Mahou Publicado 22 de Octubre del 2011 Denunciar Compartir Publicado 22 de Octubre del 2011 (editado) Hola gente. Necesito que alguien tenga la bondad de interpretar la siguiente lectura que me ha hecho el vag-com. VCDS Version: Release 10.6.4 Data version: 20110418 Saturday,22,October,2011,18:45:06:10074 Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56 61 62 72 77 VIN: WAUZZZ4F26N099XXX Mileage: 127590km/79280miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 402 L HW: 4F0 907 401 B Component: 3.0L V6TDI G000AG 0010 Revision: --H01--- Serial number: Coding: 0011372 Shop #: WSC 02334 785 00200 VCID: 2647F2ABE877 2 Faults Found: 004120 - Intake Manifold Runner (Bank 2): Lower limit not reached P1018 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 254 Mileage: 120426 km Time Indication: 0 Date: 2011.04.29 Time: 18:17:45 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 12.54 V Duty Cycle: 20.5 % Duty Cycle: 88.8 % Duty Cycle: 20.5 % 005445 - Throttle Valve Controller: Malfunction P1545 - 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 105 Mileage: 120426 km Time Indication: 0 Date: 2011.04.29 Time: 18:17:46 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 12.54 V Duty Cycle: 92.7 % Bin. Bits: 010 Mass Air / Rev.: 0.0 mg/str Readiness: 1 2 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 B HW: 09L 927 156 A Component: AG6 09L 3.0lTDI RdW 0040 Revision: --H01--- Serial number: 4099646 Coding: 0000001 Shop #: WSC 02325 785 00200 VCID: 2341EBBF9B45 1 Fault Found: 009783 - Torque Management Feedback Signal A P2637 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 40 Mileage: 120432 km Time Indication: 0 Date: 2011.04.30 Time: 10:39:02 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 25.0°C T.B. Angle: 0.0° ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H04 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0020876 Shop #: WSC 02325 785 00200 VCID: 2D550D87CD81 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0180 Revision: 30070501 Serial number: 10600600263527 Coding: 0000007 Shop #: WSC 02323 785 00200 VCID: E3C12BBF5BC5 Part No: 4F0 910 131 G Component: FBSAUDIC6 EZS H45 0070 Part No: 4F0 910 335 Component: FBSAUDIC6 KSG H27 0080 3 Faults Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground Freeze Frame: Fault Status: 01110111 Fault Priority: 3 Fault Frequency: 1 Reset counter: 178 Mileage: 120432 km Time Indication: 0 Date: 2011.04.30 Time: 10:31:51 01176 - Key 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 29 Mileage: 122849 km Time Indication: 0 Date: 2011.06.07 Time: 16:45:42 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 40 Time Indication: 0 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F0 910 731 HW: 4E0 035 729 Component: Interfacebox H43 1200 Revision: 00000000 Serial number: 350JP057610781 Coding: 0000004 Shop #: WSC 02323 785 00200 VCID: DFC9274F77AD Part No: 4F0 910 609 E Component: Bedienteil MMIC6H08 0050 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 S Component: KLIMABETAETIGUNGH12 0160 Revision: 00000027 Serial number: 00000000196521 Coding: 0008214 Shop #: WSC 02325 785 00200 VCID: DBB1135F63B5 1 Fault Found: 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 18 Reset counter: 227 Mileage: 122921 km Time Indication: 0 Date: 2011.06.11 Time: 11:08:13 Freeze Frame: Voltage: 13.60 V (no units): 216.0 (no units): 255.0 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 D HW: 4F0 907 279 Component: ILM Fahrer H15 0190 Revision: 00000000 Serial number: 4F0907279 Coding: 0003121 Shop #: WSC 02335 785 00200 VCID: 2A5F069BFC6F Part No: 4F1 910 113 Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 E HW: 4E0 035 111 A Component: CD-Changer H44 0430 Revision: 00000000 Serial number: AUZ5ZBE7252955 Shop #: WSC 00000 000 00000 VCID: 1B31D35FA335 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 4 Fault Frequency: 4 Reset counter: 235 Mileage: 127569 km Time Indication: 0 Date: 2011.10.20 Time: 23:19:12 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 E HW: 4F0 959 655 B Component: 43 AIRBAG AUDI8RH29 0260 Revision: 07H29000 Serial number: 0037LD0AL73% Coding: 0013363 Shop #: WSC 02325 785 