PLATHY Publicado 17 de Octubre del 2011 Denunciar Publicado 17 de Octubre del 2011 Windows Based VAG/VAS Emulator VCDS Version: Release 10.6.4 Data version: 20110418 www.Ross-Tech.com 1 Fault Found: 18017 - Crash Shut-Down Activated P1609 - 001 - Upper Limit Exceeded Readiness: 0010 0001 Dealer/Shop Name: Workshop Code: 000 00000 Self-Diagnosis Log Thursday,13,October,2011,11:23:31:10074 VIN: WAUZZZ8E45A423521 License Plate: Mileage: Repair Order: Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E45A423521 Mileage: 70700km/43930miles-------------------------------------------------------------------------------Address 01: Engine Labels: Redir Fail! Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B Component: 1.8L R4/5VT G 0010 Coding: 0011581 Shop #: WSC 33278 133 00032 VCID: 7F0907CF576D -------------------------------------------------------------------------------Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 8E0 910 159 B HW: 01J 927 156 HT Component: V30 01J 1.8l5VT RdW 0010 Revision: 00000006 Serial number: 00000000840513 Coding: 0000001 Shop #: WSC 06335 000 00000 VCID: 285BFC93E263 4 Faults Found: 18201 - Transmission Output Speed Sensor 2 (G196): No Signal P1793 - 000 - - 17137 - Shift Solenoid 1 (N88): Circuit Failure P0753 - 007 - Short to Ground - Intermittent 17090 - Transmission Range Sensor (F125): Implausible Signal P0706 - 000 - - 17134 - Shift Solenoid 1 (N88): Malfunction P0750 - 000 - - - Intermittent ------------------------------------------------------------------------------- 1 Fault Found: 01119 - Gear Recognition Signal 000 - - No fault code found. No fault code found. VCDS Self-Diagnosis Log Thursday,13,October,2011,11:23:32:10074 Page 2 VIN: WAUZZZ8E45A423521 License Plate: Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT Component: ESP8 front H04 0180 Revision: 00000000 Serial number: 00000000000000 Coding: 0004872 Shop #: WSC 06335 000 00000 VCID: 2647F2ABE877 -------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AJ Component: A4 Klimaautomat 2728 Coding: 00000 Shop #: WSC 06335 VCID: 69DDB99739E9 -------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 J Component: int. Lastmodul ECE 0303 Coding: 00001 Shop #: WSC 06335 VCID: 397D29D709C9 -------------------------------------------------------------------------------Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 G HW: 8E0 959 655 G Component: Airbag 9.41 H10 3230 Revision: 91H10323 Serial number: 0036M000NG1S Coding: 0033622 Shop #: WSC 06335 000 00000 VCID: 3B7133DF03F5 1 Fault Found: 01587 - Igniter 2 for Airbag; Drivers Side (N250) 001 - Upper Limit Exceeded - Intermittent - MIL ON ------------------------------------------------------------------------------- No fault code found. 1 Fault Found: 01304 - Radio 004 - No Signal/Communication No fault code found. VCDS Self-Diagnosis Log Thursday,13,October,2011,11:23:32:10074 Page 3 VIN: WAUZZZ8E45A423521 License Plate: Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0601 Coding: 00041 Shop #: WSC 06335 VCID: 418D41376119 -------------------------------------------------------------------------------Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 900 Q HW: 8E0 920 900 Q Component: KOMBI+WFS 3 H12 0020 Revision: 0020 Serial number: AUX6Z0D0447840 Coding: 0004141 Shop #: WSC 00160 572 63401 VCID: 326F1EFBD4BF -------------------------------------------------------------------------------Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 VCID: EBD1439FB315 ------------------------------------------------------------------------------- Part No: 8E1959801B Component: Tõrsteuer.FS BRM 0205 Part No: 8E1959802B Component: Tõrsteuer.BF BRM 0205 Part No: 8E0959801A Component: Tõrsteuer.HL BRM 0205 