Fiti Publicado 1 de Agosto del 2011 Denunciar Publicado 1 de Agosto del 2011 Muy buenas, acabo de instalarme el Tempomat siguiendo el brico qeu tenemos aquí en nuestro foro, la parte mecánica facilísima y rápida, el problema ha venido al hacer el autoscan e intentar borrar errores, me sale todo esto: 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door,Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (------CABA) Labels: 06H-907-115-CAB.clb Part No SW: 8K1 907 115 B HW: 8K1 907 115 Component: 1.8l R4/4V TF H07 0001 Revision: A5H07--- Coding: 0104000318070120 Shop #: WSC 02145 785 00200 3 Faults Found 4698 - Function Restriction due to Received Malfunction Value U1113 00 [039] Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Mileage: 26816 km Date: 2008.02.08 Time: 00:30:52 4699 - Function Restriction due to Received Malfunction Value U1113 00 [039] Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Mileage: 26816 km Date: 2008.02.08 Time: 00:30:52 7150 - Please Check DTC Memory of Steering Wheel Electronics P1698 00 [039] Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Mileage: 26816 km Date: 2008.02.08 Time: 00:30:52 Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 P HW: 8K0 907 379 P Component: ESP8 front H04 0180 Revision: -------- Serial number: -------------- Coding: 010500 Shop #: WSC 02399 823 56573 2 Faults Found 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 2 Reset counter: 124 Mileage: 26816 km Time Indication: 0 Date: 2008.02.08 Time: 00:25:14 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x07A2 Hex Value: 0x001E Hex Value: 0x2A96 Hex Value: 0x00FF 00778 - Steering Angle Sensor (G85) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 124 Mileage: 26816 km Time Indication: 0 Date: 2010.08.01 Time: 12:11:30 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x00A2 Hex Value: 0x001E Hex Value: 0x2395 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 A HW: 8K0 907 064 A Component: BCM2 1.1 H70 0134 Revision: 00002001 Coding: 030100 Shop #: WSC 02399 823 56573 Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H35 0039 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 8T1 820 043 N HW: 8T1 820 043 N Component: KLIMA 1 ZONE H05 0120 Coding: 64000000 Shop #: WSC 02399 823 56573 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 C HW: 8K0 907 063 C Component: BCM1 1.0 H21 0253 Revision: 04021001 Serial number: 00000000026334 Coding: 26005091411400000001000000001D0D4F1C030800010001000000 Shop #: WSC 00987 572 91243 Part No SW: 8K1 955 119 HW: 8T1 955 119 Component: WWS 130408 H06 0060 Coding: 00FD11 Part No SW: 8K0 941 531 B HW: 8K0 941 531 B Component: E1 - LDS H07 0070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H26 0410 Serial number: 0038JD14R36+ Coding: 30343434363030303030554A304C384B3053 Shop #: WSC 02145 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 E HW: 8K0 953 568 E Component: Lenks.Modul H11 0012 Revision: -------- Serial number: 90304HDE000DZ Coding: 000006 Shop #: WSC 06335 000 00000 1 Fault Found 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 2 Reset counter: 124 Mileage: 26816 km Time Indication: 0 Date: 2008.02.08 Time: 00:37:56 Freeze Frame: (no units): 44.0 Text: 2CFFFFFF9BFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFFC0FFFFFFFF Angle: 560° Raw, Index/Key Err.: 255 255 000 Text: 3EFFFFFF83000035323636FFFFFFFF Ign. Timing: 30.0 °BTDC Mass Flow: -104.97 g/s Count: 65280 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 930 A HW: 8K0 920 930 A Component: KOMBIINSTR. H15 0221 Revision: 00000000 Serial number: 7BU21HF48 Coding: 0F0F080002000008050000 Shop #: WSC 00987 572 91243 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 H HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0091 Revision: GB102039 Serial number: 3900G08402895A Coding: 000303 Shop #: WSC 02399 823 56573 Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H03 0150 No fault code found. Y aquí se para el VAG_COM y me dice qeu no puede seguir. Que hago????? :conf: :conf: La verdad es que estoy acojo...o Saludossssssssssssssss B) Responder
Fiti Publicado 2 de Agosto del 2011 Autor Denunciar Publicado 2 de Agosto del 2011 Todo solucionado, era simplemente calibrar el sensor del ángulo de la dirección G85 y listo. Me ha costado, pero al final listo. Otro más con Tempomat. Desde aqui agradecer a todos los que desinteresadamente me habéis ayudado, sois unos máquinas. Saludossssssssssssss B) Responder
Rushifuru Publicado 2 de Agosto del 2011 Denunciar Publicado 2 de Agosto del 2011 Me alegro Fiti :clap1: Un Saludo!! Responder