00200 VCID: 295DF997F969 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90025052870610 Coding: 0002141 Shop #: WSC 02323 785 00200 VCID: E6C732ABA8F7 Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 930 C HW: 4F0 920 932 Component: KOMBIINSTR. M73 H18 0120 Revision: 00700000 Serial number: 5HP36FRA6 Coding: 2113143 Shop #: WSC 50741 143 61874 VCID: 2341EBBF9B45 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H11 0070 Revision: 11 Serial number: 1300805A178132 Coding: 6CFE73C41B3104 Shop #: WSC 00000 000 00000 VCID: 2759FFAFEF7D No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H45 1060 Revision: 00000000 Serial number: 305JM057646400 Shop #: WSC 02323 785 00200 VCID: 3B7133DF03F5 1 Fault Found: 02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 7 Fault Frequency: 1 Reset counter: 212 Mileage: 127194 km Time Indication: 0 Date: 2011.10.11 Time: 10:30:30 Freeze Frame: Hex Value: 0x4E94 Hex Value: 0x1AC6 Hex Value: 0x1600 Hex Value: 0x5B44 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 793 E Component: TSG FA H12 0080 Revision: 00000000 Serial number: – Coding: 0018954 Shop #: WSC 02327 785 00200 VCID: 2C530083F69B No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H19 0140 Revision: 01400019 Serial number: 01008066450000 Coding: 0132229 Shop #: WSC 02335 785 00200 VCID: 2E570A8BC087 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-BO.lbl Part No SW: 4F0 910 223 A HW: 4F0 035 223 A Component: DSP-High C6 H09 0140 Revision: PROD_01 Serial number: 00000000809324 Coding: 0000012 Shop #: WSC 02323 785 00200 VCID: 1C33D043A63B No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000095291 Coding: 0001003 Shop #: WSC 02323 785 00200 VCID: DEB71A4B70A7 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 792 E Component: TSG BF H12 0080 Revision: 00000000 Serial number: 7‚ Coding: 0018954 Shop #: WSC 02327 785 00200 VCID: 2C530083F69B No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0000321 Shop #: WSC 02334 785 00200 VCID: DDB51D477DA1 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 C HW: 4F0 907 357 C Component: AFS 1 H01 0030 Revision: 00000001 Serial number: Coding: 0000016 Shop #: WSC 02325 785 00200 VCID: 2647F2ABE877 Part No: 4F0 941 329 B Component: AFS-Modul links H02 0020 Part No: 4F0 941 329 B Component: AFS-Modul rechtsH02 0020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 F HW: 4F0 035 541 B Component: TUNER EU/US/RDW H42 0480 Revision: 00000000 Serial number: 394J2057628865 Coding: 0000001 Shop #: WSC 02323 785 00200 VCID: 2341EBBF9B45 1 Fault Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 220 Mileage: 127293 km Time Indication: 0 Date: 2011.10.14 Time: 00:32:43 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: J0644 BEM H12 0590 Revision: 00000000 Serial number: 00000000136389 Shop #: WSC 00192 572 55138 VCID: 2341EBBF9B45 Part No: 4F0 915 105 D Component: von VA0 2510150548 Coding: 344630393135313035442056413032353130313530353438 Shop #: WSC 00000 384 00290 2 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Mileage: 122445 km Time Indication: 0 Date: 2011.05.29 Time: 17:27:46 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Mileage: 122445 km Time Indication: 0 Date: 2011.05.29 Time: 17:31:12 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 795 E Component: TSG HL H21 0050 Coding: 0018434 Shop #: WSC 02327 785 00200 VCID: 2E570A8BC087 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 794 E Component: TSG HR H21 0050 Coding: 0018434 Shop #: WSC 02327 785 00200 VCID: 2E570A8BC087 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-333.lbl Part No SW: 4E0 910 333 E HW: 4E0 862 333 C Component: TELEFONMODUL EU 0700 Revision: 00000006 Serial number: T2AUDX0505JBXV Coding: 0000006 Shop #: WSC 02323 785 00200 VCID: 214DE1B78159 No fault code found. End --------------------------------------------------------------------- Os pongo en antecedentes..... Este coche lo compré en Mayo de este año. Tuve problemas con el golfo del compra-venta (hasta el punto de que no me dió ni el libro de mantenimiento ni siquiera los papeles del coche una vez hecha la transferencia), por lo que no tengo muy claro el tema de que los