Buenas tardes compañeros!
Este fin de semana que estoy liado con el coche (aunque la lie parda!! :p) en el tema de cuadros, he rescatado un informe del VAGCOM y me aparecen varios errores pero desconozco que importancia tienen estos. A ver si me podeis echar una manita. Graciasssssss!!
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 A
Component: 1,9l R4 EDC 0000SG 2801
Coding: 00002
Shop #: WSC 06435
3 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 M
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 900 B
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 00140
Shop #: WSC 04561
Ident.-Nr. Wegfahrs.:AUZ5Z0Y0052
5 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
01128 - Immobilizer Pickup Coil (D2)
01176 - Key
07-10 - Signal to Low - Intermittent
00562 - Sensor for Oil Level/Temperature (G266)
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 K
Component: ZV-Pumpe, Funk D11
Coding: 12900
Shop #: WSC 06435
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
End -------------------------------------------------------
pero animal, :bsh1: ,jjajaja borra los fallos depues de cambiar el cuadro,son todos por el cambio de cuadro o casi todos,primero borra todos te das una vuelta con el coche y escaneas de nuevo y si sigue saliendo alguno ya lo posteas...un saludo
Jajajajajajajaja OK OK ASI lo hare y despues posterare los errores que aparezcan!! :thumbsup:
No te volvió a aparecer ningun DTC después de la que liaste??? Jijiji.
no creo los fallos eran todos del cuadro excepto el del cierre que suele salir de vez en cuando en casi todos los coches incluido el mio...saludos