paul2008 Publicado 7 de Agosto del 2011 Denunciar Publicado 7 de Agosto del 2011 Todo solucionado, era simplemente calibrar el sensor del ángulo de la dirección G85 y listo. Me ha costado, pero al final listo. Otro más con Tempomat. Desde aqui agradecer a todos los que desinteresadamente me habéis ayudado, sois unos máquinas. Saludossssssssssssss B) Compi, Me alegro que ya lo tengas ok!!! Como has calibrado G85? Saludos! Responder
Chity Publicado 8 de Agosto del 2011 Denunciar Publicado 8 de Agosto del 2011 Todo solucionado, era simplemente calibrar el sensor del ángulo de la dirección G85 y listo. Me ha costado, pero al final listo. Otro más con Tempomat. Desde aqui agradecer a todos los que desinteresadamente me habéis ayudado, sois unos máquinas. Saludossssssssssssss B) Me alegro muchisimo Fiti que ya lo tengas montado, ahora a disfrutarlo, ya veras como le das uso en los viajes largos y es una gozada. Un saludo . Responder
arcancelo Publicado 8 de Agosto del 2011 Denunciar Publicado 8 de Agosto del 2011 Todo solucionado, era simplemente calibrar el sensor del ángulo de la dirección G85 y listo. Me ha costado, pero al final listo. Otro más con Tempomat. Desde aqui agradecer a todos los que desinteresadamente me habéis ayudado, sois unos máquinas. Saludossssssssssssss B) Me alegro muchisimo Fiti que ya lo tengas montado, ahora a disfrutarlo, ya veras como le das uso en los viajes largos y es una gozada. Un saludo . Hola Fiti, Me puedes decir la referencia de las manetas que tenías y las que pusiste además de los extras de tu coche? Responder
Fiti Publicado 29 de Agosto del 2011 Autor Denunciar Publicado 29 de Agosto del 2011 Todo solucionado, era simplemente calibrar el sensor del ángulo de la dirección G85 y listo. Me ha costado, pero al final listo. Otro más con Tempomat. Desde aqui agradecer a todos los que desinteresadamente me habéis ayudado, sois unos máquinas. Saludossssssssssssss B) Compi, Me alegro que ya lo tengas ok!!! Como has calibrado G85? Saludos! Gracias Paul. Voy a intentar explicarlo en el post del brico del montaje del Tempomat que puso Kantusjack, a ver si tengo un ratillo y me lío con ello. Todo solucionado, era simplemente calibrar el sensor del ángulo de la dirección G85 y listo. Me ha costado, pero al final listo. Otro más con Tempomat. Desde aqui agradecer a todos los que desinteresadamente me habéis ayudado, sois unos máquinas. Saludossssssssssssss B) Me alegro muchisimo Fiti que ya lo tengas montado, ahora a disfrutarlo, ya veras como le das uso en los viajes largos y es una gozada. Un saludo . Una maravilla, probado estas vacaciones y de lujo, Gracias Chity. Todo solucionado, era simplemente calibrar el sensor del ángulo de la dirección G85 y listo. Me ha costado, pero al final listo. Otro más con Tempomat. Desde aqui agradecer a todos los que desinteresadamente me habéis ayudado, sois unos máquinas. Saludossssssssssssss B) Me alegro muchisimo Fiti que ya lo tengas montado, ahora a disfrutarlo, ya veras como le das uso en los viajes largos y es una gozada. Un saludo . Hola Fiti, Me puedes decir la referencia de las manetas que tenías y las que pusiste además de los extras de tu coche? La referencia de las que tenía era esta: 8K0 953 502C 4PK y la que puse es esta: 8K0 953 502D 4PK Lo mejor para que no tengas problemas al ponerla es ir al conce con el número de bastidor y ellos te dicen cual es tu referencia exacta. Saludossssssssssssssssss B) Responder
zZarZiLLoSs Publicado 24 de Septiembre del 2012 Denunciar Publicado 24 de Septiembre del 2012 (editado) Desde luego hay cosas que no entiendo, en mi caso también estoy mirando el tema del Tempomat y me dieron esa misma referencia estoy buscando por Ebay y he encontrado algo pero va sin las manetas de regulación. http://www.ebay.es/i...ME:B:SS:ES:1123 8K0 953 502 D 4PK ==> MANETA 8K0 953 512 E 6PS ==> CARCASA Quiero pensar que es un error del vendedor. Editado 24 de Septiembre del 2012 por zZarZiLLoSs Responder
arcancelo Publicado 24 de Septiembre del 2012 Denunciar Publicado 24 de Septiembre del 2012 Desde luego hay cosas que no entiendo, en mi caso también estoy mirando el tema del Tempomat y me dieron esa misma referencia estoy buscando por Ebay y he encontrado algo pero va sin las manetas de regulación. http://www.ebay.es/i...ME:B:SS:ES:1123 8K0 953 502 D 4PK ==> MANETA 8K0 953 512 E 6PS ==> CARCASA Quiero pensar que es un error del vendedor. Suena a error del vendedor. A mí me pasó cuando compré la mía. Había un tipo en ebay que me vendía una con la referencia que a mí me valía pero la maneta realmente tenía otra diferente. Dile que te mande una foto de la etiqueta donde viene la referencia de la pieza. De todas formas, si la foto se corresponde con la maneta real que tiene en venta, es obvio que no te vale. Responder