Km sean los reales y no sé como mirarlo con el vag, aunque más pronto que tarde espero despejar la duda. Aun así, el tema papeleo está resuelto con duplicados. Pero bueno, al tema....sobre el vag-com El vag-com lo he recibido hoy. Se trata de este: http://www.spaincard...1%26aid%3D10%26 He instalado la versión 10.6.4, que parece la más estable y para un novato como yo creo que es lo mejor de momento. Mi primera sorpresa ha sido al conectar el cable y hacerle el registro. Como no había puesto el contacto, me decía que no era can, por lo que tenía que seleccionar el tipo y modelo de coche viendo que solo me admitia el modelo C5 en vez del C6 que es el que debería ser...... No obstante os cuelgo unas fotos y me decis lo que creeis... http://img805.images...inmatricula.jpg http://img688.images...nmatricula2.jpg http://img190.images...riculainter.jpg Luego una vez corregida mi pequeño error y con el contacto puesto, he pulsado en can y el solito me ha detectado el modelo y realizado el autoscan con los datos que os he puesto para analizar. Lo que no aparece en el autoscan es nada relacionado con un problema que creo pueda ser de la EGR. Me explico..... El coche a revoluciones bajas parece que va ahogado y si le piso el acelerador, parece que se ahoga hasta que sube de revoluciones y empieza a tirar como alma que lleva el diablo. Además el consumo en ciudad es un poco elevado (13-14L.) y no se donde mirar si falla la EGR o cual pueda ser el problema. Tras todo este peazo ladrillo que he soltado, no me queda más que pediros ayuda para la interpretación del autoscan puesto y si habeis llegado hasta aquí, también opinión y ayuda sobre el resto. Saludos a todos Editado 22 de Octubre del 2011 por Mahou Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Mahou Publicado 23 de Octubre del 2011 Autor Denunciar Compartir Publicado 23 de Octubre del 2011 Hola a todos nuevamente. De los fallos descritos he estado averiguando algunas cosas por ahi.......y creo que lo realmente importante son estos dos: Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 402 L HW: 4F0 907 401 B Component: 3.0L V6TDI G000AG 0010 Revision: --H01--- Serial number: Coding: 0011372 Shop #: WSC 02334 785 00200 VCID: 2647F2ABE877 2 Faults Found: 004120 - Intake Manifold Runner (Bank 2): Lower limit not reached P1018 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 254 Mileage: 120426 km Time Indication: 0 Date: 2011.04.29 Time: 18:17:45 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 12.54 V Duty Cycle: 20.5 % Duty Cycle: 88.8 % Duty Cycle: 20.5 % 005445 - Throttle Valve Controller: Malfunction P1545 - 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 105 Mileage: 120426 km Time Indication: 0 Date: 2011.04.29 Time: 18:17:46 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 12.54 V Duty Cycle: 92.7 % Bin. Bits: 010 Mass Air / Rev.: 0.0 mg/str Readiness: 1 2 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 B HW: 09L 927 156 A Component: AG6 09L 3.0lTDI RdW 0040 Revision: --H01--- Serial number: 4099646 Coding: 0000001 Shop #: WSC 02325 785 00200 VCID: 2341EBBF9B45 1 Fault Found: 009783 - Torque Management Feedback Signal A P2637 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 40 Mileage: 120432 km Time Indication: 0 Date: 2011.04.30 Time: 10:39:02 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 25.0°C T.B. Angle: 0.0° Pido por favor un poco de ayuda, pues no quiero tener que llevarlo a taller Audi, y necesito saber exactamente (o lo más aproximado posible) de que avería se trata para poder dejárselo a un taller de los de toda la vida y avaratar el coste, aunque preveo que será importante. Creo que los dos primeros se trata de algo relacionado con la EGR, pero dentro de la EGR hay varias cosas y por eso solicito vuestra ayuda. Y del tercero no tengo ni la más remota idea. Echarme una manita por favor. Venga, un saludo a todos. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
