antonio63545 Publicado 12 de Septiembre del 2011 Denunciar Compartir Publicado 12 de Septiembre del 2011 ola, pues e echo un autochequeo con el vag-com y me ha dado estos errores, si alguno sabeis que es decirmelo para saberlos y arreglarlos: VCDS Version: Release 10.6.2 Data version: 20101123 Sunday,11,September,2011,16:41:59:36838 Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: Cannot be reached 1100 56-Radio -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKD.lbl Part No SW: 03G 906 021 LG HW: 03G 906 021 AN Component: R4 2,0L EDC G000SG 9828 Revision: --H07--- Serial number: AUX7Z0H0FNQ00Q Coding: 0000072 Shop #: WSC 06314 000 00000 VCID: 6FE6CF3841C71A64 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0023170 Shop #: WSC 06314 000 00000 VCID: 73EEC3482DEF3E84 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG Component: KlimavollautomatH19 0430 Revision: 241894 Serial number: 8P0820043AG Shop #: WSC 00000 000 00000 VCID: 71E2C94057F30C94 No fault code found. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
matrix Publicado 12 de Septiembre del 2011 Denunciar Compartir Publicado 12 de Septiembre del 2011 (editado) No te ha salido el escaneo completo si te das cuenta te faltan direcciones . Prueba a hacerlo de nuevo o si te sale lo mismo puede que tengas un problemas con el programa. Saludos. Editado 12 de Septiembre del 2011 por matrix Responder Enlace al comentario Compartir en otros sitios web More sharing options...
antonio63545 Publicado 14 de Septiembre del 2011 Autor Denunciar Compartir Publicado 14 de Septiembre del 2011 lo e vuelto a hacer de nuevo y me a salido lo mismo, de todas maneras esos tres errores que salen que son? si lo sabes dimelo para ver si lo puedo comprobar yo a mano, saludos. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
spaincardiagnosis Publicado 15 de Septiembre del 2011 Denunciar Compartir Publicado 15 de Septiembre del 2011 Antonio con lo que has puesto no se te puede decir nada. Entra en el módulo 9 que es el que esta en fallo pinchando 2 veces sobre el y copia el fallo que te da aqui. Entra en los módulos 16 y 19 igualmente pinchando 2 click sobre ellos y lo mismo copia el contenido del fallo aqui, sino es muy dificil ayudarte. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ToloR Publicado 3 de Octubre del 2011 Denunciar Compartir Publicado 3 de Octubre del 2011 Hola, ¿Has copiado y pegado de pantalla, o estás enviando el log? Al igual que matrix, creo que faltan líneas... Un saludo. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
antonio63545 Publicado 3 de Octubre del 2011 Autor Denunciar Compartir Publicado 3 de Octubre del 2011 Hola, ¿Has copiado y pegado de pantalla, o estás enviando el log? Al igual que matrix, creo que faltan líneas... Un saludo. ola, lo k pasa es k no le hace el chequeo completo no se porke, pero bueno eso es lo de menos porque yo lo k kiero solucionar es el error de la luz diurna k no la reconoce, porque le he cambiado los faros de halogeno a bixenon y los leds no los reconoce, tu sabrias arreglar eso? un saludo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ToloR Publicado 3 de Octubre del 2011 Denunciar Compartir Publicado 3 de Octubre del 2011 Hola, ¿Has copiado y pegado de pantalla, o estás enviando el log? Al igual que matrix, creo que faltan líneas... Un saludo. ola, lo k pasa es k no le hace el chequeo completo no se porke, pero bueno eso es lo de menos porque yo lo k kiero solucionar es el error de la luz diurna k no la reconoce, porque le he cambiado los faros de halogeno a bixenon y los leds no los reconoce, tu sabrias arreglar eso? un saludo Hombre, si tienes vag-com y no hace el chequeo completo, no creo que sea lo de menos, pero allá tú. No sé cómo cambiar el tipo de faro, mira por el foro a ver. Creo que he leído algo de cambio y codificación con vag-com. Un saludo. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
antonio63545 Publicado 3 de Octubre del 2011 Autor Denunciar Compartir Publicado 3 de Octubre del 2011 Hola, ¿Has copiado y pegado de pantalla, o estás enviando el log? Al igual que matrix, creo que faltan líneas... Un saludo. ola, lo k pasa es k no le hace el chequeo completo no se porke, pero bueno eso es lo de menos porque yo lo k kiero solucionar es el error de la luz diurna k no la reconoce, porque le he cambiado los faros de halogeno a bixenon y los leds no los reconoce, tu sabrias arreglar eso? un saludo Hombre, si tienes vag-com y no hace el chequeo completo, no creo que sea lo de menos, pero allá tú. No sé cómo cambiar el tipo de faro, mira por el foro a ver. Creo que he leído algo de cambio y codificación con vag-com. Un saludo. no es k sea lo de menos, eske el coche es nuevo y lo del chequeo aora no me importa porque tiene 10.000 kilometros y no kreo k tenga muchos fallos tan pronto, de todas maneras es el 10.6.2 el ultimo k a salido. ya mirare por el foro aver si veo algo, muchas gracias de todas maneras, un saludo. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
