  • Respuestas 202
En la sección de bricos del subforo tienes bastante información sobre el tema:
http://www.audisport...1-bricos-a6-4f/
Y en dicha sección bricos específicos:
http://www.audisport...page__hl__brico
los e leido y releido y leido y releidothumbsup.gif gracias de todas formas
bueno aqui os pongo el manual de instalacion de la caja controladora de los leds s6 marca TEAM APT
Instruction manual APT‐S Light module with Audi‐S6‐day driving lights Stand:Juni 2011
© 2011, TeamAPT Page 1 von 4 Version 2.0.0
INSTRUCTION MANUAL:
APT‐S Light module
with AUDI S6‐daylights
Inhaltsverzeichnis
‐ Description Site: 1
‐ Scope of supply Site: 2
‐ To the installation required material / tools Site: 3
‐ Installation Site: 3 ‐ 4
‐ Functional control Site: 5
‐ Mistake removal Site: 5
‐ Technical data company tesion Site: 5
‐ Contact Site: 5
‐ Disclamier of liability Site: 5
Description:
The APT‐ S Light module is a microprocessor‐steered control which is required to the legal company by day
driving lights (TFL) according to model of Audi or Porsche. This module must be switched before the TFL,
with it the technical decrease give can become. APT‐ S Light module steers the brightness and the switch
states of the lights by means of pulse width modulation (PWM). It owns the general TFL functions (in, from
and gedimmt in each case depending on switch state), a sidelight as well as a Coming Home function.
© 2011, TeamAPT Page 2 von 4 Version 2.0.0
Scope of supply
belong to the scope of supply:
‐ APT‐ S Light module
‐ 10kΩ potentiometer
‐ operating instructions (topical download: www.teamapt.de)
‐ protection holder and protection 3A
‐ cable in different colours and lengths 0,75mm2 or thicker
‐ soldering iron incl. accessories, chandelier clips or quick links
‐ shrink tubing/insulating tape
‐ screwdriver
‐ other assembly material
‐ Perhaps, multimeter / test lamp
Installation:
Before the installation of APT‐ S Light module must be clamped for the prevention against short circuits,
the plus by the battery. In addition, you had to do all pipelines which you move, mark around mistakes to
exclude. With the installation must be absolutely respected to the right polarity. Wrong connected inlets
can lead to the destruction of the TFL control. The pipelines in the APT‐S Light module are bundled up after
entrances and exits. The thick bundle the entrances (are red, blue, violet, brown, green‐red, black‐andwhite,
grey, chartreuse, yellow, yellow‐blue) and the thin bundle the exits (blue red‐white, knows, black).
Kurzbez. Beschreibung Kabelfarbe
Entrances
+12V tension care with preprotection directly from battery red
Mass mass of measures directly to the battery or on a mass point blue
On a lasting switch on of the TFL violet
Zünd. Ignition signal brown
Standl. R sidelight on the right from the right sidelight put on one side green –red
Standl. L of sidelight on the left from the left sidelight put on one side black‐white
ZV of the indicator or directly from ZV grey
+P plus 5 V for Poti yellow‐green
SP chartreuse signal SP of Poti to the control yellow
‐P mass for Poti yellow‐blue
exits
PIN3 TFL R/L PLUS for both day driving lights Red‐ white
PIN1 TFL R/L Mass signal for both day driving lights blue
PIN2 TFL R PWM for the right day driving light knows mass white
PIN2 TFL L PWM for the left day driving light black
The day driving lights after the manufacturer's default
insert in the front bumper. (Info: www.teamapt.de)
insert APT‐ S Light module (preferential under the
steering wheel disguising near the clip box).
The TFL according to plan connect which lay pipelines to
the APT‐S Light module and connect after plan.
Long‐term plus of the battery or from the clip box put on
one side. A preprotection (3A vehicle protection or fine
protection) add and for a manual disconnection of the
system TFL a main switch (optionally) connect and
connect everything in the red cable.
Mass of the battery or from a mass point (clamp board)
put on one side and in the blue cable connect.
In an entrance (violet management) connect the signal of
the not more required fog lamp counter now or insert an
extra counter if the vehicle none fog lamp had.
In the ignition lock or in the clamp board measure the ignition signal and in the brown cable of the control
connect.
In the plus management of the right sidelight measure the signal and in the green‐red cable of APT‐ S
Light module connect.
In the plus management of the left sidelight measure the signal and in the black‐and‐white cable of APT‐ S
Now must be still inserted of the Poti to the brightness adjustment in the gedimmten state. Connect
moreover simply the Poti like in the switch plan illustrated to the control. The Poti can be appropriated
under the steering wheel disguising where he is inaccessible after unique adjusting of the brightness, or
somewhere in the vehicle where he is well accessible. Thus the brightness can be also shifted any time.
The installation of APT‐ S Light module is concluded. Before the positive pole of the battery is connected
again, all connections should be checked for her right connection. This step is very important, because
wrong connected connections with short circuits, false functions or for the damage / destruction of the
module can lead. In addition, all junctions with shrink tubing or insulating tape must be isolated. If you
have checked everything and have connected the plus again in the battery, can be begun with the
functional control.
Functional control
1‐st ignition switch on: ? both TFL shine ungedimmt.
2‐nd light switch on: ? both TFL switch over to gedimmten mode.
3‐rd light from and ignition from: ? both TFL switch off.
4‐th sidelight in: ? both TFL shine in the gedimmten mode.
5‐th sidelight on the right in: ? the right TFL shines in the gedimmten mode.
6‐th sidelight on the left in: ? the left TFL shines in the gedimmten mode.
7‐th sidelights from: ? none of the TFL shines
8‐th open or lock: ? both TFL shine approx. 30 seconds
If a false function has appeared, the mistake removal helps you.
Mistake removal
‐ If a switch state does not function, control the connections of the entrances.
‐ If the TFL instead of gedimmt do not shine at all, take an adjustment in the Poti before.
‐ If the TFL flicker, move the pipelines on another way. Move the pipelines far from sturgeon springs
(ignition, generator, …)
‐ If nothing at all functions, control the inlets, the protection as well as the connection of the TFL.
Technical data company tension
Company tension: 12 V – 30 V DC
Stream admission ges.: 1.5A*
Standby‐stream admission: 100 mA
exits: 12 V – 30 V DC / 1A
*Im company with Audi S6‐day driving lights. Depends in the essentials on the used day driving lights.
Contact
Anschrift: TeamAPT www.teamapt.de
Obere Gasse 1‐2 Specialists für TFL ‐ Technic
74542 Orlach
disclaimer of liability
the installation of this control happens on own danger. The observance of these operating instructions, as well as the
contact and the methods by installation, company, servicing and use of the product cannot be supervised by the
TeamAPT. Hence, TeamAPT takes over no liability for losses, damages or costs which arise by faulty or careless use or
company or hang together in any way with it. In spite of high high‐class claims with construction, manufacturing and
test of the product and the provided accessories false functions are not to be excluded completely. For from it
originating losses, damages or costs TeamAPT takes over no liability.
Te va a quedar de vicio.......... :notworthy: :notworthy:
Tengo unas ganas de verlo terminado...... :drooling: :drooling: :drooling: :drooling:
jejejej gracias, con que quede la mitad de bonito que el tuyo me conformolaugh.gif