fjortuno Publicado 23 de Octubre del 2011 Denunciar Compartir Publicado 23 de Octubre del 2011 Hola Mahou, pues los dos primeros errores que tienes son los mas comunes aqui en el foro, El primero es de la valvula de admision del banco de cilindros 2 mirate el foro , posiblemente mal contacto en el motor que la actua. y el segundo fallo es la valvula de mariposa al lado de la egr que falla , se desgastan los engranajes y se fastidia, tambien hay aqui en el foro como cambiarla. Suerte Responder Enlace al comentario Compartir en otros sitios web More sharing options...
fjortuno Publicado 23 de Octubre del 2011 Denunciar Compartir Publicado 23 de Octubre del 2011 Ah se me olvidaba decirte que te indica el fallo a los km del vehiculo y la fecha en la que ocurrio, Mileage: 120432 km Time Indication: 0 Date: 2011.04.30 Time: 10:39:02 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 23 de Octubre del 2011 Denunciar Compartir Publicado 23 de Octubre del 2011 la tira la de errores que llevas, lo primero y importante es que una vez que has hecho el scan los guardes y borres los fallos, luego vuelvas a scanear para saber lo que verdaderamente tienes averiado, te digo error importante que tienes en la caja de cambios es el sensor de par, por eso no va bien el coche, y los fallos del motor tienes la mariposa principal y la del banco Nº2 cascada el navegador dice que tienes que ponerlo nuevo, del cd dice que tienes la protección activa, en la radio el cable de la antena parece estar suelto, las llaves se te han quedado sin pila parece ser, errores con la batería mira ver esta ultima como esta no valla ser causante de estos últimos errores Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Mahou Publicado 23 de Octubre del 2011 Autor Denunciar Compartir Publicado 23 de Octubre del 2011 Gracias a los dos por vuestra ayuda. Ximo, me has dejao acojonao.....Mas de lo que ya estaba. El sensor de par del cambio, pone error intermitente. Y solo lo tengo como producido una vez, por lo que espero que haya sido un error puntual sin más.Para comprobarlo, ¿como lo borro?. ¿Desde el autoscan puedo, una vez hecho el autoscan, borrar todos los errores y circular un poco y realizarlo otra vez. O tengo que meterme en el módulo específico para borrarlos uno a uno? En cuanto a los errores de la EGR, ¿Crees que tengo que cambiar la pieza de la aleta de mando entera? (he visto el brico y parece fácil, lástima de no tener ni sitio donde hacerlo yo ni algo del material necesario...Con el otro brico, no me atrevería. Demasiadas piezas a desmontar) Gracias de nuevo a los dos por vuestra ayuda. Salu2 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Mahou Publicado 23 de Octubre del 2011 Autor Denunciar Compartir Publicado 23 de Octubre del 2011 el navegador dice que tienes que ponerlo nuevo, del cd dice que tienes la protección activa, en la radio el cable de la antena parece estar suelto, las llaves se te han quedado sin pila parece ser, errores con la batería mira ver esta ultima como esta no valla ser causante de estos últimos errores El navegador me funciona bien. La radio también, y la llave, le cuesta algunas veces reconocermela al intentar abrir el coche. Efectivamente puede ser un problema de batería, y de pila del mando. He visto por el foro un problema similar con el voltaje. Intentaré que me hagan una medición para saber como en que estado está. En definitiva y tras mucho buscar info sobre los errores, la conclusión es que son 3 los errores más graves. Los 2 relacionados con la EGR y el que más me acojona, el sensor del par, que aunque pone en el log "intermitente", bien pudiera ser el causante de ese problema que os he descrito que le noto al coche..... A ver si sé como borrarlos con el vag y comprobar si me los pone otra vez. Salu2 Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Mahou Publicado 23 de Octubre del 2011 Autor Denunciar Compartir Publicado 23 de Octubre del 2011 Veamos que os parece las pruebas realizadas y los resultados. he bajado al garaje y tras volver a realizar un autoscan, he borrado los DLCs. Me he dado una vuelta con el coche (unos 3 Km) y he vuelto a realizar un autoscan con el siguiente resultado: VCDS Version: Release 10.6.4 Data version: 20110418 Sunday,23,October,2011,17:11:04:10074 Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55 56 61 62 72 77 VIN: WAUZZZ4F26N099XXX Mileage: 