.]Byte 7 -> Bit 5 change 0 to 1Byte 8 Bit 0 Change 0 to 1 - Enable Engine/Gearbox (Improved throttle response and puts tranny into "S" mode when "D" is selected)Byte 8 Bit 1 Change 0 to 1 - Enable Dynamic Steering (Definitely stiffens steering on my car - a lot)Byte 8 Bit 2 Change 0 to 1 - Enable Engine (Improved throttle response - Not completely sure if I can feel a significant change)Byte 8 Bit 3 Change 0 to 1 - Enable Suspension (useless for cars w/o ads suspension)Byte 8 Bit 4 Change 0 to 1 - Enable Steering (not quite sure, doesn't really affect steering on my car)Byte 8 Bit 5 Change 0 to 1 - Enable Sports Differential (useless without sports diff installed)[security Access - 16] [Adaptation - 10] -> Channel 63 -> Change to [see below][security Access - 16] [Adaptation - 10] -> Channel 64 -> Change to [see below][security Access - 16] [Adaptation - 10] -> Channel 65 -> Change to [see below][security Access - 16] [Adaptation - 10] -> Channel 66 -> Change to [see below](all four channels must have the same value)1 = Comfort2 = Auto (Factory default)3 = Dynamic[/code] Responder
Quimicefa Publicado 31 de Julio del 2011 Autor Denunciar Publicado 31 de Julio del 2011 Vaya lio! en otro foro leo lo siguiente: [code]Byte 8 Bit 0 Change 0 to 1 - Enable Engine/Gearbox (This bit enables throttle response control)Byte 8 Bit 1 Change 0 to 1 - Enable Steering (This bit enables steering response control)Byte 8 Bit 2 Change 0 to 1 - Enable Engine On MMI Menu (If equipped) Byte 8 Bit 4 Change 0 to 1 - Enable Steering On MMI Menu (If equipped)[/code] ¿Entonces son los bits 0 y 1 los que tengo que activar? Además en varios sitios activan el byte 17 bit 7 y en otros no?¿Es imprescindible?¿Para que sirve? Responder
156SW Publicado 1 de Agosto del 2011 Denunciar Publicado 1 de Agosto del 2011 Mira esto te será mas fácil Si no teneis MMI haced esta configuración que quedará permanente y solo podras cambiar via cable Vagcom Paso 1.- Coding 09-Central electric: for carisma engine only Byte 7, bit 5, change 0 to 1 Byte 8, bit 2, change 0 to 1 Byte 17, bit 7, change 0 to 1 Después codifica los canales 63,64,65 y 66 (antes esto no era posible sin hacer el paso 1) [09 – Cent. Elect.] [security Access - 16] [Adaptation - 10] -> Channel 63 change to 03 [Adaptation - 10] -> Channel 64 change to 03 [Adaptation - 10] -> Channel 65 change to 03 [Adaptation - 10] -> Channel 66 change to 03 3 = Dynamic 1 = Comfort, 2 = Auto (default), 3 = Dynamic, 4 = Individual. Modificando el valor que he puesto en rojo, podeis poner el modo que querais: 1 = Comfort, 2 = Auto (default), 3 = Dynamic Espero que este más claro, un saludo. Responder
Quimicefa Publicado 1 de Agosto del 2011 Autor Denunciar Publicado 1 de Agosto del 2011 Gracias por responder, ¿tienes el coche como yo, sin navegador? Por que cuanto más leo más lio tengo; al principio sólo cambié el Byte 7, bit 5 y el Byte 8, bit 1, y con eso la dirección se nota mucho más dura a bajas velocidades, eso con los canales 63, 64, 65 y 66 en 2. Ahora me faltaría saber si para el motor es el Byte 8, bit 0 o 2 o ambos. Los he estado probando y no noto cambio en la respuesta del motor como si la noté en la dirección. Responder
156SW Publicado 1 de Agosto del 2011 Denunciar Publicado 1 de Agosto del 2011 (editado) Mira yo tengo mmi con navegación y también me ha costado lo mío configurarlo ,según entiendo lo primero que tienes que hacer es esto for carisma engine only Byte 7, bit 5, change 0 to 1 Byte 8, bit 2, change 0 to 1 Byte 17, bit 7, change 0 to 1 Y después los canales lo que modificas es todo en conjunto no por separado si te fijas son 3 opciones 1 = Comfort, 2 = Auto (default), 3 = Dynamic esto es lo que tienes que poner en los cuatro canales pero todos iguales Si te fijas en el ejemplo usa el numero 3 modo dinámico [09 – Cent. Elect.] [security Access - 16] [Adaptation - 10] -> Channel 63 change to 03 [Adaptation - 10] -> Channel 64 change to 03 [Adaptation - 10] -> Channel 65 change to 03 [Adaptation - 10] -> Channel 66 Chante to 03 Por si las moscas preguntale a pacoalvarez el compi controla estará liao con algo pero enviale un mp y seguro te lo soluciona Editado 1 de Agosto del 2011 por 156SW Responder
