  • Respuestas 384
Posted Images
Por fin tengo la instalacion hecha del aps del y tras. Parace ser que la centralita acabada en AA si funciona.
La señal acustica y grafica funciona, lo que me ocurre, es que cuando pulso el boton CAR no me aparece en el menu la opcion de ajustes del sistema de ayuda al aparcamiento.
Sabeis por que puede ser??
Gracias
La referencia E y la R funcionan con 8 sensores mas el tema Grafico.
Si tienes navi tendras que activar el modo grafico en el menu oculto.
Refencias ..........
First series:
4F0 910 283 A - 4 sensors, no graphical support
4F0 910 283 B - ? sensors, no graphical support
4F0 910 283 C - 8 sensors, graphical support
4F0 910 283 D - 4 sensors, graphical support
4F0 910 283 E - 8 sensors, graphical support, rear view camera support
4F0 910 283 F - 4 sensors, graphical support, rear view camera support
4F0 910 283 G - 8 sensors, graphical support, rear view camera support
4F0 910 283 H - 8 sensors, graphical support, rear view camera support
Second (current) series:
8K0 919 475 AA - 8 sensors, graphical support, rear view camera support
8K0 919 475 A - 8 sensors, graphical support8
K0 919 475 B - 4 sensors, no graphical support
8K0 919 475 C - 8 sensors, graphical support, rear view camera support
8K0 919 475 D - 4 sensors, no graphical support
8K0 919 475 E - 8 sensors, graphical support, rear view camera support
8K0 919 475 H - 4 sensors, graphical support, rear view camera support
8K0 919 475 R - 8 sensors, graphical support, rear view camera support
Gracias
La referencia E y la R funcionan con 8 sensores mas el tema Grafico.Si tienes navi tendras que activar el modo grafico en el menu oculto.
First series:4F0 910 283 A - 4 sensors, no graphical support4F0 910 283 B - ? sensors, no graphical support4F0 910 283 C - 8 sensors, graphical support4F0 910 283 D - 4 sensors, graphical support4F0 910 283 E - 8 sensors, graphical support, rear view camera support4F0 910 283 F - 4 sensors, graphical support, rear view camera support4F0 910 283 G - 8 sensors, graphical support, rear view camera support4F0 910 283 H - 8 sensors, graphical support, rear view camera support
Second (current) series:8K0 919 475 AA - 8 sensors, graphical support, rear view camera support8K0 919 475 A - 8 sensors, graphical support8K0 919 475 B - 4 sensors, no graphical support8K0 919 475 C - 8 sensors, graphical support, rear view camera support8K0 919 475 D - 4 sensors, no graphical support8K0 919 475 E - 8 sensors, graphical support, rear view camera support8K0 919 475 H - 4 sensors, graphical support, rear view camera support8K0 919 475 R - 8 sensors, graphical support, rear view camera support
buen aporte
Gracias
Gracias por la info. Como activo el menu del asistente de parking desde el menu oculto?
Gracias
Vamos a ver .. adivinos no somo dinos que modelo llevas de navi y te podremos orientar un poco mejor, de todas formas Google hace maravillas.
https://www.google.es/search?q=asistente+de+parking+desde+el+menu+oculto&ie=utf-8&oe=utf-8&gws_rd=cr&ei=M0y6VIqiGcz9UtXcgJAF
Audi avant 2011 mmi 3g. A mi me sale el pictograma del coche en la pantalla, lo que no me sale es en el menu de CAR, la opcione de ajustes de la ayuda al aparcamiento. Mi pregunta es, despues de haber hecho la instalacion completa y codificacion, hay que activar algo en el menu oculto?
Gracias
Problema resuelto!! Si habia que activar desde menu oculto. Ahora ya sale la opcion de ajustes de asistente de aparcamiento pulsando la tecla CAR.
Hay que ir a carmenuoperation y en park help ponemos valor 5, y reiniciamos el MMI (setup+joystick+boton superior dcho).
Enhorabuena challenger, al final lo has montado y te has ahorrado una pasta, seguro... Y encima tienes la satisfacción de haberlo hecho tu mismo!!!
Sds...
Me alegro compañero.
[emoji122] [emoji122] [emoji122] [emoji122] [emoji122]
Saludos del NaN@ooo By OnePlus
  • 9 meses más tarde...
Buenas tengo una duda estoy en pleno montaje, con el cable de la ampliación delantera cuál es el conector del módulo 46 donde debo conectar los cables pequeños que vienen pineados? Urge!
No se muy bien a que conector te refieres, hay un esquema eléctrico ea la ultima hoja del brico en PDF.
Si mal no recuerdo el cable en la punta de atras hacia la centralita, tiene dos pines sueltos que los tienes que meter el conectar marrón 16 pines, existente, que son los que van en el otro extremo a la botonera. Y luego esta el conector negro de 14 pines que lo enchufas al que queda libre.
Te comento que no hace falta quitar nada para pasar los cables hacia atrás, se mete bien con una guía mediendolos por dentro de los plásticos.
Se refiere al cable de ampliación para los sensores delanteros, el cable que para la zona delantera vienen dos pines que pone que van al mazo de cables del módulo 46 en concreto al mazo de cables de 16 pero no sé cuál es su el mazo negro o el marrón, esa es la duda, gracias
Enviado desde mi iPhone 6 Plus 