127600km/79286miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 402 L HW: 4F0 907 401 B Component: 3.0L V6TDI G000AG 0010 Revision: --H01--- Serial number: Coding: 0011372 Shop #: WSC 02334 785 00200 VCID: 2647F2ABE877 2 Faults Found: 004120 - Intake Manifold Runner (Bank 2): Lower limit not reached P1018 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 3 Mileage: 127597 km Time Indication: 0 Date: 2011.10.23 Time: 16:45:29 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 11.86 V Duty Cycle: 20.5 % Duty Cycle: 88.8 % Duty Cycle: 20.5 % 005445 - Throttle Valve Controller: Malfunction P1545 - 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 127597 km Time Indication: 0 Date: 2011.10.23 Time: 16:45:31 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 11.86 V Duty Cycle: 92.7 % Bin. Bits: 010 Mass Air / Rev.: 0.0 mg/str Readiness: 0 0 1 1 1 Como podeis ver, todos los problemas han desaparecido menos los 2 de la EGR. El que más me acojonaba de momento no aparece (menos mal, uuufff). Eso si, la pila de la llave parece haber muerto. No he podido abrir a traves del sensor inhalambrico, y arrancar tampoco. He tenido que meter la llave enla cerradura y en el contacto. Habrá que cambiar la pila, pero ese es el menor de mis problemas ahora mismo. ¿Seguis pensando que tengo que cambiar la mariposa del banco 2 de la EGR, y de la entrada principal de la admisión, o podría ser un problema de suciedad o mal contacto del motorcillo? Gracias de nuevo por vuestras opiniones. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 23 de Octubre del 2011 Denunciar Compartir Publicado 23 de Octubre del 2011 no es la ERG, cuando es esta lo pone ademas si lees por los hilos esta el error en esta pagina o en la siguiente del foro que el tema no ha bajado tanto tu lo que tienes mal es la mariposa de un lado del lado derecho mirando tu hacia el motor y esta otra mira http://www.audisport-iberica.com/foro/index.php?/topic/270217-brico-para-cambiar-la-palometa-de-la-admision/ aqui tienes el segundo error, la solución y brico del primer error aquí tienes la solución y brico, la que tu tienes rota es, si no estoy equivocado, la que tiene darsonar en la primera foto del post con un circulo http://www.audisport-iberica.com/foro/index.php?/topic/271768-brico-desmontaje-egr-y-admision/ que ya de paso haces lo de darsonar pos no te vendrá mal y si no te va bien el motor después de limpiar las mariposas o palomillas, palometas o como las quieras llamar es lo del sensor de par del motor que es la avería de la caja de cambios acostumbramos a poner los errores sin comprobar que verdaderamente tenemos errores el metodo correcto para decir tenemos un error es: 1º scanear, 2º guardar scan 3º borrar errores 4º volver hacer scan si son errores de motor 5º rodar el coche un poco o unos días 6º volver hacer scan como ves yo te dije que borraras :clap1: y nos quedemos sin la mitad de errores cuando la batería falla, graba el coche fallos erroneos Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Mahou Publicado 23 de Octubre del 2011 Autor Denunciar Compartir Publicado 23 de Octubre del 2011 Primero de todo agradecerte la aclaración. Cuando hablo de la EGR es porque ya me he visto los dos bricos (y unos cuantos más). Lo pongo un par de post más arriba, que con el de dasonar no me atrevería, pero con el segundo si (el de la palometa), pero que por falta de alguna herramienta y de sitio no lo podía hacer. Además, para arreglar el primero, hay que soltar la palometa del segundo error. Aun habiendo visto los bricos, no me quedó claro que sea una mariposa o el motorcillo o la carbonilla lo que motivaba el error, pero tenía claro que era la admisión. En cuanto a los errores puestos en el primer post, he de disculparme. Pero tambien explico que el cable del vag-com lo recibí el mismo sábado y era mi primer scaneado, con lo que puse todo lo que aparecia para que me dieseis una impresión (que hicisteis tanto tú como el amigo fjortuno y que os agradezco). De hecho, me he guiado para hacer el autoscaneado de un muy buen post explicativo de Txispis. Me parece muy correcta la manera que expones de postear los errores del vag, pero entiende que los novatos como yo no