Hola buenas tardes, hoy por fin he conseguido "casi" codificar el RNS-E, ya que lo cambie hace unas dos semanas el pero de todo esto es:
Los errores son los que señalo:
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
* 19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
* 37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
* 56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
* 77-Telephone -- Status: Malfunction 0010
- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 8P0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H43 0311
Revision: H43 Serial number: 060411F2002873
Coding: 352102
Shop #: WSC 06314 000 00000
VCID: 33611BFF2BA5
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 254
Mileage: 8066 km
Time Indication: 0
Date: 2011.08.30
Time: 13:31:41
- Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0200
Revision: 0000012S Serial number: AUZBZ7LD203387
Coding: 0205755
Shop #: WSC 00184 211 17606
VCID: 346318E32EAB
2 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 127
Freeze Frame:
Mileage: 8060 km
Count: 3008
Clock: 13:46
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 37
Mileage: 8066 km
Time Indication: 0
Date: 2011.08.30
Time: 13:32:02
Freeze Frame:
Mileage: 8060 km
Count: 3008
Clock: 13:31
- Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205755
VCID: 346318E32EAB
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 127
Freeze Frame:
Mileage: 8060 km
Count: 3008
Clock: 13:46
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 37
Mileage: 8066 km
Time Indication: 0
Date: 2011.08.30
Time: 13:32:02
Freeze Frame:
Mileage: 8060 km
Count: 3008
Clock: 13:31
- Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005362365
Coding: 0011455
VCID: F4E358E3EE2B
1 Fault Found:
02503 - Output Wire to Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 127
Mileage: 8066 km
Time Indication: 0
Date: 2011.08.30
Time: 13:31:49
Haber si me podeis ayudar a solucionar estos fallos, ya que ha sido mi primera vez con el vagcom, y otra cosa al meterme en el modulo 19 (CAN Wategay), y darle al long coding la ventana se me va fuera de la pantalla del ordenador y no me deja tocarle a nada.
Muchas Gracias, perdonad por el tocho.
Alguno de los fallos es intermitente por haber tenido desconectada la antena o los cables del navegador y
Efectivamente tienes que entrar en el modulo 19 y dar de alta el navegador para que no te salga el error. Dale a clear all dtcs y vuelve a escanear los errores seran los reales. un saludo
Y como se da de alta el navegador???? yo es que lo cambie hace tiempo y me salen algunos de los fallos que comenta el compañero.
Saludos y gracias
Me reedito eso que hay que hacer es esto????
Si tienes vag-com lo puedes configurar tu mismo entrando en el modulo del navegador 37 y luego en codig lo configuras segun tengas volante multifunción manos libres etc.
si no puedes entrar quizas tengas que entrar primero en el modulo 19 cangateway y darlo de alta Byte 03 Bit 3 [37] Navegación. Saludos
Editado por jozee1889
¿Y como le doy de alta?, ya que al meterme en el modulo 19 me salia "Byte 0" y no me sale nada de navegacion. aparte de primeras me he podido meter bien en el modulo 19, pero luego no se lo que le a pasado que la ventana de "log coding" me ha desaparecido.
Muchas Gracias