Part No: 8E0959802A Component: Tõrsteuer.HR BRM 0205 VCDS Self-Diagnosis Log Thursday,13,October,2011,11:23:32:10074 Page 4 VIN: WAUZZZ8E45A423521 License Plate: Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BM Component: Komfortgerát T3B 2431 Coding: 06266 Shop #: WSC 06335 VCID: 7DF5FDC75D61 2 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 00915 - Window Regulator Switch; Rear Right; Driver (E55) 27-10 - Implausible Signal - Intermittent End ----------------------------------------- estos son los fallos que me a salido a pasar el autscan, despues de ver los allos que me salen como airbag, instrumentos, y demas cosas mi duda es que pasos e de seguir para poder quitar estos fallos ya que no tengo ninguna idea del vag, hasta hay llego no toco nada por si borro algo. gracias de antemano Responder
PLATHY Publicado 17 de Octubre del 2011 Autor Denunciar Publicado 17 de Octubre del 2011 Windows Based VAG/VAS Emulator VCDS Version: Release 10.6.4 Data version: 20110418 www.Ross-Tech.com 1 Fault Found: 18017 - Crash Shut-Down Activated P1609 - 001 - Upper Limit Exceeded Readiness: 0010 0001 Dealer/Shop Name: Workshop Code: 000 00000 Self-Diagnosis Log Thursday,13,October,2011,11:23:31:10074 VIN: WAUZZZ8E45A423521 License Plate: Mileage: Repair Order: Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E45A423521 Mileage: 70700km/43930miles-------------------------------------------------------------------------------Address 01: Engine Labels: Redir Fail! Part No SW: 8E0 909 518 AQ HW: 8E0 909 018 B Component: 1.8L R4/5VT G 0010 Coding: 0011581 Shop #: WSC 33278 133 00032 VCID: 7F0907CF576D -------------------------------------------------------------------------------Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 8E0 910 159 B HW: 01J 927 156 HT Component: V30 01J 1.8l5VT RdW 0010 Revision: 00000006 Serial number: 00000000840513 Coding: 0000001 Shop #: WSC 06335 000 00000 VCID: 285BFC93E263 4 Faults Found: 18201 - Transmission Output Speed Sensor 2 (G196): No Signal P1793 - 000 - - 17137 - Shift Solenoid 1 (N88): Circuit Failure P0753 - 007 - Short to Ground - Intermittent 17090 - Transmission Range Sensor (F125): Implausible Signal P0706 - 000 - - 17134 - Shift Solenoid 1 (N88): Malfunction P0750 - 000 - - - Intermittent ------------------------------------------------------------------------------- 1 Fault Found: 01119 - Gear Recognition Signal 000 - - No fault code found. No fault code found. VCDS Self-Diagnosis Log Thursday,13,October,2011,11:23:32:10074 Page 2 VIN: WAUZZZ8E45A423521 License Plate: Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT Component: ESP8 front H04 0180 Revision: 00000000 Serial number: 00000000000000 Coding: 0004872 Shop #: WSC 06335 000 00000 VCID: 2647F2ABE877 -------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AJ Component: A4 Klimaautomat 2728 Coding: 00000 Shop #: WSC 06335 VCID: 69DDB99739E9 -------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 J Component: int. Lastmodul ECE 0303 ----------------------------- 1 Fault Found: 01119 - Gear Recognition Signal 000 - - No fault code found. No fault code found. VCDS Responder
WAJE Publicado 17 de Octubre del 2011 Denunciar Publicado 17 de Octubre del 2011 No entiendo lo que pones Plathy, haber cuando te pase yo el vag salieron un monton de fallos, los 4 del cambio son de la unidad de control, EL DEL MOTOR ES NUEVO, TENIAS 2 PERO ESTE ES DISTINTO, MIRA haber que es, por ahi hay un manual del significado de cada codigo, el de los frenos se ha vuelto a repetir, mira haber tambie que significa y el del airbag he visto que te ha vuelto a salir con lo que se te habra vuelto a encender la luz no? a y elk de la radio pasa de el. SALUDOS Y YA CONTARAS Responder