nacemos sabiendo y preguntamos exponiendo muchas veces información excesiva por no saber desgranar lo importante de lo nimio. Ahora ya se cuales son los pasos para desgranar los errores a traves del autoscan. Sigo aprendiendo a base de leer y de explicaciones de los que afortunadamente os dignais en responder o de postear cosas para los neófitos como yo. Un saludo y reitero mi agradecimiento por tus explicaciones Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 23 de Octubre del 2011 Denunciar Compartir Publicado 23 de Octubre del 2011 mahou aqui estamos para ayudarnos y aprender lo que no sabemos, que aquí el primero que tiene que aprender soy yo Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Mahou Publicado 23 de Octubre del 2011 Autor Denunciar Compartir Publicado 23 de Octubre del 2011 (editado) mahou aqui estamos para ayudarnos y aprender lo que no sabemos, que aquí el primero que tiene que aprender soy yo Ya me gustaría a mi saber una cuarta parte de lo que tu sabes de nuestros coches......Aunque dame tiempo, que a esa cuarta parte creo que llegaré. Por otra parte me has dejado con la duda rondando por mi cabeza.......¿Crees que el problema que le detecto al coche pueda ser motivado por los dos problemas de la admisión, o no tienen nada que ver esos problemas de falta de empuje o ahogamiento a bajas revoluciones?. Te recuerdo el problema: "El coche a revoluciones bajas parece que va ahogado y si le piso el acelerador, parece que se ahoga hasta que sube de revoluciones y empieza a tirar como alma que lleva el diablo." Si no crees que este pueda ser el motivo, está claro que piensas más en el sensor del par.... Editado 23 de Octubre del 2011 por Mahou Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 23 de Octubre del 2011 Denunciar Compartir Publicado 23 de Octubre del 2011 mahou si lees los post de los enlaces que te pasado antes, ninguno de los dos habla de fallos en el coche, exceptuando el testigo en el salpicadero, asi que lo tuyo pueden ser las palomillas, que estas las tienes cascadas seguro, pero yo con el empuje si te lo sigue haciendo y te vuelve a salir el fallo, tiene que ver el par, tu llevas convertidor, si no le han hecho ningún cambio de atf yo se lo haria, por cambiarlo y controlar niveles Responder Enlace al comentario Compartir en otros sitios web More sharing options...
Mahou Publicado 23 de Octubre del 2011 Autor Denunciar Compartir Publicado 23 de Octubre del 2011 Vale ximo. Tomo nota de lo del cambio, aunque en el conce me dijeron que mi coche no llevaba mantenimiento del cambio, algo he leido por el foro sobre la conveniencia de hacérselo. De hecho, hablan muy bien de un sitio en Alcorcon (Madrid) que investigaré un poco antes de llevar el coche. ¿Sabes si tras el cambio del sensor del par hay que tocar algo en el vag?. Si me dices que no, buscaré un buen sitio donde me cambien el aceite del cambio (que se hace de una manera tan particular) y sepan cambiar este sensor. Si por el contrario, hay que codificar el sensor, me tocará ir a algún conce oficial y aflojar bastante el bolsillo.... La misma pregunta te hago con las palomillas. ¿Sabes si tras el cambio hay que codificar algo con el vag?. Aunque creo haber leido que se le hace un "ajuste básico", no tengo muy claro en que consiste. Salu2 P.D. Buen apunte sobre los dos bricos. Es cierto que ninguno refiere avería. Tan solo luz en el cuadro, cosa que a mi no se me enciende. Responder Enlace al comentario Compartir en otros sitios web More sharing options...
ximo@6 Publicado 24 de Octubre del 2011 Denunciar Compartir Publicado 24 de Octubre del 2011 mira vas50 solo me dice el fallo, que es la señal A del par de motor, pero no me da mas explicaciones, segun esto lleva cinco anillos o lo que sea que lleva, que va del A B C D E, a ti el que te da el fallo es el A, supongo que esto es dentro del convertidor de par, que hasta aqui llega mi sabiduria, por cierto no tienes la luz has mirado si cuando enciendes el coche se te enciende en el check, porque lo mismo se fundió de ir tanto tiempo encendida y te lo vendieron ya con la pega Responder Enlace al comentario Compartir en otros sitios web More sharing options...
