Buenas,
Un colega me deja un PC con el programa más el cable, me podéis decir si sabéis los BITS que hay que cambiar para poder anular el pitido cinturon + Cornering???
Si alguien sabe de más opciones o tiene un listado que me lo pase porfavor a f_menescal@hotmail.com
Gracias de antemanO!!!
  • Respuestas 45
  • 1 mes más tarde...
Guys,
I decided to start that topic to gather all the informations available across the inet in one place, I am starting that topic but it's more a community thing so everyone is welcome to contribute (I will try to keep the first post as up to date as possible)
Required Material to perform the mod :
- Laptop with Windows
- Hex + Can Cable Ross-Tech Genuine Cable
- VCDS Software
- Audi A1
To start here are the mods that are available and where to find them in the software (originally posted by mojito)
• [VCDS] DRL 100% And Rear LEDs
• Device 09-central electronics> coding> byte 11, bit 2
• The green indicator light on the light switch stays lit all the time when the DRL is. Also the map display in navigation • mode is dimmed for night usage all the time.
• [VCDS] Fog Turn Lights
• Enables fog cornering lights.
• Control unit "09-Central Electric">> "Encoding">> Byte 14, Bit 7
• Settings: 0 / 1
• Default: 0
• [VCDS] Disable Headlight Washers
• Control unit "09-Central Electric">> "Encoding">> Byte 20, Bit 5
• Values:
• 1: SRA available
• 0: SRA does not exist
• [VCDS] Indicator Soft Touch
• Sets the number of flash operations of soft touch turn signals
• Control unit "09-Central Electric">> "Adjustments">> "Comfort turn signal (Cycles)
• Adjustable: 1-5x
• Default value: 3 times
• [VCDS] Disable DRL Dimming When Indicating
• Disables the dimming (25%) of the LED daytime running lights flashing as the light level.
• Control unit "09-Central Electric">> "Encoding">> Byte 15, Bit 3
• Values:
• 1: Dimming active (default)
• 0: disable dimming.
• [VCDS] Coming & Leaving Home light Cycle
• Setting the operating time of coming and leaving home function.
• Control unit "09-Central Electric">> "Adjustments">> "Coming Home-Time" and "Leaving Home-Time"
• Possible burn times up to 60 seconds.
• Default values:
• Coming Home Time: 15 sec
• Leaving-Home Time: 60sec
• [VCDS] Needle Swoosh
• (VCDS) staging = pointer when you start
• `Address 17: go control panel insert> Customize> production and> active"
• Ignition off and on again to finish
• [VCDS] Seat Belt Warning Disable / Modify
• Disables the seat belt reminders
• Control unit "17-panel insert">> "Adjustments" Disable Seatbelt>>
• Adjustable: yes / no
• Default value: no
• [VCDS]Changes the seat belt warning
• Control unit "17-panel insert">> "Adjustments">> "Seatbelt"
• Adjustable Version 2 (normal) / Variant 3 (subjectively more aggressive)
• Default value: Variant 2
• [VCDS] Activate Rear LED Lights as DRLs (Xenons Only)
• The green indicator light on the light switch stays lit all the time. Also the map display in navigation mode is
• dimmed for night usage all the time.
• Control unit "09-Central Electric">> "Encoding">> Byte 18, Function 7, Change code 72 to 73 in long code
• Values:
• Bit 0 Enable.
• [VCDS] Deactivate Auto Rear Wiper on Reverse
• Control unit "09-Central Electric">> "Encoding">> Byte 21, Bit 6
• *Untested*
• [VCDS] Mirror Dipping on Reverse Active
• Control unit "Door Elec Passenger">> "Encoding">> Byte 4, Bit 2 and Bit 3
• *Untested*
• [VCDS] Siren Alarm Type (Changes Alarm Sound?)
• Control unit "09-Central Electric">> "Encoding">> Byte 6, Bit 1
That's a start I will add all the mod that I can find and you are welcome to send them to me by PM or on this topic and II will add them to the first post !
I will try to create a small how to for beginners as soon as I have time but if anyone want to help me you are more than welcome,
All the credits should go to Mojito who posted all the information on this forum ....
Editado por f_menescal
  • 5 semanas más tarde...
Hola f_menescal.Hice lo que me dijiste con los codigos que aparecen en ingles en este foro,entiendo que son estos a los que te refieres.Al intentar activar el cornering con dichos codigos lo que hace es dejar encendidas las luces antiniebla fijas con la luz diurna.Solo hace eso.Me comenta el mecanico de la casa audi que si son codigos de un coche ingles pueden dar estos problemas.Pongo las luces en automatico y tanpoco lo hace, ni con giro , marcha atras ni intermitentes.Espero que pudas ayudarme. Un saludo.(vag com casa oficial audi por medio de cable )
Se hace todo a traves de un cable... se connecta con el VAG-COM y se cambian las configuraciones arriba indicadas... todo es 0 y 1... :)
hola f, haber si cuando quedemos podemos meter el vag(si lo consiges), que yo quiero ponerle un par de cositas como te comente,salu2!!!!!!! :thumbsup:
Buenas,
Pues no lo entiendo, yo con el listado este lo hice y me funcionó a la primera.
Sobretodo debes comprobar que es la linea que toca y su BYT correspondiente... yo lo ví muy facil de hacer.
Has probado algun otro aparte del Cornering?
Saludos!
Pues no he intentado activar nada mas,puesto que es lo unico que me interesa.Coming Home y Leaving Home lo hace cuando pones las luces en auto.
¿Podrias hacerme el favor de indicarme exactamente el codigo que utlizaste y los pasos a seguir?Como si fuera un tutorial para principiantes.Gracias un saludo y FELICES FIESTAS
Ooooooooh ola chicos pongo noticias calentitas.
Ya me han llegado las luces Led matricula del A1 originales y sorpresaaaaaaa, viene todo entero no es una bombilla y además es estanco y al ir a montar lo esperado, los conectores para luces led son diferentes, ASI que ala otra vez a recambios a pedirlos y tocara hacer manualidades.