Quimicefa Publicado 2 de Agosto del 2011 Autor Denunciar Publicado 2 de Agosto del 2011 Mira yo tengo mmi con navegación y también me ha costado lo mío configurarlo ,según entiendo lo primero que tienes que hacer es esto for carisma engine only Byte 7, bit 5, change 0 to 1 Byte 8, bit 2, change 0 to 1 Byte 17, bit 7, change 0 to 1 Y después los canales lo que modificas es todo en conjunto no por separado si te fijas son 3 opciones 1 = Comfort, 2 = Auto (default), 3 = Dynamic esto es lo que tienes que poner en los cuatro canales pero todos iguales Si te fijas en el ejemplo usa el numero 3 modo dinámico [09 – Cent. Elect.] [security Access - 16] [Adaptation - 10] -> Channel 63 change to 03 [Adaptation - 10] -> Channel 64 change to 03 [Adaptation - 10] -> Channel 65 change to 03 [Adaptation - 10] -> Channel 66 Chante to 03 Por si las moscas preguntale a pacoalvarez el compi controla estará liao con algo pero enviale un mp y seguro te lo soluciona Gracias jefe, voy a probar que tampoco pierdo nada, activaré el byte 17 bit 7 y voy a dejar el Byte 8 0000111 a ver que pasa; la verdad es que con el navegador se solucionan un montón de problemas, que pena no saberlo en su momento. Responder
labombadiesel Publicado 3 de Agosto del 2011 Denunciar Publicado 3 de Agosto del 2011 Un consejo, si no tienes MMI yo dejaría la dirección en Auto y el motor o en Auto o en Dynamic, aunque seguramente dejar también el motor en Auto sea lo más sensato, ya que en ciudad elmotor en dynamic se hace demasiado reactivo y agresivo, por lo menos a mi. Responder
Quimicefa Publicado 4 de Agosto del 2011 Autor Denunciar Publicado 4 de Agosto del 2011 Un consejo, si no tienes MMI yo dejaría la dirección en Auto y el motor o en Auto o en Dynamic, aunque seguramente dejar también el motor en Auto sea lo más sensato, ya que en ciudad elmotor en dynamic se hace demasiado reactivo y agresivo, por lo menos a mi. Gracias por el consejo, voy a dejarlo todo en auto -de hecho ya lo tengo pero no se si funciona la parte del motor- , he leido por otro foro que debían ponerse en los bits 63, 64, 65 y 66 los mismos valores (pero de "fabrica" venía el 63 en 1 y los 64, 65 y 66 en 2 o sea que a saber si es verdad) Responder
txio Publicado 9 de Agosto del 2011 Denunciar Publicado 9 de Agosto del 2011 aupi, yo tengo mmi, pero no es ni 2 g ni 3g, es el concer. aki se podrian poner los 3 modos? o tendrias q configurar con el cable solo el q kieres?? Responder
txio Publicado 9 de Agosto del 2011 Denunciar Publicado 9 de Agosto del 2011 y si pondria los botones, podria hacerlo? o necesito tb navegador? Responder
156SW Publicado 9 de Agosto del 2011 Denunciar Publicado 9 de Agosto del 2011 Mira esto con mmi 2g http://www.audisport-iberica.com/foro/index.php?/topic/222944-codificaciones-vagcom-a5/page__st__435 Responder
txio Publicado 9 de Agosto del 2011 Denunciar Publicado 9 de Agosto del 2011 ok, ya he mirado ese enlace, entonces yo tendria q pones la configuracion pero no el menu, noo? pq el mio no tiene navegador, el mio es audi concert Responder
Quimicefa Publicado 16 de Agosto del 2011 Autor Denunciar Publicado 16 de Agosto del 2011 Eso creo yo, al menos lo de la dirección sí se nota; la mejora es el motor la verdad es que no la aprecio, pero puede que se pequeña y no me entere. Responder
labombadiesel Publicado 16 de Agosto del 2011 Denunciar Publicado 16 de Agosto del 2011 la mejora en el motor igual no la notas ya que igual no se te ha activado, y esto es así ya que dependiendo del coche la codificación que hay que meter para el motor es una u otra. Es decir, en - Central Electric / byte 8 , el modo de motor en algunos coches se activa poniendo valor "1" en el Bit "0" en vez de en el bit "2", como por ejemplo pasa en mi coche... Responder
Quimicefa Publicado 19 de Agosto del 2011 Autor Denunciar Publicado 19 de Agosto del 2011 Yo creo que por eso es mejor activarlos ambos, no debería de causar ningún problema...de hecho lo hice en su momento y tampoco noté diferencia (activé los bits 0, 1 y 2), pero repito que como uso el coche poco no le tengo cogido el tacto de lo que anda como para que lo note si la diferencia es pequeña. Responder
